Go to Page... |
10-04-2020, 16:36 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Armenia, Armavir
Member: 616204 Status: Offline Thanks Meter: 26 | J510FN Boot repair [Answered] When I was flashing my native flash memory, if the repartition checkbox was turned on, then I did not want to flash it, and when I unchecked the repartition checkbox it was flashed normally !!!. I put the flash drive in place, but nothing changed, the phone stopped at 75mA and was not detected by the computer. I thought that I needed to change the flash memory, the phone had H9TQ17ABJTBCUR-KUM I found a suitable KMQ310013B-B419, removed it from the G570f, read all the sections except the systems from the old flash memory, erased the new flash memory, wrote it down to the backups, then wrote down the pit and the firmware as in the video I asked for everything even with the repartition checkbox inserted, put the flash memory on the phone, now the phone will stop at 70mA and the computer can only see Qualcomm HS-USB QDLoader 9008. Already reached a dead end, tell me what else can be done ???? Thanks for advance P.S. Sorry for not having logs, logs on the computer at the workplace, if you need? I'll attach the logs tomorrow |
10-08-2020, 20:47 | #3 (permalink) |
Member: 616204 Status: Offline Thanks Meter: 26 | I remove emmc nand and connected to medusa-pro check Welcome to Medusa Pro Software version 2.1.3. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Gemalto e-gate Smart Card 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG4v2 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147347632013719ABB11569 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4v2 Product revision : 0.1 Product serial number : (hex) 3719ABB1 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/HAG4v2_03_10_2020_18_14_46.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001C980) 57.19 MB P03: sbl1 (00026180, 00000400) 512 KB P04: ddr (00026580, 00000040) 32 KB P05: aboot (000265C0, 00001000) 2048 KB P06: rpm (000275C0, 00000400) 512 KB P07: qsee (000279C0, 00000600) 768 KB P08: qhee (00027FC0, 00000400) 512 KB P09: fsg (000283C0, 00001800) 3072 KB P10: sec (00029BC0, 00000020) 16 KB P11: pad (00029BE0, 00005420) 10.52 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00005FFA) 12 MB P19: backup (00051FFA, 000037EE) 6.991 MB P20: fsc (000557E8, 00001800) 3072 KB P21: ssd (00056FE8, 00000010) 8 KB P22: persist (00056FF8, 00004000) 8 MB P23: persistent (0005AFF8, 00000800) 1024 KB P24: persdata (0005B7F8, 00004808) 9.004 MB P25: system (00060000, 005DC000) 3000 MB P26: cache (0063C000, 00064000) 200 MB P27: hidden (006A0000, 0001E000) 60 MB P28: userdata (006BE000, 0169BFD8) 11.3 GB Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_fsg_0x283c0_0x1800_03_10_2020_18_14_46.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping efs partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_efs_0x34000_0x7000_03_10_2020_18_14_46.bin file... Reading. Please wait... Done. Elapsed time 00:00:05 SW: 2.1.3; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_modemst1_0x3b000_0x1800_03_10_2020_18_14_46 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_modemst2_0x3c800_0x1800_03_10_2020_18_14_46 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 6144000 Device Manufacturer : samsung Device Platform : msm8916 Build ID : NMF26X Display Build ID : NMF26X.J510FNXXU2BRE4 Release ID : 7.1.1 Device Model : SM-J510FN Device Name : j5xnltexx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : j5xnltexx-user 7.1.1 NMF26X J510FNXXU2BRE4 release-keys I try to restore his native emmc nand. but when the repartition checkbox was turned on, I cannot restor Selected pit file: F:/Firmware/Samsung/J510fn/ATO-J510FNXXU2BRJ4_J510FNATO2BRJ1-20181212/J5XNLTE_EUR_OPEN.pit Open file "F:/Firmware/Samsung/J510fn/ATO-J510FNXXU2BRJ4_J510FNATO2BRJ1-20181212/J510FNXXU2BRJ4_J510FNATO2BRJ1_J510FNXXU2BRG1_HOME. tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT ERROR[012]: Write error. At sector 0. Disconnected. Last edited by Armkar; 10-08-2020 at 20:54. |
