Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 11-06-2016, 12:10   #1 (permalink)
Member: 2250995
Thanks Meter: 47
Thumbs up LG D851 Still Dead After Repair With Mudussa Pro [Solved]
Write only Boot Partation
Then
Write all LG Firmware Partation
Via USB
Phone in same state .....
Old 11-06-2016, 21:00   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,397
Hello.
Then problem can be with phone's eMMC chip (most likely). Also, the problem can be with version of phone's boot loaders. Boot loaders in firmware file which You have written, can be not suitable with your phone. Try to make Factory Repair using different original LG firmwares for this phone. Also try to make Smart Repair using SRF (Smart Repair File) from the Support Area.
If after Smart Repairing and Factory Repairing with all available firmwares (different versions), the device still doesn't go into Download Mode - most likely, device's flash chip doesn't allow to make repair. Some flash chips don't allow to make repair/write data (eMMC flash chip has write data protection and it doesn't allow to write boot or some other partitions even write process was shown successfully completed). You need to solder (replace) new flash chip and then make Repair. Unfortunately, currently no another solution how to disable write protection in non-Samsung eMMC flash chips.
The Following User Says Thank You to Medusa Box For This Useful Post:
Old 11-08-2016, 12:14   #3 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 385
u can use Old medusa software 2.6.1 and try to jtag with usb.
i did many set with this.
GSM.SOLVE
Old 11-12-2016, 13:00   #4 (permalink)
Member: 2250995
Thanks Meter: 47
Its VS985 :(
Originally Posted by Medusa Box View Post
Hello.
After Disamble ....
Fallowning cell is VS985 Printed on the borad Not D851
Old 11-13-2016, 08:19   #5 (permalink)
Member: 2250995
Thanks Meter: 47
Its Done :)
Hello.
used Mudusa pro Software by slecting MSM8974AC But the phone was VS985 .
Select thw fallowing Firmware VS98547A_01_0314_ARB01 (6.0) The Phone IS OK And normal booting
The Following User Says Thank You to najrazlug For This Useful Post:
Page generated in 0.14618 seconds with 8 queries
