07-06-2013, 16:29 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Austria Age: 45
Member: 57712 Status: Offline Sonork: 1010 Thanks Meter: 49 | HTC Desire C (PL01100) i have phone working need change CID no detect the phone Welcome to Medusa Box Software version 1.8.8 Selected device model: HTC Desire C (PL01100) Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. ERROR[045]: Scan chain is too long or damaged. Scanned TAP ID's list: 0x000000C1 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000007 0x00000000 MI: Medusa JTAG init failed. |
07-08-2013, 06:16 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Most likely, You soldered some Jtag wires incorrectly. Please check soldering of all Jtag wires and try again. Don't forget to fully charge phone's battery. To power your device use fully charged battery and USB cable. We have tried with our device and Connect was successfully: Quote:
08-15-2013, 09:36 | #4 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Hungary, near Miskolc Age: 48
Member: 19327 Status: Offline Thanks Meter: 45 | I have the same problem ... I would like to "repair imei" on a working phone , but can't connect to the board .. Yes,i checked the soldered wires - i tried two different wires -as you can see in the pictures in my comment.(that you couldn't see : the reset wire is soldered too on the backside) Yes, the battery is fully charged,and i use charger or usb wire too. By RTCK selection - the result is the same,like the first poster(expect the VREF -it is 1.75V) By 100kHz manual mode the result is the following : Selected device model: HTC Desire C (PL01100) Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. Detected TAP ID: 106010E1, IR Length = 4. JTAG speed : 100 KHz. VREF level : 1.75 V CPU : Qualcomm MSM7225A Core ID : 106010E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Could you suggest me any other thing ,that i have never tried ? http://forum.gsmhosting.com/vbb/atta...1&d=1376555543 Last edited by clone; 08-15-2013 at 09:42. |
08-15-2013, 11:09 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please try to connect your phone in Auto Mode (select "Manufacturer: Auto", "Device model: MSM72xx/MSM76xx", "JTAG speed: Auto (RTCK)") and post here log. Also please use both - fully charged battery and USB cable at the same time for powering the device. |
08-15-2013, 11:18 | #6 (permalink) |
Member: 19327 Status: Offline Thanks Meter: 45 | Unfortunately it is the same situation .. And of course i try it with usb and battery power at the same time. It isn't my first jtag "project" http://forum.gsmhosting.com/vbb/atta...1&d=1376561833 In RTCK mode : Selected device model: Qualcomm MSM72xx/MSM76xx Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision C. MI: Medusa JTAG init failed. In : 100 kHz manual mode : |
08-16-2013, 10:10 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Also please try to connect the phone by the next way: 1. Disconnect phone's battery, mictro USB cable and Jtag wires. 2. Connect soldered Jtag wires to Box and press "Connect" button in Software. 3. Connect fully charged battery and press "Power On" button. 4. If the phone not connects, You can (should) try to connect it a few times by the same way. Currently we have no this device in our hands, so we cant check whether can be the problem with your device exactly. We have tested now on HTC Explorer (with the same CPU) and the mentioned above connectin procedure works OK. |
08-16-2013, 10:25 | #8 (permalink) |
Member: 19327 Status: Offline Thanks Meter: 45 | I have done all steps but the result is exactly the same Not the first phone,that i couldn't done with the medusa - tomorrow i'll make one more try with an other PC , but today i have no more time for it . |
11-09-2013, 09:04 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please post here full software log and describe all of your actions step by step how You connect the device. |
11-10-2013, 03:06 | #11 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Venezuela
Member: 594580 Status: Offline Thanks Meter: 157 | Quote:
Selected device model: Auto Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision C. Detected TAP ID: 106010E1, IR Length = 4. JTAG speed : 100 KHz. VREF level : 1.74 V CPU : Qualcomm MSM7225A Core ID : 106010E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Selected device model: Auto Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision C. ERROR[045]: Scan chain is too long or damaged. Scanned TAP ID's list: 0x000010E1 0x00000000 0x00000000 0x00000000 0x0000001F 0x00000000 0x0000000F 0x0000000F MI: Medusa JTAG init failed. Ive tried HTC Decire C model and Auto model and same result, Ive tried diferent Jtag speed and only with 100 Khz I get this: Selected device model: Auto Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision C. Detected TAP ID: 106010E1, IR Length = 4. JTAG speed : 100 KHz. VREF level : 1.74 V CPU : Qualcomm MSM7225A Core ID : 106010E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. But if I select directly CPU type Qualcom MSM72xx/MSM76xx and 100 Khz speed I get this: Selected device model: Qualcomm MSM72xx/MSM76xx Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision C. Detected TAP ID: 106010E1, IR Length = 4. JTAG speed : 100 KHz. VREF level : 1.74 V CPU : Qualcomm MSM7225A Core ID : 106010E1 Storage Device: Hynix eMMC XINYH Device ID : 00904A01 Block size : 512 bytes Blocks : 4702208 Storage size : 2296 Mb Connect successful. But there are not options for repair IMEI Sir.. What can I do next?? | |
The Following User Says Thank You to richiricherd For This Useful Post: |
11-10-2013, 08:16 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. To make Repair IMEI, You need to connect the device as HTC Desire C (PL01100). Don't forget to fully charge phone's battery. To power your device use fully charged battery and USB cable. To connect the device try to do the next steps: 1. Disconnect phone's battery, mictro USB cable and Jtag wires. 2. Connect soldered Jtag wires to Box and press "Connect" button in Software. 3. Connect fully charged battery and press "Power On" button. 4. If the phone not connects, You can (should) try to connect it a few times by the same way. |
11-13-2013, 21:31 | #13 (permalink) |
Member: 594580 Status: Offline Thanks Meter: 157 | Ok Sir I think that I found the problem, and Im sorry cause my mistake, this phone is HTC Desire C ( PL01130 ) not ( PL01100 ) as you support that Desire C only.. Im very ashame sir.. |
01-17-2014, 19:41 | #14 (permalink) |
Member: 594580 Status: Offline Thanks Meter: 157 | Sir please add support for Desire C PL01130, I think is equal than PL01100 but your software refuses it because not exactly same number but same hardware.. Only diference in hardware is 3G Bands frecuency.. |
11-30-2014, 16:01 | #15 (permalink) | |
Insane Poster Join Date: Dec 2010 Location: Venezuela
Member: 1473248 Status: Offline Sonork: Tecnico Thanks Meter: 7 | Quote:
A doubt desiree htc PL01130, I selected the model of octoplus jtag PL01100 to repair imei? Una duda, el htc desiree PL01130, debo de seleccionar el modelo en jtag de octoplus PL01100 para poder reparar el imei? | |
