05-01-2017, 07:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2016 Location: Pakistan Age: 27
Member: 2665080 Status: Offline Thanks Meter: 63 | Lg g4 Ls991 Conect problem Interface : USB Brand : LG Model : LS991 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS991_USB.srf Core : Qualcomm MSM8992 Loader : QLoader_v2 Connecting... Sending loader...OK. Loader not initialized. Loader is not suitable for this device. Storage info sending error. Model Settings: Interface : USB Brand : LG Model : LS991 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS991_USB.srf Core : Qualcomm MSM8992 Loader : QLoader_v2 Connecting... Sending loader...OK. Loader not initialized. Loader is not suitable for this device. Storage info sending error. |
05-01-2017, 07:30 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. As You can see from your Software log, USB Qualcomm MSM8992 loader "QLoader_v2" is not compatible (not suitable) with your phone: Quote:
1. Select "USB" option in Software. 2. Select "Brand: Custom Settings". 3. Select "Device (Core): Qualcomm MSM8992" 4. Select "Loader: QLoader_v1". Also note, that loaders can be not suitable for connecting the device. This depends on device CPU bootrom revision. Some devices (the same models) can be connected using loaders from Software and some аrе not connected, for example: http://forum.gsmhosting.com/vbb/f664...d-usb-2161902/, http://forum.gsmhosting.com/vbb/f798...table-2162110/. | |
05-01-2017, 11:39 | #4 (permalink) |
Member: 2665080 Status: Offline Thanks Meter: 63 | Downloaded file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LS991_BOOT REPAIR_BY_CHARLES_GARCIA_TOSHIBA EMMC 032G74.MPT. Model Settings: Interface : USB Brand : LG Model : LS991 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS991_USB.srf Core : Qualcomm MSM8992 Loader : QLoader_v2 Connecting... Sending loader...OK. Loader not initialized. Loader is not suitable for this device. Storage info sending error. |
05-01-2017, 19:29 | #5 (permalink) |
No Life Poster Join Date: Jul 2012
Member: 1783314 Status: Offline Sonork: 100.1620532 Thanks Meter: 127 | Hello, Medusa team was suggesting using : "Loader : Qloader_v1" In Medusa pro settings pick from drop box setting : Qloader_v1. In your logs you are only trying : " Loader : Qloader_v2" Try with Qloader_v1 and post log here. One of the 2 loaders should work to connect via USB. Sent from my SAMSUNG-SGH-I317 using Tapatalk |
05-02-2017, 05:50 | #7 (permalink) |
Member: 2665080 Status: Offline Thanks Meter: 63 | Model Settings: Interface : USB Brand : LG Model : LS991 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS991_USB.srf Core : Qualcomm MSM8992 Loader : QLoader_v2 Connecting... Sending loader...OK. Loader not initialized. Loader is not suitable for this device. Storage info sending error. |
05-02-2017, 05:53 | #8 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,308 | Quote:
via usb not Support , you need to Connect phone via ISP Pinouts | |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
05-02-2017, 06:06 | #10 (permalink) |
Member: 2665080 Status: Offline Thanks Meter: 63 | Connecting... Sending loader...OK. Loader not initialized. Loader is not suitable for this device. Storage info sending error. Downloaded file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LS991_BOOT REPAIR_BY_CHARLES_GARCIA_TOSHIBA EMMC 032G74.MPT. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. |
05-02-2017, 06:11 | #11 (permalink) |
Member: 2665080 Status: Offline Thanks Meter: 63 | Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Report Post |
05-02-2017, 06:16 | #12 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Quote:
1. You have connected battery or USB cable. Before connecting the device You must disconnect the battery and the USB cable, and then connect the device without power, this is important! 2. Some wires are soldered incorrectly. Carefully check soldering of all wires. 3. In the process of soldering, the resistors were burned (damaged) by using soldering iron or the pin pads on the board to which wires were soldered were damaged. Need replace damaged resistors and restore the pin pads on the board. 4. The ends of wires that were soldered, had not been cleared. Wire, that comes complete with Medusa Pro Box, is covered with an insulator, so before soldering need to clean the ends of each wire. 5. Soldered wires are too long. Make each wire as short as possible (3-5 CM length). 6. For GND connection use more thicker wire. Check all of them and try to connect the device again. Also post here full Software log with the Connect procedure. | |
05-02-2017, 06:46 | #14 (permalink) |
Member: 2665080 Status: Offline Thanks Meter: 63 | https://ibb.co/d7EwO5 check this pic i use this test point |
05-02-2017, 07:51 | #15 (permalink) |
Member: 2665080 Status: Offline Thanks Meter: 63 | Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS991 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS991_EMMC_032G74.srf Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. |
