03-02-2017, 12:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Lumia 520 Remove Protection Done again Code: Welcome to Medusa Pro Software version 1.3.2. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Reader #3: Generic EMV Smartcard Reader 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC M8G2YC Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 1501004D384732594300DA62495731B1 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : M8G2YC Product revision : 0.0 Product serial number : (hex) DA624957 Manufacturing date : 03/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF96406007 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Boot partition enable : User area Partition config : 00111000 Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2539520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/M8G2YC_01_03_2017_19_36_42.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.2; FW: 1.15. Remove write protect successfully completed. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC M8G2YC Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 1501004D384732594300DA62495731B1 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : M8G2YC Product revision : 0.0 Product serial number : (hex) DA624957 Manufacturing date : 03/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF96404063 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Boot partition enable : User area Partition config : 00111000 Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2539520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/M8G2YC_01_03_2017_19_37_01.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.2; FW: 1.15. Last edited by Medusa Box; 03-02-2017 at 12:34. |
The Following 2 Users Say Thank You to maanarman For This Useful Post: |
