Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 06-24-2020, 12:15   #1 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 475
EXD_CSD BUG .. Please Solve [Answered]
Partition config often changes other than original ..
bug in new version ..
i have encountered this problem 5 times now in different phones ...
Welcome to Medusa Pro Software version 2.1.1.
Started.
Reader #0: Alcor Micro USB Smart Card Reader 0
Reader #1: Alcor Micro USB Smart Card Reader 1
Reader #2: FT SCR2000 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 3.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC QD63MB
Page size : 512 B
Block size : 512 B
Block count : 61071360
Size : 29.12 GB (29820.00 MB)
CID Info
CID : 150100514436334D420336DE068596B5
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : QD63MB
Product revision : 0.3
Product serial number : (hex) 36DE0685
Manufacturing date : 09/2019
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 16384 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 8Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x02) 00000010
Boot bus width : x8 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 15261696 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QD63MB_24_06_2020_15_45_50.bin.
Connect successful.
SW: 2.1.1; FW: 1.24.
P00: GPT (00000000, 00000040) 32 KB
P01: boot_para (00000040, 00000800) 1024 KB
P02: recovery (00000840, 00010000) 32 MB
P03: para (00010840, 00000400) 512 KB
P04: opporeserve1 (00010C40, 00004000) 8 MB
P05: opp/reserve2 (00014C40, 00020000) 64 MB
P06: opporeserve3 (00034C40, 00020000) 64 MB
P07: oppo_custom (00054C40, 00000800) 1024 KB
P08: expdb (00055440, 0000A000) 20 MB
P09: frp (0005F440, 00000800) 1024 KB
P10: vbmeta (0005FC40, 00004000) 8 MB
P11: nvcfg (00063C40, 00010000) 32 MB
P12: nvdata (00073C40, 00020000) 64 MB
P13: metadata (00093C40, 00010000) 32 MB
P14: protect1 (000A3C40, 00004000) 8 MB
P15: protect2 (000A7C40, 000043C0) 8.469 MB
P16: seccfg (000AC000, 00004000) 8 MB
P17: persist (000B0000, 00018000) 48 MB
P18: sec1 (000C8000, 00001000) 2048 KB
P19: proinfo (000C9000, 00001800) 3072 KB
P20: md1img (000CA800, 00032000) 100 MB
P21: spmfw (000FC800, 00000800) 1024 KB
P22: scp1 (000FD000, 00000800) 1024 KB
P23: scp2 (000FD800, 00000800) 1024 KB
P24: sspm_1 (000FE000, 00000800) 1024 KB
P25: sspm_2 (000FE800, 00000800) 1024 KB
P26: gz1 (000FF000, 00008000) 16 MB
P27: logo (00100000, 00048000) 144 MB
P28: gz2 (00107000, 00008000) 16 MB
P29: nvram (0010F000, 00020000) 64 MB
P30: lk (0012F000, 00000800) 1024 KB
P31: lk2 (0012F800, 00000800) 1024 KB
P32: boot (00130000, 00010000) 32 MB
P33: dtbo (00148000, 00008000) 16 MB
P34: tee1 (00150000, 00002800) 5 MB
P35: tee2 (00152800, 00005800) 11 MB
P36: odm (00158000, 00080000) 256 MB
P37: vendor (001D8000, 001CC000) 920 MB
P38: system (003A4000, 00960000) 4.688 GB
P39: cache (00D04000, 000D8000) 432 MB
P40: userdata (00DDC000, 02C447DF) 22.13 GB
P41: otp (03A207DF, 00015800) 43 MB
P42: flashinfo (03A35FDF, 00008000) 16 MB
Erasing partition userdata... error!
ERROR[013]: Erase error.
Attempting to erase...
error!
error!
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 3.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
ERROR[001]: Can not connect. No target device present.
Model Settings:
Interface : eMMC
Voltage : 3.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Model Settings:
Interface : eMMC
Voltage : 3.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Model Settings:
Interface : eMMC
Voltage : 3.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Model Settings:
Interface : eMMC
Voltage : 3.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 8Bit)
Boot ACK : No boot acknowledge sent (default)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QD63MB_24_06_2020_16_01_25.bin.
Connect successful.
P05: opporeserve2 (00014C40, 00020000) 64 MB
P27: gz2 (00107000, 00008000) 16 MB
P28: nvram (0010F000, 00020000) 64 MB
P29: lk (0012F000, 00000800) 1024 KB
P30: lk2 (0012F800, 00000800) 1024 KB
P31: boot (00130000, 00010000) 32 MB
P32: logo (00140000, 00008000) 16 MB
Done.
Erasing is finished.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 3.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 8Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QD63MB_24_06_2020_16_03_20.bin.
Connect successful.
Writing EXT_CSD succesfully complete!
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 3.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 8Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QD63MB_24_06_2020_16_03_37.bin.
Connect successful.
Disconnected.
i have to write its backup EXD_CSD to revive the phone ..
why software touch this area ????
Old 06-24-2020, 13:29   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,034
Hello.
There are no any issue with Software! Please, setl Voltage to 1.88 and add resistor from D0 to VCCQ & CMD to VCCQ
The Following User Says Thank You to Medusa Box For This Useful Post:
Old 07-01-2020, 09:23   #3 (permalink)
starkrimes's Avatar
Member: 1191316
Thanks Meter: 692
to work with oppo mtk devices with isp you need to do like what medusa pro said
and use max length of wires 5 cm and they must same exactly length
Old 07-01-2020, 11:43   #4 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 475
Not satisfied with any of answers
i asked totally different question ..
why Partition config and Boot partition changes on some phones without doing anything to them ?
Page generated in 0.30310 seconds with 7 queries
