10-15-2020, 07:24 | #1 (permalink) |
Freak Poster Join Date: Oct 2016
Member: 2640240 Status: Offline Thanks Meter: 150 | j727p dead boot repair done but now show 9008 port [Answered] Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J727P SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J727P_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100513331334242006E1CAC61C429 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) 6E1CAC61 Manufacturing date : 12/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/Q313BB_15_10_2020_06_20_46.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000400) 512 KB P04: rpm (00002C00, 00000400) 512 KB P05: tz (00003000, 00001000) 2048 KB P06: aboot (00004000, 00001000) 2048 KB P07: sec (00005000, 00000200) 256 KB P08: lksecapp (00005200, 00000400) 512 KB P09: keymaster (00005600, 00000400) 512 KB P10: cmnlib (00005A00, 00000200) 256 KB P11: fsg (00005C00, 00002000) 4 MB P12: cmnlib64 (00007C00, 00000200) 256 KB P13: pad (00007E00, 00000200) 256 KB P14: modemst1 (00008000, 00002000) 4 MB P15: modemst2 (0000A000, 00002000) 4 MB P16: efs (0000E000, 00008000) 16 MB P17: fsc (00016000, 00001A00) 3328 KB P18: ssd (00017A00, 00000200) 256 KB P19: devcfg (00017C00, 00000200) 256 KB P20: apdp (00017E00, 00000100) 128 KB P21: msadp (00017F00, 00000100) 128 KB P22: param (00018000, 00006000) 12 MB P23: backup (0001E000, 00002000) 4 MB P24: boot (00020000, 00010000) 32 MB P25: recovery (00030000, 00010000) 32 MB P26: bota (00040000, 00004000) 8 MB P27: fota (00044000, 00002000) 4 MB P28: persist (00046000, 00010000) 32 MB P29: persistent (00056000, 00000800) 1024 KB P30: steady (00056800, 00002000) 4 MB P31: keystore (00058800, 00000800) 1024 KB P32: config (00059000, 00000800) 1024 KB P33: dsp (00059800, 00008000) 16 MB P34: modem (00061800, 00030000) 96 MB P35: apnhlos (00091800, 00012000) 36 MB P36: reserved2 (000A3800, 00000800) 1024 KB P37: system (000A4000, 006D8000) 3504 MB P38: cache (0077C000, 00096000) 300 MB P39: carrier (00812000, 00018000) 48 MB P40: userdata (0082A000, 0152E000) 10.59 GB Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q313BB_fsg_0x5c00_0x2000_15_10_2020_06_20_46.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q313BB_modemst1_0x8000_0x2000_15_10_2020_06_20_46. bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q313BB_modemst2_0xa000_0x2000_15_10_2020_06_20_46. bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q313BB_efs_0xe000_0x8000_15_10_2020_06_20_46.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.1.3; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 7176192 Device Manufacturer : samsung Device Platform : msm8953 Build ID : NRD90M Display Build ID : NRD90M.J727PVPS3ARA1 Release ID : 7.0 Device Model : SM-J727P Device Name : j7popltespr Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : j7popltespr-user 7.0 NRD90M J727PVPS3ARA1 release-keys --------------------------------------------------------------- Selected pit file: C:/Users/hp/Downloads/J7POP_USA_SPR.pit Open file "C:/Users/hp/Downloads/J727PVPU6BSF2-(SPT)(Firmware 4 Files) (Android 8.1.0 Oreo) File By (Support.**************)_2/AP_J727PVPU6BSF2_CL14631142_QB24254597_REV00_user_ low_ship_MULTI_CERT_meta.tar.md5". Open file "C:/Users/hp/Downloads/J727PVPU6BSF2-(SPT)(Firmware 4 Files) (Android 8.1.0 Oreo) File By (Support.**************)_2/BL_J727PVPU6BSF2_CL14631142_QB24254597_REV00_user_ low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/hp/Downloads/J727PVPU6BSF2-(SPT)(Firmware 4 Files) (Android 8.1.0 Oreo) File By (Support.**************)_2/CP_J727PVPU6BSF2_CP12997269_CL14631142_QB24254597_ REV00_user_low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/hp/Downloads/J727PVPU6BSF2-(SPT)(Firmware 4 Files) (Android 8.1.0 Oreo) File By (Support.