08-19-2020, 18:31 | #1 (permalink) |
Freak Poster Join Date: Dec 2008 Location: GSM DÜNYASI TEAM.
Member: 923948 Status: Offline Sonork: 100.1655611 Thanks Meter: 35 | SM-J530F repair samsung devices using factory files Error [Solved] Medusa pro 2 program shuts down when boot load is 99% Please help me Octopus support team Welcome to Medusa Pro Software version 2.1.2. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Loading firmware. Please wait... Done. Selected eMMC interface. Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC AJTD4R Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100414A544434520090B6F447540D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : AJTD4R Product revision : 0.0 Product serial number : (hex) 90B6F447 Manufacturing date : 05/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/AJTD4R_19_08_2020_20_17_31.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.2; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: bota0 (00002000, 00002000) 4 MB P02: bota1 (00004000, 00002000) 4 MB P03: efs (00006000, 0000A000) 20 MB P04: cpefs (00010000, 00004000) 8 MB P05: m9kefs1 (00014000, 00002000) 4 MB P06: m9kefs2 (00016000, 00002000) 4 MB P07: m9kefs3 (00018000, 00002000) 4 MB P08: carrier (0001A000, 00000800) 1024 KB P09: param (0001A800, 00004000) 8 MB P10: boot (0001E800, 00010000) 32 MB P11: recovery (0002E800, 00013000) 38 MB P12: ota (00041800, 00004000) 8 MB P13: radio (00045800, 0002C000) 88 MB P14: tombstones (00071800, 00000800) 1024 KB P15: persistent (00072000, 00000400) 512 KB P16: steady (00072400, 00002000) 4 MB P17: reserved2 (00074400, 00003C00) 7.5 MB P18: system (00078000, 00600000) 3072 MB P19: cache (00678000, 00064000) 200 MB P20: hidden (006DC000, 00032000) 100 MB P21: cp_debug (0070E000, 00002800) 5 MB P22: nad_fw (00710800, 0000A000) 20 MB P23: nad_refer (0071A800, 00000800) 1024 KB P24: userdata (0071B000, 0163D000) 11.12 GB Backuping efs partition... Opening C:/Program Files/Medusa Pro Software/Backups/AJTD4R_efs_0x6000_0xa000_19_08_2020_20_17_31.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.1.2; FW: 2.00. ---------------------------------------------------------------Searching Android build info... Not found ---------------------------------------------------------------RPMB: Counter of the successful data write requests = 2. Selected pit file: C:/Users/mesut/Desktop/SM-J530F/J530FXXS7CTG2_9_4File_United Kingdom (BTU)/J5Y17LTE_EUR_OPEN.pit Open file "C:/Users/mesut/Desktop/SM-J530F/J530FXXS7CTG2_9_4File_United Kingdom (BTU)/BL_J530FXXS7CTG2_CL16642474_QB32828996_REV00_user_ low_ship.tar.md5". Open file "C:/Users/mesut/Desktop/SM-J530F/J530FXXS7CTG2_9_4File_United Kingdom (BTU)/AP_J530FXXS7CTG2_CL16642474_QB32828996_REV00_user_ low_ship_meta_OS9.tar.md5". Open file "C:/Users/mesut/Desktop/SM-J530F/J530FXXS7CTG2_9_4File_United Kingdom (BTU)/CP_J530FXXS7CTF1_CL891228_QB16065201_SIGNED.tar.md 5". Open file "C:/Users/mesut/Desktop/SM-J530F/J530FXXS7CTG2_9_4File_United Kingdom (BTU)/CSC_BTU_J530FBTU7CTG1_CL17419960_QB32671741_REV00_ user_low_ship.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOTLOADER... from 0 to 512 Done. |
08-20-2020, 08:15 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello. Please send us firmware which you have used, we will check it. Quote:
The Following User Says Thank You to Octopus support For This Useful Post: |
