Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 07-31-2021, 02:08   #1 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 302
I need help to connect nokia 5.4 [Answered]
hi, i'm trying to connect a nokia 5.4 but i can`t, sometimes i get conection, but i can´t manage partitions, or backup.
Welcome to Medusa Pro Software version 2.2.2.
Started.
Reader #0: Alcor Micro USB Smart Card Reader 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage   : 1.8V
Bus Mode  : 1 bit
Bus speed : Auto
Connecting...
ERROR[001]: Can not connect. No target device present.
Model Settings:
Interface : eMMC
Voltage   : 2.0V
Bus Mode  : 1 bit
Bus speed : 10 MHz
Connecting...
Model Settings:
Interface : eMMC
Voltage   : 2.2V
Bus Mode  : 1 bit
Bus speed : 10 MHz
Model Settings:
Interface : eMMC
Voltage   : 2.2V
Bus Mode  : 1 bit
Bus speed : 13 MHz
Connecting...
Device       : Hynix eMMC hDEaP3
Page size    : 512 B
Block size   : 512 B
Block count  : 244285440
Size         : 116.48 GB (119280.00 MB)
CID Info
CID                   : 90014A68444561503303101CACFE97E3
Manufacturer ID       : 0X90
Device/BGA            : BGA (Discrete embedded)
OEM/Application ID    : 0X4A
Product name          : hDEaP3
Product revision      : 0.3
Product serial number : (hex) 101CACFE
Manufacturing date    : 09/2020
CSD Info
CSD                   : D02700328F5903FFFFFFFFEF8E400043
CSD structure         : CSD version No. 1.2
SPEC version          : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
                        4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed            : 26 MHz
READ block length     : 512 Bytes
WP group enable       : YES
PERM_WRITE_PROTECT    : NO
TMP_WRITE_PROTECT     : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size      : 512 Kbytes
Boot1 size            : 4096 Kbytes
Boot2 size            : 4096 Kbytes
RPMB size             : 16384 Kbytes
Partition config      : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK              : No boot acknowledge sent (default)
Boot bus conditions   : (0x00) 00000000
Boot bus width        : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions   : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode             : Use single data rate + backward compatible timings in boot operation (default)
RST_n function        : (0x01) RST_n signal is permanently enabled
Partitioning support  : Device supports partitioning features
Enhanced attribute    : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 40714240 Kbytes
Partitions attribute  : 0x0
Part setting completed: 0x0
GP partition 1 size   : 0 b
GP partition 2 size   : 0 b
GP partition 3 size   : 0 b
GP partition 4 size   : 0 b
Enhanced area size    : (0x0) 0 b
Enhanced area start   : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hDEaP3_30_07_2021_19_40_58.bin.
Connect successful.
SW: 2.2.2; FW: 1.24.
Searching Android build info...
Not found
Disconnected.
Model Settings:
Interface : eMMC
Voltage   : 2.8V
Bus Mode  : 1 bit
Bus speed : 13 MHz
Connecting...
Page size    : 512 B
Block size   : 512 B
CID Info
CSD Info
TRAN speed            : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hDEaP3_30_07_2021_19_41_17.bin.
Connect successful.
Not found
Partition table was not found.
Disconnected.
Model Settings:
Interface : eMMC
Voltage   : 3.2V
Bus Mode  : 1 bit
Bus speed : 13 MHz
Connecting...
Model Settings:
Interface : eMMC
Voltage   : 2.8V
Bus Mode  : 1 bit
Bus speed : 13 MHz
Connecting...
Page size    : 512 B
Block size   : 512 B
CID Info
CSD Info
TRAN speed            : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hDEaP3_30_07_2021_19_41_47.bin.
Connect successful.
Model Settings:
Interface : eMMC
Voltage   : 2.0V
Bus Mode  : 1 bit
Bus speed : 13 MHz
Connecting...
Page size    : 512 B
Block size   : 512 B
CID Info
CSD Info
TRAN speed            : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hDEaP3_30_07_2021_19_42_17.bin.
Connect successful.
Model Settings:
Interface : eMMC
Voltage   : 2.2V
Bus Mode  : 1 bit
Bus speed : 10 MHz
Connecting...
Model Settings:
Interface : eMMC
Voltage   : 3.2V
Bus Mode  : 1 bit
Bus speed : 20 MHz
Connecting...
Model Settings:
Interface : eMMC
Voltage   : 3.2V
Bus Mode  : 1 bit
Bus speed : 20 MHz
Connecting...
