Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 05-20-2022, 05:10   #1 (permalink)
Member: 152445
Thanks Meter: 16
Sm-g988b not connect gelo please [Answered]
does not connect, does not detect, would you have the pinout please thank you I am making the connection through the one found by google
Old 05-20-2022, 13:41   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Hello
What connect do you use (EMMC, UFS, USB etc.)?
Also, please, send us software log, where you tried to connect.
Old 05-21-2022, 12:11   #3 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 647
its a ufs . if you using isp pinout use maximum small length wire connection
between chip and isp socket
once more try if connection not successful share connection photo and exe
photo you will must get result
The Following User Says Thank You to saleem5001 For This Useful Post:
Old 05-21-2022, 17:45   #4 (permalink)
Member: 152445
Thanks Meter: 16
g988b
Started.
Reader #0: Alcor Micro USB Smart Card Reader 0
Loading firmware. Please wait... Done.
Selected UFS interface.
Socket detected!
Selected PIN - CONNECTOR.
Model Settings:
Interface : UFS
Gear : PWM Gear 1
Connecting to server. Please wait...
Connection to server successful
Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4)
Connecting in ISP mode... (it may take about 10 seconds)
Connect unsuccessful.
Model Settings:
Interface : UFS
Gear : PWM Gear 2
Model Settings:
Interface : UFS
Gear : PWM Gear 3
Model Settings:
Interface : UFS
Gear : PWM Gear 4
Model Settings:
Interface : UFS
Gear : HS Gear 1
Old 05-21-2022, 18:27   #5 (permalink)
Member: 152445
Thanks Meter: 16
isp
Old 05-22-2022, 11:40   #6 (permalink)
Member: 152445
Thanks Meter: 16
Yes, thanks, I have already changed the cables several times and the same thing happens, it does not detect it
Old 05-24-2022, 20:03   #7 (permalink)
Member: 152445
Thanks Meter: 16
I have tried with different models and no results. some models yes and others no. while in other tools with the same cables it detects it.
I've already shortened it
Old 05-25-2022, 09:43   #8 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Hello
Please, explain how did you connect in more details.
Namely, the sequence.
First, you connected USB and then pressed the ''connect'', or vice versa, first the ''connect'' and then USB?
Old 05-25-2022, 16:08   #9 (permalink)
Member: 152445
Thanks Meter: 16
I have tried different methods connecting USB first then connect or connect then USB and tried connecting vcc and vccq and still the same problem no connection.
with the same connection in other boxes if it detects them
Old 06-06-2022, 08:51   #10 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Share with us your pin connection diagram.
Like this:
"Phone → PIN_CONNECTOR"
  • TX0P → ?
  • TX0N → ?
  • RX0P → ?
  • RX0N → ?
Page generated in 0.21745 seconds with 8 queries
