08-18-2020, 15:59 | #1 (permalink) |
Freak Poster Join Date: Aug 2015
Member: 2439409 Status: Offline Thanks Meter: 104 | j200h after boot repair show mtp usb device only [Answered] Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J200H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J200H_EMMC.srf Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48384734742101A5B994A7A279 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) A5B994A7 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A400013 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H8G4t_18_08_2020_16_39_13.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: WDSP (00006000, 00002000) 4 MB P08: MODEM (00008000, 00004000) 8 MB P09: MODEM2 (0000C000, 00004000) 8 MB P10: TDDSP (00010000, 00002000) 4 MB P11: FOTA_SIG (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: PARAM (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: RESERVED2 (00022000, 00001000) 2048 KB P20: KERNEL (00023000, 00008000) 16 MB P21: RECOVERY (0002B000, 00008000) 16 MB P22: PERSISTENT (00033000, 00000800) 1024 KB P23: persdata (00033800, 00004800) 9 MB P24: CACHE (00038000, 00064000) 200 MB P25: SYSTEM (0009C000, 002EE000) 1500 MB P26: HIDDEN (0038A000, 0000F000) 30 MB P27: userdata (00399000, 00AF0000) 5.469 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/H8G4t_efs_0x15800_0xa000_18_08_2020_16_39_13.bin file... Reading. Please wait... Done. Elapsed time 00:00:07 SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 638976 Number of sectors : 3072000 Device Manufacturer : samsung Device Platform : sc8830 Build ID : LMY48B Display Build ID : LMY48B.J200HXXU0AQK2 Release ID : 5.1.1 Device Model : SM-J200H Device Name : j23gdd Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : j23gdd-user 5.1.1 LMY48B J200HXXU0AQK2 release-keys ---------------------------------------------------------------Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J200H_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing FOTA_SIG partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Writing prodnv partition... Done. Writing RESERVED2 partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Writing PERSISTENT partition... Done. Writing persdata partition... Done. Smart Repair is successfully complete. SW: 2.1.1; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J200H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J200H_EMMC.srf Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48384734742101A5B994A7A279 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) A5B994A7 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A400013 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H8G4t_18_08_2020_16_44_06.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: WDSP (00006000, 00002000) 4 MB P08: MODEM (00008000, 00004000) 8 MB P09: MODEM2 (0000C000, 00004000) 8 MB P10: TDDSP (00010000, 00002000) 4 MB P11: FOTA_SIG (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: PARAM (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: RESERVED2 (00022000, 00001000) 2048 KB P20: KERNEL (00023000, 00008000) 16 MB P21: RECOVERY (0002B000, 00008000) 16 MB P22: PERSISTENT (00033000, 00000800) 1024 KB P23: persdata (00033800, 00004800) 9 MB P24: CACHE (00038000, 00064000) 200 MB P25: SYSTEM (0009C000, 002EE000) 1500 MB P26: HIDDEN (0038A000, 0000F000) 30 MB P27: userdata (00399000, 00AF0000) 5.469 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/H8G4t_efs_0x15800_0xa000_18_08_2020_16_44_06.bin file... Reading. Please wait... Done. Elapsed time 00:00:07 SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 638976 Number of sectors : 3072000 Device Manufacturer : samsung Device Platform : sc8830 Build ID : LMY48B Display Build ID : LMY48B.J200HXXU0AQK2 Release ID : 5.1.1 Device Model : SM-J200H Device Name : j23gdd Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : j23gdd-user 5.1.1 LMY48B J200HXXU0AQK2 release-keys --------------------------------------------------------------- Selected pit file: C:/Users/HP/Downloads/SM-J200H(LMY48B.J200HXXU0APK1-5.1.1-LMY48B)[H8G4t!_21BAE8D6]_Dump Dead Boot Repair/userarea_2GiB.bin Unknown format of input file C:/Users/HP/Downloads/SM-J200H(LMY48B.J200HXXU0APK1-5.1.1-LMY48B)[H8G4t!_21BAE8D6]_Dump Dead Boot Repair/userarea_2GiB.bin! Selected pit file: C:/Users/HP/Downloads/SM-J200H by SH_Rom_BD/SM-J200H by SH_Rom_BD/J23G_EUR_OPEN.pit Open file "C:/Users/HP/Downloads/SM-J200H by SH_Rom_BD/SM-J200H by SH_Rom_BD/BL_J200HXXU0APK1_CL1145746_QB11476181_REV00_user_l ow_ship.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOT... from 0 to 40 Done. Switched to user area. Writing partition SBOOT... from 2000 to C02 Done. Writing partition SBOOT2... from 3000 to C02 Done. Writing partition PARAM... from 14800 to 460 Done. Writing is finished. SW: 2.1.1; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J200H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J200H_EMMC.srf Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48384734742101A5B994A7A279 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) A5B994A7 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A400013 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H8G4t_18_08_2020_16_57_07.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00001000) 2048 KB P20: kernel (00023000, 00008000) 16 MB P21: recovery (0002B000, 00008000) 16 MB P22: persistent (00033000, 00000800) 1024 KB P23: persdata (00033800, 00004800) 9 MB P24: cache (00038000, 00064000) 200 MB P25: system (0009C000, 002EE000) 1500 MB P26: hidden (0038A000, 0000F000) 30 MB P27: userdata (00399000, 00AF5000) 5.479 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/H8G4t_efs_0x15800_0xa000_18_08_2020_16_57_07.bin file... Reading. Please wait... Done. Elapsed time 00:00:07 SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 638976 Number of sectors : 3072000 Device Manufacturer : samsung Device Platform : sc8830 Build ID : LMY48B Display Build ID : LMY48B.J200HXXU0AQK2 Release ID : 5.1.1 Device Model : SM-J200H Device Name : j23gdd Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : j23gdd-user 5.1.1 LMY48B J200HXXU0AQK2 release-keys ---------------------------------------------------------------Disconnected. |
08-19-2020, 09:37 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,128 | Hello. As we can see from the software log everything is fine. Most likely it's HW problem with your phone. |
The Following User Says Thank You to Octopus support For This Useful Post: |