**************)_2/CSC_SPT_J727PSPT6BSF2_CL14631142_QB24254597_REV00_ user_low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition SBL1... from 2000 to 23A Done. Writing partition RPM... from 2C00 to FB Done. Writing partition TZ... from 3000 to 48C Done. Writing partition ABOOT... from 4000 to 768 Done. Writing partition SEC... from 5000 to 2 Done. Writing partition LKSECAPP... from 5200 to C6 Done. Writing partition KEYMASTER... from 5600 to 13B Done. Writing partition CMNLIB... from 5A00 to 150 Done. Writing partition DEVCFG... from 17C00 to 2F Done. Writing partition APDP... from 17E00 to 17 Done. Writing partition MSADP... from 17F00 to 17 Done. Writing partition BOOT... from 20000 to 717F Done. Writing partition RECOVERY... from 30000 to 8B10 Done. Writing partition PERSIST... from 46000 to 37 Done. Writing partition DSP... from 59800 to 1B45 Done. Writing partition MODEM... from 61800 to 17001 Done. Writing partition APNHLOS... from 91800 to 4C2B Done. Writing partition RESERVED2... from A3800 to 4C2B Done. Writing partition SYSTEM... from A4000 to 424A67 Done. Writing partition CACHE... from 77C000 to 20F53 Done. Writing partition USERDATA... from 82A000 to 14CA8C Done. Writing is finished. SW: 2.1.3; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J727P SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J727P_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100513331334242006E1CAC61C429 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) 6E1CAC61 Manufacturing date : 12/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/Q313BB_15_10_2020_07_20_10.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000400) 512 KB P04: rpm (00002C00, 00000400) 512 KB P05: tz (00003000, 00001000) 2048 KB P06: aboot (00004000, 00001000) 2048 KB P07: sec (00005000, 00000200) 256 KB P08: lksecapp (00005200, 00000400) 512 KB P09: keymaster (00005600, 00000400) 512 KB P10: cmnlib (00005A00, 00000200) 256 KB P11: fsg (00005C00, 00002000) 4 MB P12: cmnlib64 (00007C00, 00000200) 256 KB P13: pad (00007E00, 00000200) 256 KB P14: modemst1 (00008000, 00002000) 4 MB P15: modemst2 (0000A000, 00002000) 4 MB P16: efs (0000E000, 00008000) 16 MB P17: fsc (00016000, 00001A00) 3328 KB P18: ssd (00017A00, 00000200) 256 KB P19: devcfg (00017C00, 00000200) 256 KB P20: apdp (00017E00, 00000100) 128 KB P21: msadp (00017F00, 00000100) 128 KB P22: param (00018000, 00006000) 12 MB P23: backup (0001E000, 00002000) 4 MB P24: boot (00020000, 00010000) 32 MB P25: recovery (00030000, 00010000) 32 MB P26: bota (00040000, 00004000) 8 MB P27: fota (00044000, 00002000) 4 MB P28: persist (00046000, 00010000) 32 MB P29: persistent (00056000, 00000800) 1024 KB P30: steady (00056800, 00002000) 4 MB P31: keystore (00058800, 00000800) 1024 KB P32: config (00059000, 00000800) 1024 KB P33: dsp (00059800, 00008000) 16 MB P34: modem (00061800, 00030000) 96 MB P35: apnhlos (00091800, 00012000) 36 MB P36: reserved2 (000A3800, 00000800) 1024 KB P37: system (000A4000, 006D8000) 3504 MB P38: cache (0077C000, 00096000) 300 MB P39: carrier (00812000, 00018000) 48 MB P40: userdata (0082A000, 0152E000) 10.59 GB Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q313BB_fsg_0x5c00_0x2000_15_10_2020_07_20_10.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q313BB_modemst1_0x8000_0x2000_15_10_2020_07_20_10. bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q313BB_modemst2_0xa000_0x2000_15_10_2020_07_20_10. bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q313BB_efs_0xe000_0x8000_15_10_2020_07_20_10.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.1.3; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 7176192 Device Manufacturer : samsung Device Platform : msm8953 Build ID : M1AJQ Display Build ID : M1AJQ.J727PVPU6BSF2 Release ID : 8.1.0 Device Model : SM-J727P Device Name : j7popltespr Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : j7popltespr-user 8.1.0 M1AJQ J727PVPU6BSF2 release-keys --------------------------------------------------------------- alredy chack with bit 3,4, and now flash with 6 but still same probem |
