12-24-2022, 13:22 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | Help me change boot mode [Answered] Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled BUT I WANT TO CHANGE RST_N FUNCTION TO THIS , from a working phone Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) |
01-03-2023, 11:04 | #4 (permalink) | |
Insane Poster Join Date: Apr 2007 Location: Poland, Warsaw
Member: 487336 Status: Offline Thanks Meter: 33 | Quote:
what did you do with the phone??? did you upload the dump? or what?? Do you have VCC and VCCQ connected or are you powering from USB??? | |
01-03-2023, 11:12 | #5 (permalink) | |
Member: 1507693 Status: Offline Thanks Meter: 131 | Quote:
I wrote full dump from working phone, I wrote Boot1, Boot2, CSD from working phone , but no download mode coming when press Vol Up and Down with USB cable | |
01-03-2023, 11:48 | #6 (permalink) | |
maybe you had u2 firmware and you uploaded u1. here i have dump u2 https://drive.google.com/file/d/1X7y...TttCxOsAT/view or repair by mtk utility https://drive.google.com/file/d/1mwJ...ew?usp=sharing | |
