Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 06-01-2020, 15:08   #1 (permalink)
Member: 1360157
Sonork: 623-221-328
Thanks Meter: 3
Incorrectly creates partitions.[Answered]
I need to restore it, I am flashing it using the vendor, some other partitions are being created, and the phone does not turn on, I did not find the dump.
Model Settings:
Interface : eMMC
Voltage   : 3.2V
Bus Mode  : 4 bits
Bus speed : Auto
Connecting...
Device       : Samsung eMMC BJTD4R
Page size    : 512 B
Block size   : 512 B
Block count  : 61071360
Size         : 29.12 GB (29820.00 MB)
CID Info
CID                   : 150100424A5444345200C111F035657B
Manufacturer ID       : 0X15
Device/BGA            : BGA (Discrete embedded)
OEM/Application ID    : 0X00
Product name          : BJTD4R
Product revision      : 0.0
Product serial number : (hex) C111F035
Manufacturing date    : 06/2018
CSD Info
CSD                   : D02701320F5903FFF6DBFFEF8E40400D
CSD structure         : CSD version No. 1.2
SPEC version          : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
                        4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed            : 26 MHz
READ block length     : 512 Bytes
WP group enable       : YES
PERM_WRITE_PROTECT    : NO
TMP_WRITE_PROTECT     : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size      : 512 Kbytes
Boot1 size            : 4096 Kbytes
Boot2 size            : 4096 Kbytes
RPMB size             : 16384 Kbytes
Partition config      : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 4Bit)
Boot ACK              : Boot acknowledge sent during boot operation Bit
Boot bus conditions   : (0x01) 00000001
Boot bus width        : x4 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions   : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode             : Use single data rate + backward compatible timings in boot operation (default)
RST_n function        : (0x01) RST_n signal is permanently enabled
Partitioning support  : Device supports partitioning features
Enhanced attribute    : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 15261696 Kbytes
Partitions attribute  : 0x0
Part setting completed: 0x0
GP partition 1 size   : 0 b
GP partition 2 size   : 0 b
GP partition 3 size   : 0 b
GP partition 4 size   : 0 b
Enhanced area size    : (0x0) 0 b
Enhanced area start   : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/BJTD4R_01_06_2020_18_03_44.bin.
Connect successful.
SW: 2.1.0; FW: 1.24.
P00: GPT              (00000000, 00002000)	4 MB
P01: bota0            (00002000, 00002000)	4 MB
P02: na               (00004000, 00002000)	4 MB
P03: efs              (00006000, 0000A000)	20 MB
P04: cpefs            (00010000, 00004000)	8 MB
P05: cm               (00014000, 00004000)	8 MB
P06: ??????          (00018000, 000F2000)	484 MB
P07: nad?????         (0001E000, 00000800)	1024 KB
P08: recovery         (00033800, 00013000)	38 MB
P09: b???            (00046800, 00004000)	8 MB
P10: steady           (00061400, 00002000)	4 MB
P11: reserved2        (00063400, 00000C00)	1536 KB
P12: system           (00064000, 007C0000)	3968 MB
P13: cache            (00824000, 0007D000)	250 MB
P14: userdata         (008C9000, 03173000)	24.72 GB
P15: d_fw             (8C8FFF00000000, FF74100100000001)	1.558e+10 GB
P16: ??????           (F0000000010000A, F10000000000F0F2)	30.12 MB
P17: ??????0          (F0000000010000C, F10000000000F0F2)	30.12 MB
P18: ?????            (F0000000010800E, F1000000000FF0E5)	510.1 MB
P19: ???0             (F00000000208002, F0FFFFFFFFFFF0F2)	1.718e+10 GB
P20: ???@             (F00000000208003, F1000000000FF0F1)	510.1 MB
P21: ?????            (F0000000040800A, F1000000002070E7)	1038 MB
P22: ?????????@       (F00000000600001, F1000000000030F1)	6.118 MB
P23: ????             (A078F30F00000000, 60070EF100000001)	9.474e+08 GB
P24: ?                (B078FC0F00000000, 5F870CF100000001)	9.463e+08 GB
P25: ?debug           (B0F8FE0F00000000, 4F8703F100000001)	9.416e+08 GB
Backuping efs partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/BJTD4R_efs_0x6000_0xa000_01_06_2020_18_03_44.bin file...
Reading. Please wait... Done.
Elapsed time 00:00:02
Old 06-01-2020, 15:24   #2 (permalink)
Member: 1360157
Sonork: 623-221-328
Thanks Meter: 3
This pit file.
https://drive.google.com/file/d/1fPq...ew?usp=sharing
Old 06-01-2020, 20:02   #3 (permalink)
starkrimes's Avatar
Member: 1191316
Thanks Meter: 900
which phone is ?
and why you use 3.2v voltage
Page generated in 0.11691 seconds with 8 queries