10-15-2020, 07:49 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,128 | Hello. What is exact state of phone was before perform repair operation? The phone was in 9008 mode? Also try to write latest firmware with bit 7 for your phone and post here results. |
10-15-2020, 09:26 | #3 (permalink) |
Member: 2640240 Status: Offline Thanks Meter: 150 | phone in frp lock. wrtie commbnaton file and then flash with bit 3 file . but very inserting when i flash bit3 file without userdata so phone hang on log. but when i same file flash with out userdata means full flash then phone dnot power on. already chack battery with supply after i boot repair with bit 3,4,6,but after boot repair show 9008 port when phone dead then dnot show any port. |
10-15-2020, 15:00 | #4 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,128 | Probably at first the phone had firmware with bit 7. Unfortunately downgrade is not working, please try to write latest firmware with bit 7 for your phone and post here results. |
The Following User Says Thank You to Octopus support For This Useful Post: |
10-17-2020, 10:32 | #5 (permalink) |
Member: 2640240 Status: Offline Thanks Meter: 150 | Welcome to Medusa Pro Software version 2.1.3. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J727P SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J727P_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100513331334242006E1CAC61C429 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313BB Product revision : 0.0 Product serial number : (hex) 6E1CAC61 Manufacturing date : 12/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/Q313BB_17_10_2020_07_40_58.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.3; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000400) 512 KB P04: rpm (00002C00, 00000400) 512 KB P05: tz (00003000, 00001000) 2048 KB P06: aboot (00004000, 00001000) 2048 KB P07: sec (00005000, 00000200) 256 KB P08: lksecapp (00005200, 00000400) 512 KB P09: keymaster (00005600, 00000400) 512 KB P10: cmnlib (00005A00, 00000200) 256 KB P11: fsg (00005C00, 00002000) 4 MB P12: cmnlib64 (00007C00, 00000200) 256 KB P13: pad (00007E00, 00000200) 256 KB P14: modemst1 (00008000, 00002000) 4 MB P15: modemst2 (0000A000, 00002000) 4 MB P16: efs (0000E000, 00008000) 16 MB P17: fsc (00016000, 00001A00) 3328 KB P18: ssd (00017A00, 00000200) 256 KB P19: devcfg (00017C00, 00000200) 256 KB P20: apdp (00017E00, 00000100) 128 KB P21: msadp (00017F00, 00000100) 128 KB P22: param (00018000, 00006000) 12 MB P23: backup (0001E000, 00002000) 4 MB P24: boot (00020000, 00010000) 32 MB P25: recovery (00030000, 00010000) 32 MB P26: bota (00040000, 00004000) 8 MB P27: fota (00044000, 00002000) 4 MB P28: persist (00046000, 00010000) 32 MB P29: persistent (00056000, 00000800) 1024 KB P30: steady (00056800, 00002000) 4 MB P31: keystore (00058800, 00000800) 1024 KB P32: config (00059000, 00000800) 1024 KB P33: dsp (00059800, 00008000) 16 MB P34: modem (00061800, 00030000) 96 MB P35: apnhlos (00091800, 00012000) 36 MB P36: reserved2 (000A3800, 00000800) 1024 KB P37: system (000A4000, 006D8000) 3504 MB P38: cache (0077C000, 00096000) 300 MB P39: carrier (00812000, 00018000) 48 MB P40: userdata (0082A000, 0152E000) 10.59 GB Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q313BB_fsg_0x5c00_0x2000_17_10_2020_07_40_58.