12-08-2017, 08:32 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: turkey
Member: 706822 Status: Offline Thanks Meter: 648 | hi medusa pro all user help hi all user my phone g930a sbl error upload mode problem sda emergency file need help me. If for some reason it doesn't work, then try to create an emergency scdard from an identical model with identical firmware version as your broken one, root it by eng-boot, read out the first 1GB of the "sda" partition, write the dump to a fast class U1/U10 32GB sdcard using Win32Disk, insert the card into the sdcard slot and power it up while holding Vol Down + Home + Power. If everything was done correctly, the phone should boot into download mode, then just flash the latest full stock to fix it. To create an emergency sdcard for Qualcomm based G930/G935: adb shell su dd if=/dev/block/sda of=/storage/emulated/emergency.bin bs=1024 count=131072 exit adb pull /storage/emulated/emergency.bin |
12-08-2017, 08:43 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Unfortunately, we have no such phone at the moment to read out dump from it for You. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