10-08-2020, 21:07 | #4 (permalink) |
Member: 616204 Status: Offline Thanks Meter: 26 | I try read dump all partition without system and userdata Welcome to Medusa Pro Software version 2.1.3. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Gemalto e-gate Smart Card 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG4v2 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147347632013719ABB11569 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4v2 Product revision : 0.1 Product serial number : (hex) 3719ABB1 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/HAG4v2_04_10_2020_11_27_26.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001C980) 57.19 MB P03: sbl1 (00026180, 00000400) 512 KB P04: ddr (00026580, 00000040) 32 KB P05: aboot (000265C0, 00001000) 2048 KB P06: rpm (000275C0, 00000400) 512 KB P07: qsee (000279C0, 00000600) 768 KB P08: qhee (00027FC0, 00000400) 512 KB P09: fsg (000283C0, 00001800) 3072 KB P10: sec (00029BC0, 00000020) 16 KB P11: pad (00029BE0, 00005420) 10.52 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00005FFA) 12 MB P19: backup (00051FFA, 000037EE) 6.991 MB P20: fsc (000557E8, 00001800) 3072 KB P21: ssd (00056FE8, 00000010) 8 KB P22: persist (00056FF8, 00004000) 8 MB P23: persistent (0005AFF8, 00000800) 1024 KB P24: persdata (0005B7F8, 00004808) 9.004 MB P25: system (00060000, 005DC000) 3000 MB P26: cache (0063C000, 00064000) 200 MB P27: hidden (006A0000, 0001E000) 60 MB P28: userdata (006BE000, 0169A000) 11.3 GB Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_fsg_0x283c0_0x1800_04_10_2020_11_27_26.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping efs partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_efs_0x34000_0x7000_04_10_2020_11_27_26.bin file... Reading. Please wait... Done. Elapsed time 00:00:05 SW: 2.1.3; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_modemst1_0x3b000_0x1800_04_10_2020_11_27_26 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_modemst2_0x3c800_0x1800_04_10_2020_11_27_26 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 6144000 Device Manufacturer : samsung Device Platform : msm8916 Build ID : NMF26X Display Build ID : NMF26X.J510FNXXU2BRE4 Release ID : 7.1.1 Device Model : SM-J510FN Device Name : j5xnltexx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : j5xnltexx-user 7.1.1 NMF26X J510FNXXU2BRE4 release-keys ---------------------------------------------------------------Save to D:/dump/j510fn/Hynix eMMC HAG4v2_04_10_2020__11_28_19.mpt file... Reading partition GPT... Done. Reading partition apnhlos... Done. Reading partition modem... Done. Reading partition sbl1... Done. Reading partition ddr... Done. Reading partition aboot... Done. Reading partition rpm... Done. Reading partition qsee... Done. Reading partition qhee... Done. Reading partition fsg... Done. Reading partition sec... Done. Reading partition pad... Done. Reading partition param... Done. Reading partition efs... Done. Reading partition modemst1... Done. Reading partition modemst2... Done. Reading partition boot... Done. Reading partition recovery... Done. Reading partition fota... Done. Reading partition backup... Done. Reading partition fsc... Done. Reading partition ssd... Done. Reading partition persist... Done. Reading partition persistent... Done. Reading partition persdata... Done. Reading partition hidden... Done. Reading is finished. SW: 2.1.3; FW: 1.24. Here is smart report EMMC Smart report info: Hash code: 00000000000000000000000000000000000000000000000000 00000000000000 Super block size : 0x00000000 Bytes Super page size : 0x00000000 Bytes Optima write size : 0x00000000 Bytes Number of banks : 0 Bank0 init bad block : 0 Bank0 runtime bad block : 0 Bank0 remain reserved block : 0 Max erase count : 0 Min erase count : 0 Avg erase count : 0 Read reclaim count : 0 Optimal trim size : 0x00000000 Bytes Max erase count (SCL) : 0 Min erase count (SCL) : 