Model Settings:
Interface : eMMC
Voltage   : 3.2V
Bus Mode  : 1 bit
Bus speed : 20 MHz
Connecting...
Model Settings:
Interface : eMMC
Voltage   : 2.2V
Bus Mode  : 1 bit
Bus speed : 13 MHz
Connecting...
Model Settings:
Interface : eMMC
Voltage   : 1.8V
Bus Mode  : 1 bit
Bus speed : 4 MHz
Connecting...
Model Settings:
Interface : eMMC
Voltage   : 1.8V
Bus Mode  : 1 bit
Bus speed : 4 MHz
Connecting...
Model Settings:
Interface : eMMC
Voltage   : 2.4V
Bus Mode  : 1 bit
Bus speed : 13 MHz
Connecting...
i'm using this pinout and usb conecction for voltage
[IMG][/IMG]
i've seen this pinout works for other tool, is there anything else i should do?
File Type: jpg nokia_3.4_y 5.4_isp.jpg (157 Bytes, 378 views)
Old 07-31-2021, 07:47   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,358
Hello.
Thanks for your feedback. We will share this information with our developers and they will verify it.
Then we will try to give you an answer to your question.
The Following User Says Thank You to Medusa Box For This Useful Post:
Old 08-02-2021, 08:12   #3 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 26,880
Hello.
We recommend that when connecting the eMMC via ISP to supply power (VCC, VCCQ) from the box.
This allows you to work stably with eMMC and not damage the CPU pins.
The recommended scheme of connection of eMMC on ISP as on a picture
The Following User Says Thank You to Octopus box For This Useful Post:
Old 08-02-2021, 23:55   #4 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 302
Originally Posted by Octopus box View Post
Hello.
i measured and found the vcc and vccq pinouts, i connected without usb power and i still have the same problem, sometimes it connects, sometimes it doesn´t and whenever it connects i still can`t partition manager or backup.
my goal is to factory reset and frp this device but i'm facing this issue.
Old 08-03-2021, 06:58   #5 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,358
Please, post here full software connecting log and photo where you connect the phone.
Old 12-23-2021, 10:57   #6 (permalink)
zaskar's Avatar
Member: 60746
Thanks Meter: 54
hi there
is there a possible to remove user code
there is only reset frp option
ps.
pinout for nokia 5.4 is ok - connected wo problems
Connecting...
Device : Samsung eMMC DP6DAB
Page size : 512 B
Block size : 512 B
Block count : 122142720
Size : 58.24 GB (59640.00 MB)
CID Info
CID : 15010044503644414203F8B49094A7ED
Manufacturer ID : 0X15
OEM/Application ID : 0X00
Product name : DP6DAB
Product serial number : (hex) F8B49094
Manufacturing date : 10/2020
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Max enhanced data size: 20357120 Kbytes
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DP6DAB_23_12_2021_10_38_44.bin.
Connect successful.
SW: 2.2.3.1; FW: 1.24.
P00: GPT (00000000, 00020000) 64 MB
P01: xbl_a (00020000, 00001C00) 3584 KB
P02: xbl_b (00021C00, 00001C00) 3584 KB
P03: xbl_config_a (00040000, 00000100) 128 KB
P04: xbl_config_b (00040100, 00000100) 128 KB
P05: tz_a (00060000, 00002000) 4 MB
P06: tz_b (00080000, 00002000) 4 MB
P07: rpm_a (000A0000, 00000400) 512 KB
P08: rpm_b (000C0000, 00000400) 512 KB
P09: hyp_a (000E0000, 00000400) 512 KB
P10: hyp_b (00100000, 00000400) 512 KB
P11: keymaster_a (00120000, 00000400) 512 KB
P12: keymaster_b (00120400, 00000400) 512 KB
P13: cmnlib_a (00120800, 00000400) 512 KB