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q313BB_modemst1_0x8000_0x2000_17_10_2020_07_40_58. bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q313BB_modemst2_0xa000_0x2000_17_10_2020_07_40_58. bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.1.3; FW: 1.24. Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/Q313BB_efs_0xe000_0x8000_17_10_2020_07_40_58.bin file... Reading. Please wait... Done. Elapsed time 00:00:06 SW: 2.1.3; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 7176192 Device Manufacturer : samsung Device Platform : msm8953 Build ID : M1AJQ Display Build ID : M1AJQ.J727PVPU6BSF2 Release ID : 8.1.0 Device Model : SM-J727P Device Name : j7popltespr Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : j7popltespr-user 8.1.0 M1AJQ J727PVPU6BSF2 release-keys --------------------------------------------------------------- Selected pit file: C:/Users/hp/Downloads/J7POP_USA_SPR.pit Open file "C:/Users/hp/Downloads/J727PVPU7BTH1-(BST) (Firmware 4 Files) (Android 8.1.0 Oreo)/AP_J727PVPU7BTH1_CL14631142_QB33478358_REV00_user_ low_ship_MULTI_CERT_meta.tar.md5". Open file "C:/Users/hp/Downloads/J727PVPU7BTH1-(BST) (Firmware 4 Files) (Android 8.1.0 Oreo)/BL_J727PVPU7BTH1_CL14631142_QB33478358_REV00_user_ low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/hp/Downloads/J727PVPU7BTH1-(BST) (Firmware 4 Files) (Android 8.1.0 Oreo)/CP_J727PVPU7BTH1_CP16520081_CL14631142_QB33478358_ REV00_user_low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/hp/Downloads/J727PVPU7BTH1-(BST) (Firmware 4 Files) (Android 8.1.0 Oreo)/CSC_SPT_J727PSPT7BTH1_CL14631142_QB33478358_REV00_ user_low_ship_MULTI_CERT.tar.md5". Selected pit file: C:/Users/hp/Downloads/J727PVPU7BTH1-(BST) (Firmware 4 Files) (Android 8.1.0 Oreo)/J7POP_USA_SPR.pit Open file "C:/Users/hp/Downloads/J727PVPU7BTH1-(BST) (Firmware 4 Files) (Android 8.1.0 Oreo)/AP_J727PVPU7BTH1_CL14631142_QB33478358_REV00_user_ low_ship_MULTI_CERT_meta.tar.md5". Open file "C:/Users/hp/Downloads/J727PVPU7BTH1-(BST) (Firmware 4 Files) (Android 8.1.0 Oreo)/BL_J727PVPU7BTH1_CL14631142_QB33478358_REV00_user_ low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/hp/Downloads/J727PVPU7BTH1-(BST) (Firmware 4 Files) (Android 8.1.0 Oreo)/CP_J727PVPU7BTH1_CP16520081_CL14631142_QB33478358_ REV00_user_low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/hp/Downloads/J727PVPU7BTH1-(BST) (Firmware 4 Files) (Android 8.1.0 Oreo)/CSC_SPT_J727PSPT7BTH1_CL14631142_QB33478358_REV00_ user_low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition SBL1... from 2000 to 23A Done. Writing partition RPM... from 2C00 to FB Done. Writing partition TZ... from 3000 to 493 Done. Writing partition ABOOT... from 4000 to 768 Done. Writing partition SEC... from 5000 to 2 Done. Writing partition LKSECAPP... from 5200 to C6 Done. Writing partition KEYMASTER... from 5600 to 13C Done. Writing partition CMNLIB... from 5A00 to 14C Done. Writing partition DEVCFG... from 17C00 to 2F Done. Writing partition APDP... from 17E00 to 17 Done. Writing partition MSADP... from 17F00 to 17 Done. Writing partition BOOT... from 20000 to 717A Done. Writing partition RECOVERY... from 30000 to 8B0D Done. Writing partition PERSIST... from 46000 to 37 Done. Writing partition DSP... from 59800 to 1B45 Done. Writing partition MODEM... from 61800 to 17073 Done. Writing partition APNHLOS... from 91800 to 4C30 Done. Writing partition RESERVED2... from A3800 to 4C30 Done. Writing partition SYSTEM... from A4000 to 422B0F Done. Writing partition CACHE... from 77C000 to 20F53 Done. Writing partition USERDATA... from 82A000 to 14E515 Done. Writing is finished. SW: 2.1.3; FW: 1.24. with bit7 same show 9008 port where is problem ? |