0 Avg erase count (SCL) : 0 Max erase count (MLC) : 0 Min erase count (MLC) : 0 Avg erase count (MLC) : 0 DEVICE_LIFE_TIME_EST_TYP_B : 60% - 70% device life time used DEVICE_LIFE_TIME_EST_TYP_A : Not defined PRE_EOL_INFO : Normal SW: 2.1.3; FW: 1.24. Disconnected. I erase all partitions ---------------------------------------------------------------Erasing partition GPT... Done. Erasing partition apnhlos... Done. Erasing partition modem... Done. Erasing partition sbl1... Done. Erasing partition ddr... Done. Erasing partition aboot... Done. Erasing partition rpm... Done. Erasing partition qsee... Done. Erasing partition qhee... Done. Erasing partition fsg... Done. Erasing partition sec... Done. Erasing partition pad... Done. Erasing partition param... Done. Erasing partition efs... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Erasing partition boot... Done. Erasing partition recovery... Done. Erasing partition fota... Done. Erasing partition backup... Done. Erasing partition fsc... Done. Erasing partition ssd... Done. Erasing partition persist... Done. Erasing partition persistent... Done. Erasing partition persdata... Done. Erasing partition system... Done. Erasing partition cache... Done. Erasing partition hidden... Done. Erasing partition userdata... Done. Erasing is finished. SW: 2.1.3; FW: 1.24. Cheack after erase Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J510H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J510H_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG4v2 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147347632013719ABB11569 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4v2 Product revision : 0.1 Product serial number : (hex) 3719ABB1 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/HAG4v2_04_10_2020_12_44_31.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Last edited by Armkar; 10-08-2020 at 21:17. |
10-08-2020, 21:31 | #5 (permalink) |
Member: 616204 Status: Offline Thanks Meter: 26 | Write backup partition verification is enabled. Write partitions from D:/dump/j510fn/Hynix eMMC HAG4v2_04_10_2020__11_28_19.mpt file... Writing partition GPT... Done. Writing partition apnhlos... Done. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition ddr... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition qsee... Done. Writing partition qhee... Done. Writing partition fsg... Done. Writing partition sec... Done. Writing partition pad... Done. Writing partition param... Done. Writing partition efs... Done. Writing partition modemst1... Done. Writing partition modemst2... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition fota... Done. Writing partition backup... Done. Writing partition fsc... Done. Writing partition ssd... Done. Writing partition persist... Done. Writing partition persistent... Done. Writing partition persdata... Done. Writing partition hidden... Done. SW: 2.1.3; FW: 1.24. Disconnected. Cheack after flash backup Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J510H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J510H_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG4v2 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147347632013719ABB11569 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4v2 Product revision : 0.1 Product serial number : (hex) 3719ABB1 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/HAG4v2_04_10_2020_12_48_24.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001C980) 57.19 MB P03: sbl1 (00026180, 00000400) 512 KB P04: ddr (00026580, 00000040) 32 KB P05: aboot (000265C0, 00001000) 2048 KB P06: rpm (000275C0, 00000400) 512 KB P07: qsee (000279C0, 00000600) 768 KB P08: qhee (00027FC0, 00000400) 512 KB P09: fsg (000283C0, 00001800) 3072 KB P10: sec (00029BC0, 00000020) 16 KB P11: pad (00029BE0, 00005420) 10.52 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00005FFA) 12 MB P19: backup (00051FFA, 000037EE) 6.991 MB P20: fsc (000557E8, 00001800) 3072 KB P21: ssd (00056FE8, 00000010) 8 KB P22: persist (00056FF8, 00004000) 8 MB P23: persistent (0005AFF8, 00000800) 1024 KB P24: persdata (0005B7F8, 00004808) 9.004 MB P25: system (00060000, 005DC000) 3000 MB P26: cache (0063C000, 00064000) 200 MB P27: hidden (006A0000, 0001E000) 60 MB P28: userdata (006BE000, 0169A000) 11.3 GB Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_fsg_0x283c0_0x1800_04_10_2020_12_48_24.