09-16-2021, 08:57 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | KYOCERA DIGNO 404KC RESET password DONE BY MEDUSA PRO 2 Selected eMMC interface. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 50 MHz Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC QN1SMB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100514E31534D420104C1D618B2B3 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN1SMB Full name one from : KMQN1000SM-B316 Product revision : 0.1 Product serial number : (hex) 4C1D618 Manufacturing date : 11/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QN1SMB_16_09_2021_09_38_19.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.2; FW: 2.00. P00: GPT (00000000, 00000800) 1024 KB P01: modem (00000800, 00020000) 64 MB P02: sbl1 (00020800, 00000800) 1024 KB P03: sbl1bak (00021000, 00000800) 1024 KB P04: rpm (00021800, 00000400) 512 KB P05: rpmbak (00021C00, 00000400) 512 KB P06: tz (00022000, 00000400) 512 KB P07: tzbak (00022400, 00000400) 512 KB P08: hyp (00022800, 00000400) 512 KB P09: hypbak (00022C00, 00000400) 512 KB P10: aboot (00023000, 00001000) 2048 KB P11: abootbak (00024000, 00001000) 2048 KB P12: boot (00025000, 00008000) 16 MB P13: recovery (0002D000, 00008000) 16 MB P14: fota (00035000, 00008000) 16 MB P15: fotabk (0003D000, 00008000) 16 MB P16: devparam (00045000, 00004000) 8 MB P17: splash (00049000, 00003000) 6 MB P18: system (0004C000, 00248000) 1168 MB P19: cache (00294000, 00155800) 683 MB P20: userdata (003E9800, 00A58800) 5.173 GB P21: carrier (00E42000, 00014000) 40 MB P22: reserve1 (00E56000, 00004000) 8 MB P23: misc (00E5A000, 00000800) 1024 KB P24: fsc (00E5A800, 00000400) 512 KB P25: ssd (00E5AC00, 00000400) 512 KB P26: DDR (00E5B000, 00000400) 512 KB P27: fsg (00E5B400, 00001000) 2048 KB P28: log (00E5C400, 0000A000) 20 MB P29: logwork (00E66400, 0000A000) 20 MB P30: bootwork (00E70400, 00002000) 4 MB P31: chkcode (00E72400, 00000800) 1024 KB P32: fotamng (00E72C00, 00000800) 1024 KB P33: sec (00E73400, 00000400) 512 KB P34: dnand (00E73800, 00004000) 8 MB P35: sysprop (00E77800, 00004000) 8 MB P36: persist (00E7B800, 00008000) 16 MB P37: modemst1 (00E83800, 00001000) 2048 KB P38: modemst2 (00E84800, 00001000) 2048 KB P39: bfss1 (00E85800, 00002000) 4 MB P40: bfss2 (00E87800, 00004000) 8 MB P41: reserve2 (00E8B800, 00004000) 8 MB Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/QN1SMB_fsg_0xe5b400_0x1000_16_09_2021_09_38_19.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 2.00. Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/QN1SMB_modemst1_0xe83800_0x1000_16_09_2021_09_38_1 9.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 2.00. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/QN1SMB_modemst2_0xe84800_0x1000_16_09_2021_09_38_1 9.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 2.00. RPMB: Counter of the successful data write requests = 19. Save to C:/Program Files/Medusa Pro Software/Samsung eMMC QN1SMB_16_09_2021__09_39_12.mpt file... Reading partition GPT... Done. Reading partition sbl1... Done. Reading partition sbl1bak... Done. Reading partition rpm... Done. Reading partition rpmbak... Done. Reading partition tz... Done. Reading partition tzbak... Done. Reading partition hyp... Done. Reading partition hypbak... Done. Reading partition aboot... Done. Reading partition abootbak... Done. Reading partition boot... Done. Reading partition recovery... Done. Reading partition fota... Done. Reading partition fotabk... Done. Reading partition devparam... Done. Reading partition splash... Done. Reading partition carrier... Done. Reading partition reserve1... Done. Reading partition misc... Done. Reading partition fsc... Done. Reading partition ssd... Done. Reading partition DDR... Done. Reading partition fsg... Done. Reading partition log... Done. Reading partition logwork... Done. Reading partition bootwork... Done. Reading partition chkcode... Done. Reading partition fotamng... Done. Reading partition sec... Done. Reading partition dnand... Done. Reading partition sysprop... Done. Reading partition persist... Done. Reading partition modemst1... Done. Reading partition modemst2... Done. Reading partition bfss1... Done. Reading partition bfss2... Done. Reading partition reserve2... Done. Reading is finished. SW: 2.2.2; FW: 2.00. Reset operation finished RESET OPPO FUNCTION |
The Following 2 Users Say Thank You to Fragga For This Useful Post: |
