Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 08-04-2020, 23:47   #1 (permalink)
Member: 1698387
Thanks Meter: 43
Read photos and contacts [Answered]
Hi
Is it possible to save the pictures and contacts from this device?
Selected BGA 153/169 socket.
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 2.0V
Bus Mode : 8 bits
Bus speed : 50 MHz
Connecting...
Device : Samsung eMMC AJTD4R
Page size : 512 B
Block size : 512 B
Block count : 30777344
Size : 14.68 GB (15028.00 MB)
CID Info
CID : 150100414A5444345200872DF42064D1
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : AJTD4R
Product revision : 0.0
Product serial number : (hex) 872DF420
Manufacturing date : 06/2017
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 16384 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 4Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x01) 00000001
Boot bus width : x4 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7692288 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/AJTD4R_05_08_2020_00_45_22.bin.
Connect successful.
SW: 2.1.1; FW: 1.1.0.
P00: GPT (00000000, 00002000) 4 MB
P01: BOTA0 (00002000, 00002000) 4 MB
P02: BOTA1 (00004000, 00002000) 4 MB
P03: EFS (00006000, 0000A000) 20 MB
P04: CPEFS (00010000, 00004000) 8 MB
P05: m9kefs1 (00014000, 00002000) 4 MB
P06: m9kefs2 (00016000, 00002000) 4 MB
P07: m9kefs3 (00018000, 00002000) 4 MB
P08: CARRIER (0001A000, 00000800) 1024 KB
P09: PARAM (0001A800, 00004000) 8 MB
P10: BOOT (0001E800, 00010000) 32 MB
P11: RECOVERY (0002E800, 00013000) 38 MB
P12: OTA (00041800, 00004000) 8 MB
P13: RADIO (00045800, 0002C000) 88 MB
P14: TOMBSTONES (00071800, 00000800) 1024 KB
P15: PERSISTENT (00072000, 00000400) 512 KB
P16: STEADY (00072400, 00002000) 4 MB
P17: RESERVED2 (00074400, 00003C00) 7.5 MB
P18: SYSTEM (00078000, 00600000) 3072 MB
P19: CACHE (00678000, 00064000) 200 MB
P20: HIDDEN (006DC000, 00032000) 100 MB
P21: CP_DEBUG (0070E000, 00002800) 5 MB
P22: NAD_FW (00710800, 0000A000) 20 MB
P23: NAD_REFER (0071A800, 00000800) 1024 KB
P24: USERDATA (0071B000, 0163C000) 11.12 GB
Backuping EFS partition...
Opening C:/Program Files/Medusa Pro Software/Backups/AJTD4R_EFS_0x6000_0xa000_05_08_2020_00_45_22.bin file...
Reading. Please wait... Done.
Elapsed time 00:00:00
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : ab400000 bytes
Device sector size : 512 bytes
Partition offset : 491520
Number of sectors : 6291456
Device Manufacturer : samsung
Build ID : PPR1.180610.011
Display Build ID : PPR1.180610.011.J530FXXU6C***
Release ID : 9
Device Model : SM-J530F
Device Name : j5y17ltexx
Architecture ABI : armeabi-v7a
Architecture ABI2 : armeabi
Architecture ABI List : armeabi-v7a,armeabi
Build Description : j5y17ltexx-user 9 PPR1.180610.011 J530FXXU6C*** release-keys
---------------------------------------------------------------RPMB: Counter of the successful data write requests = 2.
Old 08-05-2020, 09:56   #2 (permalink)
Octopus support's Avatar
Member: 2891705
Thanks Meter: 2,142
Hello.
Set Bus Mode: 1 bit and Bus speed: 26 MHz then repeat operation once again. Post here results.
Old 08-05-2020, 18:21   #3 (permalink)
Member: 1698387
Thanks Meter: 43
Hello
Ok. The bus mode is on 1bit and speed is 25mhz.
I did the same, no error message come when (read from device) button pressed.
Now where can i find the contacts and pictures?
Thank you for helping!
Started.
Reader #0: FT SCR2000 0
Reader #1: FT SCR2000 1
Reader #2: Generic EMV Smartcard Reader 0
Loading firmware. Please wait... Done.
Selected eMMC interface.
Model Settings:
Interface : eMMC
Voltage : 2.0V
Bus Mode : 1 bit
Bus speed : 25 MHz
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/AJTD4R_05_08_2020_19_05_11.bin.
Connect successful.
SW: 2.1.1; FW: 2.00.
Whole proccess time: .
Opening C:/Program Files/Medusa Pro Software/Backups/AJTD4R_EFS_0x6000_0xa000_05_08_2020_19_05_11.bin file...
Elapsed time 00:00:06
Ok
Release ID : 9
Parsing device...
Image size in bytes: 2873098240
Volume system. Type: GPT. Partitions: 29.
Total: 30756864 sectors.
Warning: Unknown file system type.
Details: Sector offset: 8192, Partition Type: BOTA0
Parse finished.
Whole proccess time: 6 minutes 0 seconds : 32 ms.
Parsing contacts........done. No contacts found.
Parsing SMSs........done. No SMS info found.
Old 08-06-2020, 07:39   #4 (permalink)
Member: 2891705
Thanks Meter: 2,142
Please read full and send us it, we will check where can be the problem.
Old 08-06-2020, 21:54   #5 (permalink)
Member: 252706
Thanks Meter: 6
We have the same problem :/
Old 08-07-2020, 07:27   #6 (permalink)
Member: 2891705
Thanks Meter: 2,142
@firatt022
Hello.
Currently we searching where can be the problem, please sty tuned.
Old 08-07-2020, 16:32   #7 (permalink)
Member: 1698387
Thanks Meter: 43
Hello
i am uploading the full dump in mpt format.
It takes some time because its 11.47gb.
The Following User Says Thank You to Lux_hmobile For This Useful Post:
Old 08-17-2020, 17:27   #8 (permalink)
Member: 1698387
Thanks Meter: 43
Hello
Here is the full dump from the phone.
https://mega.nz/file/o1Yw2QpS#L1Y-Up...-fhu10aQpdR7pM
Old 08-18-2020, 09:28   #9 (permalink)
Member: 2891705
Thanks Meter: 2,142
Hello.
Unfortunately, your User Data is encrypted.
Page generated in 0.22236 seconds with 9 queries
