07-11-2020, 01:31 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 389266 Status: Offline Thanks Meter: 17 | Help lg k430t boot repair [Answered] for pack of Spanish language, flash the k430t with octopus and surprise. phone death ****************************** Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : K430 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_K430_EMMC_BY_AGRSAT.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC FE12MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100464531324D420DD7596A352489 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FE12MB Product revision : 0.13 Product serial number : (hex) D7596A35 Manufacturing date : 02/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/FE12MB_10_07_2020_11_57_17.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: misc2 (00001C00, 00004000) 8 MB P03: ftm (00005C00, 00004000) 8 MB P04: nvram (00009C00, 00002800) 5 MB P05: protect1 (0000C400, 00005000) 10 MB P06: protect2 (00011400, 00005000) 10 MB P07: lk (00016400, 00001000) 2048 KB P08: lkbak (00017400, 00001000) 2048 KB P09: laf (00018400, 0000E000) 28 MB P10: para (00026400, 00000400) 512 KB P11: boot (00026800, 00008000) 16 MB P12: recovery (0002E800, 00008000) 16 MB P13: recoverybak (00036800, 00008000) 16 MB P14: logo (0003E800, 00004000) 8 MB P15: lo_bak_go (00042800, 00004000) 8 MB P16: expdb (00046800, 00005000) 10 MB P17: seccfg (0004B800, 00000400) 512 KB P18: oemkeystore (0004BC00, 00001000) 2048 KB P19: secro (0004CC00, 00003000) 6 MB P20: keystore (0004FC00, 00004000) 8 MB P21: tee1 (00053C00, 00002800) 5 MB P22: tee2 (00056400, 00002800) 5 MB P23: eksst (00058C00, 00000400) 512 KB P24: encrypt (00059000, 00000400) 512 KB P25: persist_lg (00059400, 00004000) 8 MB P26: mpt (0005D400, 0000B000) 22 MB P27: persistent (00068400, 00001000) 2048 KB P28: lgfota (00069400, 00005000) 10 MB P29: cust (0006E400, 00032000) 100 MB P30: rct (000A0400, 00000800) 1024 KB P31: factory (000A0C00, 0000E000) 28 MB P32: persist (000AEC00, 00018000) 48 MB P33: efuse (000C6C00, 00000400) 512 KB P34: frp (000C7000, 00000800) 1024 KB P35: nvdata (000C7800, 00010800) 33 MB P36: system (000D8000, 005E4000) 3016 MB P37: cache (006BC000, 00064000) 200 MB P38: OP (00720000, 00080000) 256 MB P39: userdata (007A0000, 01576C00) 10.73 GB P40: flashinfo (01D16C00, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FE12MB_nvdata_0xc7800_0x10800_10_07_2020_11_57_17. bin file... Reading. Please wait... Done. Elapsed time 00:00:14 SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found ---------------------------------------------------------------Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_K430_EMMC_BY_AGRSAT.srf". Write data verification is enabled. Writing BOOT1 partition... Done. Writing BOOT2 partition... Done. Writing GPT partition... Done. Writing proinfo partition... Done. Writing misc2 partition... Done. Writing ftm partition... Done. Writing nvram partition... Done. Writing protect1 partition... Done. Writing protect2 partition... Done. Writing lk partition... Done. Writing lkbak partition... Done. Writing laf partition... Done. Writing para partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing recoverybak partition... Done. Writing logo partition... Done. Writing lo_bak_go partition... Done. Writing expdb partition... Done. Writing seccfg partition... Done. Writing oemkeystore partition... Done. Writing secro partition... Done. Writing keystore partition... Done. Writing tee1 partition... Done. Writing tee2 partition... Done. Writing eksst partition... Done. Writing encrypt partition... Done. Writing persist_lg partition... Done. Writing mpt partition... Done. Writing persistent partition... Done. Writing lgfota partition... Done. Writing cust partition... Done. Writing rct partition... Done. Writing factory partition... Done. Writing persist partition... Done. Writing efuse partition... Done. Writing frp partition... Done. Writing nvdata partition... Done. Writing cache partition... Done. Writing OP partition... Done. Writing flashinfo partition... Done. Smart Repair is successfully complete. SW: 2.1.1; FW: 1.24. Disconnected. ************************************************** ****** phone totally follow death help friends team luck |
