06-08-2022, 19:28 | #1 (permalink) |
Freak Poster Join Date: Sep 2017 Location: anywhere
Member: 2754769 Status: Offline Thanks Meter: 276 | problem with a127f and a217f pinout [Answered] Code: Welcome to Medusa Pro Software version 2.2.4.6. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-A217F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-A217F_EMMC_ISP_BY PIJUSH DAS.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-A217F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-A217F_EMMC_ISP_BY PIJUSH DAS.srf Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-A217F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-A217F_EMMC_ISP_BY PIJUSH DAS.srf Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. |
06-09-2022, 08:21 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello Unfortunately, EMMC in ISP mode is not supported for this device. It means that we haven't tried yet to do something with this device. Also, please, send us photo of how did you solder(please, show us phone and box connection). In case, you sure that this pinout is right, you can try to connect pull-up resistors 150 Ohm from VCC to DATA0 and from VCC to CMD. On the other side, if it is not correct, you should find proper pinout. ATTENTIVE!!! it is prohibited to turn on device with this resistor!!! This resistor is only for connection. Before you turn on device, unsolder this resistors!!! |
