Member: 2330556
Thanks Meter: 79 | oppo A5s (CPH1909) mtk usb port only after reset [Answered] phone was pattern locked and volume keys are not working so i decide to remove lock via ISP
Here is the reset logs: Quote:
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC GD6BMB
Page size : 512 B
Block size : 512 B
Block count : 61071360
Size : 29.12 GB (29820.00 MB)
CID Info
CID : 150100474436424D420133940745A6F1
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : GD6BMB
Product revision : 0.1
Product serial number : (hex) 33940745
Manufacturing date : 10/2019
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 8Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x02) 00000010
Boot bus width : x8 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 15261696 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/GD6BMB_01_09_2021_03_21_52.bin.
Connect successful.
SW: 2.2.0.1; FW: 1.24.
P00: GPT (00000000, 00000040) 32 KB
P01: boot_para (00000040, 00000800) 1024 KB
P02: recovery (00000840, 00020000) 64 MB
P03: para (00020840, 00000400) 512 KB
P04: opporeserve1 (00020C40, 00004000) 8 MB
P05: opporeserve2 (00024C40, 00020000) 64 MB
P06: oppo_custom (00044C40, 00000800) 1024 KB
P07: expdb (00045440, 0000A000) 20 MB
P08: frp (0004F440, 00000800) 1024 KB
P09: nvcfg (0004FC40, 00010000) 32 MB
P10: nvdata (0005FC40, 00020000) 64 MB
P11: metadata (0007FC40, 00010000) 32 MB
P12: protect1 (0008FC40, 00004000) 8 MB
P13: protect2 (00093C40, 000043C0) 8.469 MB
P14: seccfg (00098000, 00004000) 8 MB
P15: persist (0009C000, 00018000) 48 MB
P16: sec1 (000B4000, 00001000) 2048 KB
P17: proinfo (000B5000, 00001800) 3072 KB
P18: md1img (000B6800, 00032000) 100 MB
P19: spmfw (000E8800, 00000800) 1024 KB
P20: scp1 (000E9000, 00003000) 6 MB
P21: scp2 (000EC000, 00003000) 6 MB
P22: sspm_1 (000EF000, 00000800) 1024 KB
P23: sspm_2 (000EF800, 00000800) 1024 KB
P24: gz1 (000F0000, 00008000) 16 MB
P25: gz2 (000F8000, 00008000) 16 MB
P26: nvram (00100000, 00020000) 64 MB
P27: lk (00120000, 00002800) 5 MB
P28: lk2 (00122800, 00002800) 5 MB
P29: boot (00125000, 00010000) 32 MB
P30: logo (00135000, 00008000) 16 MB
P31: odmdtbo (0013D000, 00008000) 16 MB
P32: tee1 (00145000, 00002800) 5 MB
P33: tee2 (00147800, 00004800) 9 MB
P34: odm (0014C000, 00080000) 256 MB
P35: vendor (001CC000, 002A0000) 1344 MB
P36: system (0046C000, 00868000) 4.203 GB
P37: cache (00CD4000, 00080000) 256 MB
P38: userdata (00D54000, 02CCC7DF) 22.4 GB
P39: otp (03A207DF, 00015800) 43 MB
P40: flashinfo (03A35FDF, 00008000) 16 MB
Backuping nvdata partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/GD6BMB_nvdata_0x5fc40_0x20000_01_09_2021_03_21_52. bin file...
Reading. Please wait... Done.
Elapsed time 00:00:26
Reset operation finished
Disconnected.
| After successful reset..phone only recognized as mtk usb port only..
so i decided to write EXT_CSD..but phone remain in same condition no power
EXT_CSD logs: Quote:
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 8Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/GD6BMB_01_09_2021_05_38_28.bin.
Connect successful.
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/GD6BMB_nvdata_0x5fc40_0x20000_01_09_2021_05_38_28. bin file...
Searching Android build info...
Ok
Disk/Image size : 47c00000 bytes
Device sector size : 512 bytes
Partition offset : 4636672
Number of sectors : 8814592
Build ID : O11019
Release ID : 8.1.0
Architecture ABI : arm64-v8a
Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi
Build Description : full_oppo6765_18511-user 8.1.0 O11019 1616154336 release-keys
Writing EXT_CSD succesfully complete!
Disconnected.
| Also remove CLK resistor and applied jumper but same no power
i reset alot of phones with medusa without facing any problem but i have never reset a5s.
Kindly share your experience where is the problem..
The pinout i used: https://www.********************/thr...-pinout.13305/ |