P14: cmnlib64_a (00120C00, 00000400) 512 KB
P15: cmnlib_b (00121000, 00000400) 512 KB
P16: cmnlib64_b (00121400, 00000400) 512 KB
P17: mdtpsecapp_a (00121800, 00002000) 4 MB
P18: mdtpsecapp_b (00123800, 00002000) 4 MB
P19: mdtp_a (00125800, 00010000) 32 MB
P20: mdtp_b (00135800, 00010000) 32 MB
P21: modem_a (00145800, 0005A000) 180 MB
P22: modem_b (0019F800, 0005A000) 180 MB
P23: dsp_a (001F9800, 00010000) 32 MB
P24: dsp_b (00209800, 00010000) 32 MB
P25: abl_a (00219800, 00000800) 1024 KB
P26: abl_b (0021A000, 00000800) 1024 KB
P27: ddr (0021A800, 00000800) 1024 KB
P28: bluetooth_a (0021B000, 00000800) 1024 KB
P29: bluetooth_b (0021B800, 00000800) 1024 KB
P30: ssd (00220000, 00000010) 8 KB
P31: imagefv_a (00220010, 00001000) 2048 KB
P32: imagefv_b (00221010, 00001000) 2048 KB
P33: uefisecapp_a (00222010, 00001000) 2048 KB
P34: uefisecapp_b (00223010, 00001000) 2048 KB
P35: persist (00224010, 00010000) 32 MB
P36: metadata (00234010, 00008000) 16 MB
P37: misc (0023C010, 00000800) 1024 KB
P38: keystore (0023C810, 00000400) 512 KB
P39: devcfg_a (0023CC10, 00000100) 128 KB
P40: devcfg_b (0023CD10, 00000100) 128 KB
P41: featenabler_a (0023CE10, 00000100) 128 KB
P42: featenabler_b (0023CF10, 00000100) 128 KB
P43: qupfw_a (0023D010, 00000080) 64 KB
P44: qupfw_b (0023D090, 00000080) 64 KB
P45: frp (0023D110, 00000400) 512 KB
P46: rawdump (0023D510, 00040000) 128 MB
P47: dip (00280000, 00000800) 1024 KB
P48: apdp (002A0000, 00000200) 256 KB
P49: spunvm (002A0200, 00004000) 8 MB
P50: splash_a (002A4200, 00010520) 32.64 MB
P51: splash_b (002B4720, 00010520) 32.64 MB
P52: limits (002E0000, 00000008) 4 KB
P53: toolsfv (002E0008, 00000800) 1024 KB
P54: logfs (00300000, 00004000) 8 MB
P55: cateloader (00304000, 00001000) 2048 KB
P56: logdump (00305000, 00020000) 64 MB
P57: vbmeta_a (00340000, 00000080) 64 KB
P58: vbmeta_b (00340080, 00000080) 64 KB
P59: storsec (00340100, 00000100) 128 KB
P60: multiimgoem (00340200, 00000040) 32 KB
P61: multiimgqti (00340240, 00000040) 32 KB
P62: secdata (00340280, 00000032) 25 KB
P63: catefv (003402B8, 00000400) 512 KB
P64: catecontentfv (003406B8, 00000800) 1024 KB
P65: uefivarstore (00340EB8, 00000400) 512 KB
P66: modemst1 (00360000, 00001000) 2048 KB
P67: modemst2 (00361000, 00001000) 2048 KB
P68: fsg (00380000, 00001000) 2048 KB
P69: fsc (003A0000, 00000100) 128 KB
P70: msadp (003A0100, 00000200) 256 KB
P71: proinfo (003A0300, 00000800) 1024 KB
P72: fsgall (003A0B00, 00002000) 4 MB
P73: private (003A2B00, 00000800) 1024 KB
P74: reserve (003A3300, 00000800) 1024 KB
P75: reserve2 (003A3B00, 00000800) 1024 KB
P76: devinfo (003C0000, 00000008) 4 KB
P77: elabel_a (003E0000, 00028000) 80 MB
P78: elabel_b (00408000, 00028000) 80 MB
P79: simlock (00430000, 00020000) 64 MB
P80: imeilock (00450000, 00020000) 64 MB
P81: boot_a (00470000, 00030000) 96 MB
P82: boot_b (004A0000, 00030000) 96 MB
P83: dtbo_a (004D0000, 0000C000) 24 MB
P84: dtbo_b (004DC000, 0000C000) 24 MB
P85: vbmeta_system_a (00500000, 00000080) 64 KB
P86: vbmeta_system_b (00500080, 00000080) 64 KB
P87: recovery_a (00500100, 00030000) 96 MB
P88: recovery_b (00530100, 00030000) 96 MB
P89: super (00580000, 01000000) 8 GB
P90: userdata (01580000, 05EFBFDF) 47.49 GB
Backuping modemst1 partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DP6DAB_modemst1_0x360000_0x1000_23_12_2021_10_38_4 4.bin file...
Reading. Please wait... Done.
Elapsed time 00:00:00
Backuping modemst2 partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DP6DAB_modemst2_0x361000_0x1000_23_12_2021_10_38_4 4.bin file...
Backuping fsg partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DP6DAB_fsg_0x380000_0x1000_23_12_2021_10_38_44.bin file...
Ok
Disk/Image size : 8f800000 bytes
Device sector size : 512 bytes
Partition offset : 5767168
Number of sectors : 16777216
Device Manufacturer : HMD Global
Build ID : RKQ1.210303.002
Display Build ID : 00WW_2_120
Release ID : 11
Device Model : Nokia 5.4
Device Name : DoctorDoom_00WW
Architecture ABI : arm64-v8a
Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi
Build Description 2 : 00WW_2_120
Partition table has been found on device.
Erasing. Please wait...
Erasing partition frp... Done.
Erasing is finished.
Disconnected.
The Following 2 Users Say Thank You to zaskar For This Useful Post:
Old 12-23-2021, 12:51   #7 (permalink)
zaskar's Avatar
Member: 60746
Thanks Meter: 54
JOB DONE
Succ removed screen lock and frp
Old 01-22-2022, 21:56   #8 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,270
Hi, I have same issue it do not read device partitions... please any help
The Following User Says Thank You to Shensohau For This Useful Post:
Old 01-24-2022, 12:23   #9 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,358
Hello.
Pleas,e post here full Software log of connect operation. We'll check it.
Old 01-24-2022, 13:52   #10 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,270
Hi, here is, but I dont know if need extra connections or something the problem is, I could not read partitions:
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 4 bits
Bus speed : 20 MHz
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CID : 90014A6844456150330310740D8E977F
Product serial number : (hex) 10740D8E
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hDEaP3_22_01_2022_16_51_04.bin.
Connect successful.
Old 01-25-2022, 09:18   #11 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,358
Hello.
Try to repeat operation once again using next settings:
  • Bus Mode : 1 bits
  • Bus speed : 12 MHz
Then post here result. We'll check it.
Old 01-25-2022, 22:29   #12 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,270
Hi, with this options works fine thanks.... but need add android tools like wipe user data etc... need focus on a friendly new interface....
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : 12 MHz
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hDEaP3_25_01_2022_17_23_28.bin.
Connect successful.
P90: userdata (01580000, 0D377FDF) 105.7 GB
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hDEaP3_modemst1_0x360000_0x1000_25_01_2022_17_23_2 8.bin file...
Elapsed time 00:00:01
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hDEaP3_modemst2_0x361000_0x1000_25_01_2022_17_23_2 8.bin file...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hDEaP3_fsg_0x380000_0x1000_25_01_2022_17_23_28.bin file...
Ok
Disk/Image size : 1f000000 bytes
Build ID : QKQ1.200719.002
Display Build ID : 00WW_1_180_SP01
Release ID : 10
Build Description 2 : 00WW_1_18A
Backuping FRP data...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FRP_0x23d110_0x400_25_01_2022_17_24_12.bin file...
Removing FRP. Please wait... Done.
Originally Posted by Medusa Box View Post
Hello.
  • Bus Mode : 1 bits
Old 01-26-2022, 11:36   #13 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,270
Hi, now I format user data partition as usual for factory reset and device, just qualcomm mode, possible fix by firmware?
Old 04-08-2022, 19:06   #14 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 302
pinout working fine, changed wires, changed usb cable thanks for support
Model Settings:
Interface : eMMC
Voltage   : 2.2V
Bus Mode  : 1 bit
Bus speed : 12 MHz
Connecting...
Page size    : 512 B
Block size   : 512 B
CID Info
CSD Info
TRAN speed            : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hDEaP3_08_04_2022_12_14_02.bin.
Connect successful.
SW: 2.2.4.2; FW: 1.24.
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hDEaP3_modemst1_0x360000_0x1000_08_04_2022_12_14_02.bin file...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hDEaP3_modemst2_0x361000_0x1000_08_04_2022_12_14_02.bin file...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hDEaP3_fsg_0x380000_0x1000_08_04_2022_12_14_02.bin file...
Ok
Display Build ID      : 00WW_1_300
Release ID            : 10
Build Description 2   : 00WW_1_300
Switched to boot area partition 1.
Added partition BOOT1 to constructor file.
Switched to boot area partition 2.
Added partition BOOT2 to constructor file.
Switched to user area.
Added partition GPT to constructor file.
Added partition xbl_a to constructor file.
Added partition xbl_b to constructor file.
Added partition xbl_config_a to constructor file.
Added partition xbl_config_b to constructor file.
Added partition tz_a to constructor file.
Added partition tz_b to constructor file.
Added partition rpm_a to constructor file.
Added partition rpm_b to constructor file.
Added partition hyp_a to constructor file.
Added partition hyp_b to constructor file.
Added partition keymaster_a to constructor file.
Added partition keymaster_b to constructor file.
Added partition cmnlib_a to constructor file.
Added partition cmnlib64_a to constructor file.
Added partition cmnlib_b to constructor file.
Added partition cmnlib64_b to constructor file.
Added partition mdtpsecapp_a to constructor file.
Added partition mdtpsecapp_b to constructor file.
Added partition mdtp_a to constructor file.
Added partition mdtp_b to constructor file.
Added partition modem_a to constructor file.
Added partition modem_b to constructor file.
Added partition dsp_a to constructor file.
Added partition dsp_b to constructor file.
Added partition abl_a to constructor file.
Added partition abl_b to constructor file.
Added partition ddr to constructor file.
Added partition bluetooth_a to constructor file.
Added partition bluetooth_b to constructor file.
Added partition ssd to constructor file.
Added partition imagefv_a to constructor file.
Added partition imagefv_b to constructor file.
Added partition uefisecapp_a to constructor file.
Added partition uefisecapp_b to constructor file.
Added partition persist to constructor file.
Added partition metadata to constructor file.
Added partition misc to constructor file.
Added partition keystore to constructor file.
Added partition devcfg_a to constructor file.
Added partition devcfg_b to constructor file.
Added partition featenabler_a to constructor file.
Added partition featenabler_b to constructor file.
Added partition qupfw_a to constructor file.
Added partition qupfw_b to constructor file.
Added partition frp to constructor file.
Added partition rawdump to constructor file.
Added partition dip to constructor file.
Added partition apdp to constructor file.
Added partition spunvm to constructor file.
Added partition splash_a to constructor file.
Added partition splash_b to constructor file.
Added partition limits to constructor file.
Added partition toolsfv to constructor file.
Added partition logfs to constructor file.
Added partition cateloader to constructor file.
Added partition logdump to constructor file.
Added partition vbmeta_a to constructor file.
Added partition vbmeta_b to constructor file.
Added partition storsec to constructor file.
Added partition multiimgoem to constructor file.
Added partition multiimgqti to constructor file.
Added partition secdata to constructor file.
Added partition catefv to constructor file.
Added partition catecontentfv to constructor file.
Added partition uefivarstore to constructor file.
Added partition modemst1 to constructor file.
Added partition modemst2 to constructor file.
Added partition fsg to constructor file.
Added partition fsc to constructor file.
Added partition msadp to constructor file.
Added partition proinfo to constructor file.
Added partition fsgall to constructor file.
Added partition private to constructor file.
Added partition reserve to constructor file.
Added partition reserve2 to constructor file.
Added partition devinfo to constructor file.
Added partition elabel_a to constructor file.
Added partition elabel_b to constructor file.
Added partition simlock to constructor file.
Added partition imeilock to constructor file.
Added partition boot_a to constructor file.
Added partition boot_b to constructor file.
Added partition dtbo_a to constructor file.
Added partition dtbo_b to constructor file.
Added partition vbmeta_system_a to constructor file.
Added partition vbmeta_system_b to constructor file.
Added partition recovery_a to constructor file.
Added partition recovery_b to constructor file.
SRF "C:/_Firmwares_NOKIA/newnokia/nokia_5.4/Nokia_5.4.srf" has been installed successfully.
Save to C:/_Firmwares_NOKIA/newnokia/nokia_5.4/mi nokia_5.4 folder...
Reading partition persist...	Done.
Reading partition misc...	Done.
Reading partition frp...	Done.
Reading partition spunvm...	Done.
Reading partition secdata...	Done.
Reading partition modemst1...	Done.
Reading partition modemst2...	Done.
Reading partition fsg...	Done.
Reading partition fsc...	Done.
Reading partition reserve...	Done.
Reading partition reserve2...	Done.
Reading partition devinfo...	Done.
Reading partition simlock...	Done.
Reading partition imeilock...	Done.
Reading is finished.
Erasing partition userdata...	Done.
Disconnected.
Disconnected.
The Following 2 Users Say Thank You to bananin For This Useful Post:
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.33985 seconds with 8 queries