07-13-2020, 15:41 | #4 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Quote:
As i can see Smart Repair operation was completed successfully, does your device still can't boot into Download Mode manually? | |
07-14-2020, 11:39 | #6 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | do repair via factory repair tab and use latest kdz firmware for k430t |
The Following 3 Users Say Thank You to starkrimes For This Useful Post: |
07-19-2020, 03:26 | #8 (permalink) |
Member: 389266 Status: Offline Thanks Meter: 17 | Model Settings: Interface : eMMC Brand : LG Model : K430 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_K430_EMMC_BY_AGRSAT.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC FE12MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100464531324D420DD7596A352489 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FE12MB Product revision : 0.13 Product serial number : (hex) D7596A35 Manufacturing date : 02/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/FE12MB_15_07_2020_17_48_21.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: misc2 (00001C00, 00004000) 8 MB P03: ftm (00005C00, 00004000) 8 MB P04: nvram (00009C00, 00002800) 5 MB P05: protect1 (0000C400, 00005000) 10 MB P06: protect2 (00011400, 00005000) 10 MB P07: lk (00016400, 00001000) 2048 KB P08: lkbak (00017400, 00001000) 2048 KB P09: laf (00018400, 0000E000) 28 MB P10: para (00026400, 00000400) 512 KB P11: boot (00026800, 00008000) 16 MB P12: recovery (0002E800, 00008000) 16 MB P13: recoverybak (00036800, 00008000) 16 MB P14: logo (0003E800, 00004000) 8 MB P15: lo_bak_go (00042800, 00004000) 8 MB P16: expdb (00046800, 00005000) 10 MB P17: seccfg (0004B800, 00000400) 512 KB P18: oemkeystore (0004BC00, 00001000) 2048 KB P19: secro (0004CC00, 00003000) 6 MB P20: keystore (0004FC00, 00004000) 8 MB P21: tee1 (00053C00, 00002800) 5 MB P22: tee2 (00056400, 00002800) 5 MB P23: eksst (00058C00, 00000400) 512 KB P24: encrypt (00059000, 00000400) 512 KB P25: persist_lg (00059400, 00004000) 8 MB P26: mpt (0005D400, 0000B000) 22 MB P27: persistent (00068400, 00001000) 2048 KB P28: lgfota (00069400, 00005000) 10 MB P29: cust (0006E400, 00032000) 100 MB P30: rct (000A0400, 00000800) 1024 KB P31: factory (000A0C00, 0000E000) 28 MB P32: persist (000AEC00, 00018000) 48 MB P33: efuse (000C6C00, 00000400) 512 KB P34: frp (000C7000, 00000800) 1024 KB P35: nvdata (000C7800, 00010800) 33 MB P36: system (000D8000, 005E4000) 3016 MB P37: cache (006BC000, 00064000) 200 MB P38: OP (00720000, 00080000) 256 MB P39: userdata (007A0000, 01576C00) 10.73 GB P40: flashinfo (01D16C00, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FE12MB_nvdata_0xc7800_0x10800_15_07_2020_17_48_21. bin file... Reading. Please wait... Done. Elapsed time 00:00:14 SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found ---------------------------------------------------------------Opening C:/Users/DARIO MASTER/Desktop/K430T10b_00_0805.kdz file... Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition preloader... Done. Switched to user area. Writing partition pgpt... Done. Writing partition lk... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition logo... Done. Writing partition secro... Done. Writing partition tee1... Done. Writing partition tee2... Done. Writing partition cust... Done. Writing partition factory... Done. Writing partition efuse... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition OP... Done. Writing partition OP... Done. Writing partition sgpt... Done. Writing is finished. SW: 2.1.1; FW: 1.24. Disconnected. ************************** Phone no power on , death luck |
