12-19-2019, 13:50 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | A13 oppo after reset frp and pattern touch is not working help [Answered] Code: SW: 1.7.7; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC QD63MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100514436334D4203E1E407848647 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QD63MB Product revision : 0.3 Product serial number : (hex) E1E40784 Manufacturing date : 08/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QD63MB_18_12_2019_17_51_00.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: vbmeta (0005FC40, 00004000) 8 MB P11: nvcfg (00063C40, 00010000) 32 MB P12: nvdata (00073C40, 00020000) 64 MB P13: metadata (00093C40, 00010000) 32 MB P14: protect1 (000A3C40, 00004000) 8 MB P15: protect2 (000A7C40, 000043C0) 8.469 MB P16: seccfg (000AC000, 00004000) 8 MB P17: persist (000B0000, 00018000) 48 MB P18: sec1 (000C8000, 00001000) 2048 KB P19: proinfo (000C9000, 00001800) 3072 KB P20: md1img (000CA800, 00032000) 100 MB P21: spmfw (000FC800, 00000800) 1024 KB P22: scp1 (000FD000, 00000800) 1024 KB P23: scp2 (000FD800, 00000800) 1024 KB P24: sspm_1 (000FE000, 00000800) 1024 KB P25: sspm_2 (000FE800, 00000800) 1024 KB P26: gz1 (000FF000, 00008000) 16 MB P27: gz2 (00107000, 00008000) 16 MB P28: nvram (0010F000, 00020000) 64 MB P29: lk (0012F000, 00000800) 1024 KB P30: lk2 (0012F800, 00000800) 1024 KB P31: boot (00130000, 00010000) 32 MB P32: logo (00140000, 00008000) 16 MB P33: dtbo (00148000, 00008000) 16 MB P34: tee1 (00150000, 00002800) 5 MB P35: tee2 (00152800, 00005800) 11 MB P36: odm (00158000, 00080000) 256 MB P37: vendor (001D8000, 001CC000) 920 MB P38: system (003A4000, 00960000) 4.688 GB P39: cache (00D04000, 000D8000) 432 MB P40: userdata (00DDC000, 02C447DF) 22.13 GB P41: otp (03A207DF, 00015800) 43 MB P42: flashinfo (03A35FDF, 00008000) 16 MB Backuping FRP data... Opening C:/Program Files/Medusa Pro Software/Backups/FRP_0x5f440_0x800_18_12_2019_17_51_14.bin file... Reading. Please wait... ERROR[011]: Read error. At sector 390208 Attempting to read... Done. Elapsed time 00:00:00 SW: 1.7.7; FW: 1.24. Removing FRP. Please wait... Done. SW: 1.7.7; FW: 1.24. Disconnected. now touch is not working compelety. is it possible after writing tha "para" partition, may cause the touch not working some time? para partition log Code: Welcome to Medusa Pro Software version 1.7.7. Started. Reader #0: FT SCR2000 0 Reader #1: Generic USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC QD63MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100514436334D4203E1E407848647 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QD63MB Product revision : 0.3 Product serial number : (hex) E1E40784 Manufacturing date : 08/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QD63MB_18_12_2019_20_04_34.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: opporeserve1 (00010C40, 00004000) 8 MB P05: opporeserve2 (00014C40, 00020000) 64 MB P06: opporeserve3 (00034C40, 00020000) 64 MB P07: oppo_custom (00054C40, 00000800) 1024 KB P08: expdb (00055440, 0000A000) 20 MB P09: frp (0005F440, 00000800) 1024 KB P10: vbmeta (0005FC40, 00004000) 8 MB P11: nvcfg (00063C40, 00010000) 32 MB P12: nvdata (00073C40, 00020000) 64 MB P13: metadata (00093C40, 00010000) 32 MB P14: protect1 (000A3C40, 00004000) 8 MB P15: protect2 (000A7C40, 000043C0) 8.469 MB P16: seccfg (000AC000, 00004000) 8 MB P17: persist (000B0000, 00018000) 48 MB P18: sec1 (000C8000, 00001000) 2048 KB P19: proinfo (000C9000, 00001800) 3072 KB P20: md1img (000CA800, 00032000) 100 MB P21: spmfw (000FC800, 00000800) 1024 KB P22: scp1 (000FD000, 00000800) 1024 KB P23: scp2 (000FD800, 00000800) 1024 KB P24: sspm_1 (000FE000, 00000800) 1024 KB P25: sspm_2 (000FE800, 00000800) 1024 KB P26: gz1 (000FF000, 00008000) 16 MB P27: gz2 (00107000, 00008000) 16 MB P28: nvram (0010F000, 00020000) 64 MB P29: lk (0012F000, 00000800) 1024 KB P30: lk2 (0012F800, 00000800) 1024 KB P31: boot (00130000, 00010000) 32 MB P32: logo (00140000, 00008000) 16 MB P33: dtbo (00148000, 00008000) 16 MB P34: tee1 (00150000, 00002800) 5 MB P35: tee2 (00152800, 00005800) 11 MB P36: odm (00158000, 00080000) 256 MB P37: vendor (001D8000, 001CC000) 920 MB P38: system (003A4000, 00960000) 4.688 GB P39: cache (00D04000, 000D8000) 432 MB P40: userdata (00DDC000, 02C447DF) 22.13 GB P41: otp (03A207DF, 00015800) 43 MB P42: flashinfo (03A35FDF, 00008000) 16 MB Partition table has been found on device. Partition table has been found on device. Don't forget to reconnect the device after writing to see changes. Writting partitions. Please wait... Writing partition para from C:/Users/saqib/Desktop/Temp/Pin pattren Remove/Factory reset format data.bin file... ERROR[012]: Write error. Attempting to read... Done. Writing is finished. SW: 1.7.7; FW: 1.24. Reconnect the device to see changesDisconnected. |
12-19-2019, 20:57 | #3 (permalink) | |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,101 | Quote:
After that re-check your Device... [OPPO/Realme/VIVO/Honor Mobiles_RESET.srf Files for Medusa/Octoplus Pro Box...] | |
The Following 2 Users Say Thank You to Pijush Das For This Useful Post: |
