07-19-2020, 07:31 | #1 (permalink) |
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | How to use Preset of Boot Configuration [Answered] And also there is RST_n_Enable always disabled. Guide me how to use Boot configuration by core option. |
07-19-2020, 17:54 | #2 (permalink) | |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,100 | Quote:
Yours 1st question is the option "RST_n_Enable always disabled." Answer is: RST_n_Function value set only One time Possible, if RST_n_Function value already Permanently Enabled then You can't change this value, so here this option is always showing not sellected by Core. Yours 2nd Question is "Guide me how to use Boot configuration by core option." Answer is: if RST_n_Function value is Disabled & Need to set value Enabled then just manually write correct EXT_CSD file. [NOTE: if RST_n_Function value is Enabled on Samsung eMMC then Disable possible after Factory Format (Supported Rev. Only)] Last edited by Pijush Das; 07-19-2020 at 17:59. | |
The Following 2 Users Say Thank You to Pijush Das For This Useful Post: |
07-22-2020, 16:31 | #3 (permalink) | |
Member: 2289628 Status: Offline Thanks Meter: 226 | Quote:
But why other boxes do these preset write functions without any hesitation Example:- Easy Jtag Plus UFI | |
The Following 2 Users Say Thank You to hafiz4saqib For This Useful Post: |
11-16-2020, 09:01 | #4 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. We've that option also, looks attentive eMMC services "Factory Format" |
The Following User Says Thank You to Medusa Box For This Useful Post: |