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping efs partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_efs_0x34000_0x7000_04_10_2020_12_48_24.bin file... Reading. Please wait... Done. Elapsed time 00:00:05 SW: 2.1.3; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_modemst1_0x3b000_0x1800_04_10_2020_12_48_24 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_modemst2_0x3c800_0x1800_04_10_2020_12_48_24 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found ---------------------------------------------------------------Disconnected. try restor EMMC like video via pit files with uncheack repartition cheackbox Selected pit file: C:/Users/Gsm Service/Downloads/SM-J510FN_1_20190801142127_doy8ud1wuh_fac/J5XNLTE_EUR_OPEN.pit Open file "C:/Users/Gsm Service/Downloads/SM-J510FN_1_20190801142127_doy8ud1wuh_fac/BL_J510FNXXU3BSG2_CL12476963_QB24652943_REV00_user _low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/Gsm Service/Downloads/SM-J510FN_1_20190801142127_doy8ud1wuh_fac/AP_J510FNXXU3BSG2_CL12476963_QB24652943_REV00_user _low_ship_MULTI_CERT_meta.tar.md5". Open file "C:/Users/Gsm Service/Downloads/SM-J510FN_1_20190801142127_doy8ud1wuh_fac/CP_J510FNXWU3BSE1_REV00_CL2364549_QB12784957.tar.m d5". Open file "C:/Users/Gsm Service/Downloads/SM-J510FN_1_20190801142127_doy8ud1wuh_fac/CSC_OXY_J510FNOXY3BSG2_CL12476963_QB24652943_REV00 _user_low_ship_MULTI_CERT.tar.md5". Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition APNHLOS... from 2000 to 5C24 Done. Writing partition MODEM... from 9800 to 16444 Done. Writing partition SBL1... from 26180 to 22E Done. Writing partition ABOOT... from 265C0 to A13 Done. Writing partition RPM... from 275C0 to 170 Done. Writing partition QSEE... from 279C0 to 3EA Done. Writing partition QHEE... from 27FC0 to B1 Done. Writing partition sec... from 29BC0 to 2 Done. Writing partition BOOT... from 3E000 to 61FD Done. Writing partition RECOVERY... from 44800 to 6F91 Done. Writing partition PERSIST... from 56FF8 to 2131 Done. Writing partition CACHE... from 63C000 to 2ABD9 Done. Writing partition HIDDEN... from 6A0000 to 18F81 Done. Writing partition USERDATA... from 6BE000 to 1B2D97 Done. Writing is finished. SW: 2.1.3; FW: 1.24. Disconnected. Cheack after restore EMMC Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG4v2 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147347632013719ABB11569 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4v2 Product revision : 0.1 Product serial number : (hex) 3719ABB1 Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/HAG4v2_04_10_2020_13_20_51.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001C980) 57.19 MB P03: sbl1 (00026180, 00000400) 512 KB P04: ddr (00026580, 00000040) 32 KB P05: aboot (000265C0, 00001000) 2048 KB P06: rpm (000275C0, 00000400) 512 KB P07: qsee (000279C0, 00000600) 768 KB P08: qhee (00027FC0, 00000400) 512 KB P09: fsg (000283C0, 00001800) 3072 KB P10: sec (00029BC0, 00000020) 16 KB P11: pad (00029BE0, 00005420) 10.52 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00005FFA) 12 MB P19: backup (00051FFA, 000037EE) 6.991 MB P20: fsc (000557E8, 00001800) 3072 KB P21: ssd (00056FE8, 00000010) 8 KB P22: persist (00056FF8, 00004000) 8 MB P23: persistent (0005AFF8, 00000800) 1024 KB P24: persdata (0005B7F8, 00004808) 9.004 MB P25: system (00060000, 005DC000) 3000 MB P26: cache (0063C000, 00064000) 200 MB P27: hidden (006A0000, 0001E000) 60 MB P28: userdata (006BE000, 0169A000) 11.3 GB Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_fsg_0x283c0_0x1800_04_10_2020_13_20_51.