06-09-2022, 12:22 | #1 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | ERROR[012]: Write error [Solved] Welcome to Medusa Pro Software version 2.2.4.6. Started. Reader #0: Generic EMV Smartcard Reader 0 Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[016]: CID error(check voltage/bus mode) Socket not detected! Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC RP64AB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 150100525036344142001922CE4E39D3 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : RP64AB Product revision : 0.0 Product serial number : (hex) 1922CE4E Manufacturing date : 03/2022 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20357120 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/RP64AB_09_06_2022_14_20_30.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.4.6; FW: 2.00. ERROR[011]: Read error. At sector 0. Disconnected. Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC RP64AB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 150100525036344142001922CE4E39D3 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : RP64AB Product revision : 0.0 Product serial number : (hex) 1922CE4E Manufacturing date : 03/2022 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20357120 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/RP64AB_09_06_2022_14_20_41.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.4.6; FW: 2.00. P00: GPT (00000000, 00400000) 4 MB P01: efs (00400000, 00800000) 8 MB P02: sec_efs (00C00000, 00800000) 8 MB P03: steady (01400000, 00400000) 4 MB P04: nvram (01800000, 04000000) 64 MB P05: spmfw (05800000, 00100000) 1024 KB P06: scp1 (05900000, 00100000) 1024 KB P07: sspm_1 (05A00000, 00100000) 1024 KB P08: tee1 (05B00000, 00200000) 2048 KB P09: tzar (05D00000, 00400000) 4 MB P10: gz1 (06100000, 01000000) 16 MB P11: lk (07100000, 00200000) 2048 KB P12: dtbo (07300000, 00800000) 8 MB P13: vbmeta (07B00000, 00010000) 64 KB P14: btd (07B10000, 004F0000) 4.938 MB P15: protect1 (08000000, 00800000) 8 MB P16: protect2 (08800000, 00800000) 8 MB P17: seccfg (09000000, 00800000) 8 MB P18: bota (09800000, 02D00000) 45 MB P19: boot_para (0C500000, 00100000) 1024 KB P20: para (0C600000, 00080000) 512 KB P21: misc (0C680000, 00080000) 512 KB P22: expdb (0C700000, 01400000) 20 MB P23: frp (0DB00000, 00100000) 1024 KB P24: nvcfg (0DC00000, 02000000) 32 MB P25: nvdata (0FC00000, 04000000) 64 MB P26: metadata (13C00000, 02000000) 32 MB P27: keyrefuge (15C00000, 01000000) 16 MB P28: keydata (16C00000, 01000000) 16 MB P29: md_udc (17C00000, 0169A000) 22.6 MB P30: persistent (1929A000, 00080000) 512 KB P31: proinfo (1931A000, 00300000) 3072 KB P32: md1img (1961A000, 06400000) 100 MB P33: logo (1FA1A000, 00800000) 8 MB P34: param (2021A000, 00400000) 4 MB P35: up_param (2061A000, 00400000) 4 MB P36: persist (20A1A000, 03000000) 48 MB P37: boot (23A1A000, 02000000) 32 MB P38: recovery (25A1A000, 02500000) 37 MB P39: vbmeta_system (27F1A000, 00010000) 64 KB P40: vbmeta_vendor (27F2A000, 00010000) 64 KB P41: efuse (27F3A000, 00080000) 512 KB P42: rsv1 (27FBA000, 00046000) 280 KB P43: sec1 (28000000, 00800000) 8 MB P44: super (28800000, 16C000000) 5.688 GB P45: prism (194800000, 12800000) 296 MB P46: optics (1A7000000, 01800000) 24 MB P47: cache (1A8800000, 0C800000) 200 MB P48: omr (1B5000000, 03200000) 50 MB P49: spu (1B8200000, 03200000) 50 MB P50: userdata (1BB400000, CD4000000) 51.31 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/RP64AB_efs_0x2000_0x4000_09_06_2022_14_20_41.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.2.4.6; FW: 2.00. Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/RP64AB_nvdata_0x7e000_0x20000_09_06_2022_14_20_41. bin file... Reading. Please wait... Done. Elapsed time 00:00:21 SW: 2.2.4.6; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 1327104 Number of sectors : 11927552 Build ID : RP1A.200720.012 Display Build ID : RP1A.200720.012.A037FXXU1AVA1 Release ID : 11 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : a03snnxx-user 11 RP1A.200720.012 A037FXXU1AVA1 release-keys --------------------------------------------------------------- ERROR[012]: Write error. At sector 0 Disconnected. |
06-09-2022, 12:41 | #2 (permalink) | |
Member: 2185549 Status: Offline Thanks Meter: 535 | Quote:
