09-29-2022, 20:21 | #1 (permalink) |
Freak Poster Join Date: Dec 2008 Location: GSM DÜNYASI TEAM.
Member: 923948 Status: Offline Sonork: 100.1655611 Thanks Meter: 35 | KMDP6001DA-B425 bga254 product 000000 [Solved] KMDP6001DA-B425 bga254 after eMMC write firmware product name 000000 before Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC DP6DAB Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 150100445036444142036FB3D23D7793 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : DP6DAB Product revision : 0.3 Product serial number : (hex) 6FB3D23D Manufacturing date : 07/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20357120 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DP6DAB_29_09_2022_21_33_05.bin. Connect successful. after Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC 000000 Page size : 512 B Block size : 512 B Block count : 1048576 Size : 512.00 MB --------------------------------------------------------------- CID Info CID : 150100303030303030562016061354D1 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 000000 Product revision : 5.6 Product serial number : (hex) 20160613 Manufacturing date : 05/2017 --------------------------------------------------------------- CSD Info CSD : 902701320F5903FFF6DB7FE08A40403B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 512 Kbytes Boot2 size : 512 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_29_09_2022_21_39_59.bin. Connect successful. |
09-30-2022, 07:57 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello Please, explain your problem in more detail. What did you do with this device before? Also, what eaxact name of this model? |
The Following User Says Thank You to Medusa Box For This Useful Post: |