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping efs partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_efs_0x34000_0x7000_04_10_2020_13_20_51.bin file... Reading. Please wait... Done. Elapsed time 00:00:05 SW: 2.1.3; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_modemst1_0x3b000_0x1800_04_10_2020_13_20_51 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/HAG4v2_modemst2_0x3c800_0x1800_04_10_2020_13_20_51 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found After All I resold Emmc in place, put phone no power on, the phone stopped at 75mA and was not detected by the computer I thought that I needed to change the flash memory, the phone had H9TQ17ABJTBCUR-KUM I found a suitable KMQ310013B-B419, removed it from the G570f I cheack EMMC elcome to Medusa Pro Software version 2.1.3. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Gemalto e-gate Smart Card 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501005133313342420071BAD8D7B3F9 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) 71BAD8D7 Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/Q313BB_04_10_2020_15_08_49.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: CPEFS (00010000, 00004000) 8 MB P05: m9kefs1 (00014000, 00002000) 4 MB P06: m9kefs2 (00016000, 00002000) 4 MB P07: m9kefs3 (00018000, 00002000) 4 MB P08: CARRIER (0001A000, 00000800) 1024 KB P09: PARAM (0001A800, 00004000) 8 MB P10: BOOT (0001E800, 00010000) 32 MB P11: RECOVERY (0002E800, 00013000) 38 MB P12: OTA (00041800, 00004000) 8 MB P13: CDMA-RADIO (00045800, 00002000) 4 MB P14: RADIO (00047800, 0002C000) 88 MB P15: TOMBSTONES (00073800, 00000800) 1024 KB P16: DNT (00074000, 00000800) 1024 KB P17: PERSISTENT (00074800, 00000400) 512 KB P18: STEADY (00074C00, 00000800) 1024 KB P19: RESERVED2 (00075400, 00002C00) 5.5 MB P20: SYSTEM (00078000, 005DC000) 3000 MB P21: CACHE (00654000, 00064000) 200 MB P22: HIDDEN (006B8000, 0001E000) 60 MB P23: CP_DEBUG (006D6000, 00002800) 5 MB P24: USERDATA (006D8800, 0167E000) 11.25 GB Backuping EFS partition... Opening C:/Program Files/Medusa Pro Software/Backups/Q313BB_EFS_0x6000_0xa000_04_10_2020_15_08_49.bin file... Reading. Please wait... Done. Elapsed time 00:00:08 SW: 2.1.3; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 491520 Number of sectors : 6144000 Device Manufacturer : samsung Device Platform : exynos5 Build ID : R16NW Display Build ID : R16NW.G570FXXU1CRK1 Release ID : 8.0.0 Device Model : SM-G570F Device Name : on5xeltejv Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : on5xeltejv-user 8.0.0 R16NW G570FXXU1CRK1 release-keys Erase all data ---------------------------------------------------------------Erasing. Please wait... Done. SW: 2.1.3; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501005133313342420071BAD8D7B3F9 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) 71BAD8D7 Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/Q313BB_04_10_2020_15_10_30.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found Last edited by Armkar; 10-08-2020 at 21:38. |
10-08-2020, 21:49 | #6 (permalink) |
Member: 616204 Status: Offline Thanks Meter: 26 | Change boot settings like as old EMMC ---------------------------------------------------------------Boot config succesfully changed! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501005133313342420071BAD8D7B3F9 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) 71BAD8D7 Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/Q313BB_05_10_2020_12_53_10.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found Write backup partitions ---------------------------------------------------------------Please select file. Partition table was not found. Writing partition GPT to buffer... Done. Writing partition apnhlos to buffer... Done. Writing partition modem to buffer... Done. Writing partition sbl1 to buffer... Done. Writing partition ddr to buffer... Done. Writing partition aboot to buffer... Done. Writing partition rpm to buffer... Done. Writing partition qsee to buffer... Done. Writing partition qhee to buffer... Done. Writing partition fsg to buffer... Done. Writing partition sec to buffer... Done. Writing partition pad to buffer... Done. Writing partition param to buffer... Done. Writing partition efs to buffer... Done. Writing partition modemst1 to buffer... Done. Writing partition modemst2 to buffer... Done. Writing partition boot to buffer... Done. Writing partition recovery to buffer... Done. Writing partition fota to buffer... Done. Writing partition backup to buffer... Done. Writing partition fsc to buffer... Done. Writing partition ssd to buffer... Done. Writing partition persist to buffer... Done. Writing partition persistent to buffer... Done. Writing partition persdata to buffer... Done. Writing partition hidden to buffer... Done. SW: 2.1.3; FW: 1.24. Don't forget to reconnect the device after writing to see changes. Write data verification is enabled. Writing. Please wait... Writing partition GPT... Done. Writing partition apnhlos... Done. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition ddr... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition qsee... Done. Writing partition qhee... Done. Writing partition fsg... Done. Writing partition sec... Done. Writing partition pad... Done. Writing partition param... Done. Writing partition efs... Done. Writing partition modemst1... Done. Writing partition modemst2... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition fota... Done. Writing partition backup... Done. Writing partition fsc... Done. Writing partition ssd... Done. Writing partition persist... Done. Writing partition persistent... Done. Writing partition persdata... Done. Writing partition hidden... Done. Done Writing is finished. Reconnect the device to see changes. SW: 2.1.3; FW: 1.24. Disconnected. Cheack after flash backup Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501005133313342420071BAD8D7B3F9 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) 71BAD8D7 Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/Q313BB_05_10_2020_12_56_34.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001C980) 57.19 MB P03: sbl1 (00026180, 00000400) 512 KB P04: ddr (00026580, 00000040) 32 KB P05: aboot (000265C0, 00001000) 2048 KB P06: rpm (000275C0, 00000400) 512 KB P07: qsee (000279C0, 00000600) 768 KB P08: qhee (00027FC0, 00000400) 512 KB P09: fsg (000283C0, 00001800) 3072 KB P10: sec (00029BC0, 00000020) 16 KB P11: pad (00029BE0, 00005420) 10.52 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00005FFA) 12 MB P19: backup (00051FFA, 000037EE) 6.991 MB P20: fsc (000557E8, 00001800) 3072 KB P21: ssd (00056FE8, 00000010) 8 KB P22: persist (00056FF8, 00004000) 8 MB P23: persistent (0005AFF8, 00000800) 1024 KB P24: persdata (0005B7F8, 00004808) 9.004 MB P25: system (00060000, 005DC000) 3000 MB P26: cache (0063C000, 00064000) 200 MB P27: hidden (006A0000, 0001E000) 60 MB P28: userdata (006BE000, 0169A000) 11.3 GB Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/Q313BB_fsg_0x283c0_0x1800_05_10_2020_12_56_34.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping efs partition... Opening C:/Program Files/Medusa Pro Software/Backups/Q313BB_efs_0x34000_0x7000_05_10_2020_12_56_34.bin file... Reading. Please wait... Done. Elapsed time 00:00:05 SW: 2.1.3; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/Q313BB_modemst1_0x3b000_0x1800_05_10_2020_12_56_34 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/Q313BB_modemst2_0x3c800_0x1800_05_10_2020_12_56_34 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Restore EMMC like as video Selected pit file: F:/Firmware/Samsung/J510fn/ATO-J510FNXXU2BRJ4_J510FNATO2BRJ1-20181212/J5XNLTE_EUR_OPEN.pit Selected pit file: C:/Users/Gsm Service/Downloads/SM-J510FN_1_20190801142127_doy8ud1wuh_fac/J5XNLTE_EUR_OPEN.pit Open file "C:/Users/Gsm Service/Downloads/SM-J510FN_1_20190801142127_doy8ud1wuh_fac/BL_J510FNXXU3BSG2_CL12476963_QB24652943_REV00_user _low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/Gsm Service/Downloads/SM-J510FN_1_20190801142127_doy8ud1wuh_fac/AP_J510FNXXU3BSG2_CL12476963_QB24652943_REV00_user _low_ship_MULTI_CERT_meta.tar.md5". Open file "C:/Users/Gsm Service/Downloads/SM-J510FN_1_20190801142127_doy8ud1wuh_fac/AP_J510FNXXU3BSG2_CL12476963_QB24652943_REV00_user _low_ship_MULTI_CERT_meta.tar.md5". Open file "C:/Users/Gsm Service/Downloads/SM-J510FN_1_20190801142127_doy8ud1wuh_fac/BL_J510FNXXU3BSG2_CL12476963_QB24652943_REV00_user _low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/Gsm Service/Downloads/SM-J510FN_1_20190801142127_doy8ud1wuh_fac/CP_J510FNXWU3BSE1_REV00_CL2364549_QB12784957.tar.m d5". Open file "C:/Users/Gsm Service/Downloads/SM-J510FN_1_20190801142127_doy8ud1wuh_fac/CSC_OXY_J510FNOXY3BSG2_CL12476963_QB24652943_REV00 _user_low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition APNHLOS... from 2000 to 5C24 Done. Writing partition MODEM... from 9800 to 16444 Done. Writing partition SBL1... from 26180 to 22E Done. Writing partition ABOOT... from 265C0 to A13 Done. Writing partition RPM... from 275C0 to 170 Done. Writing partition QSEE... from 279C0 to 3EA Done. Writing partition QHEE... from 27FC0 to B1 Done. Writing partition sec... from 29BC0 to 2 Done. Writing partition BOOT... from 3E000 to 61FD Done. Writing partition RECOVERY... from 44800 to 6F91 Done. Writing partition PERSIST... from 56FF8 to 2131 Done. Writing partition HIDDEN... from 6A0000 to 18F81 Done. Writing is finished. SW: 2.1.3; FW: 1.24. Disconnected. Cheack after All Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501005133313342420071BAD8D7B3F9 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) 71BAD8D7 Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/Q313BB_05_10_2020_13_00_05.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001C980) 57.19 MB P03: sbl1 (00026180, 00000400) 512 KB P04: ddr (00026580, 00000040) 32 KB P05: aboot (000265C0, 00001000) 2048 KB P06: rpm (000275C0, 00000400) 512 KB P07: qsee (000279C0, 00000600) 768 KB P08: qhee (00027FC0, 00000400) 512 KB P09: fsg (000283C0, 00001800) 3072 KB P10: sec (00029BC0, 00000020) 16 KB P11: pad (00029BE0, 00005420) 10.52 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00005FFA) 12 MB P19: backup (00051FFA, 000037EE) 6.991 MB P20: fsc (000557E8, 00001800) 3072 KB P21: ssd (00056FE8, 00000010) 8 KB P22: persist (00056FF8, 00004000) 8 MB P23: persistent (0005AFF8, 00000800) 1024 KB P24: persdata (0005B7F8, 00004808) 9.004 MB P25: system (00060000, 005DC000) 3000 MB P26: cache (0063C000, 00064000) 200 MB P27: hidden (006A0000, 0001E000) 60 MB P28: userdata (006BE000, 0169A000) 11.3 GB Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/Q313BB_fsg_0x283c0_0x1800_05_10_2020_13_00_05.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping efs partition... Opening C:/Program Files/Medusa Pro Software/Backups/Q313BB_efs_0x34000_0x7000_05_10_2020_13_00_05.bin file... Reading. Please wait... Done. Elapsed time 00:00:05 SW: 2.1.3; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/Q313BB_modemst1_0x3b000_0x1800_05_10_2020_13_00_05 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/Q313BB_modemst2_0x3c800_0x1800_05_10_2020_13_00_05 .bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found And in End I remove FRP ---------------------------------------------------------------Backuping FRP data... Opening C:/Program Files/Medusa Pro Software/Backups/FRP_0x5aff8_0x800_05_10_2020_13_00_21.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.3; FW: 1.24. Removing FRP. Please wait... Done. SW: 2.1.3; FW: 1.24. Disconnected. After All I put the flash memory on the phone, now the phone will stop at 70mA and the computer can not detected phone Please Help what am I doing wrong?? |
Display Modes |
Linear Mode |
Switch to Hybrid Mode |
Switch to Threaded Mode |
LinkBack |
LinkBack URL |
About LinkBacks |
Bookmark & Share |
Digg this Thread! |
Add Thread to del.icio.us |
Bookmark in Technorati |
Share on Facebook |
Stumble this Thread |
