02-05-2019, 10:17 | #1 (permalink) | |
No Life Poster Join Date: May 2011 Location: ..:Inside UR Brain:.. Age: 34
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | LG Q6 M700 can't connect via USB... [Answered] Phone detect as Qualcomm HS Usb-device 9008 in device manager... when i try to connect for repair via usb...its giving me error Logs... Quote:
02-05-2019, 11:40 | #3 (permalink) | ||
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | Quote:
hello thanks for your quick attention... i have tried lots of other loaders but still no luck... Quote:
02-05-2019, 14:25 | #4 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Most likely loaders that we have aren't suitable with your device. Unfortunately, we don't have any other loaders right now |
02-06-2019, 13:54 | #5 (permalink) | |
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | Hi there i removed its emmc and connect it to medusa pro for factory repair... but now my problem is medusa showing this error... Quote:
02-06-2019, 15:47 | #6 (permalink) | ||
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | i have changed its emmc and connect it to medusa pro via USB.. and its connect successfully... then i repair with SRF and its flashed successfully... Quote:
after repair its info... Quote:
phone is still in qualcomm 9008 mode... i have also tried with factory repair kdz firmware but no luck phone is still dead... | ||
02-08-2019, 10:06 | #7 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Unfortunately, we don't have any other solution related to your issue, as You can see from the Software log, Repair operation was completed successfully. Most likely You need to set up some settings to your eMMC, but in USB mode such possibility isn't supported. |
02-08-2019, 13:50 | #8 (permalink) | |
can you please tell me which settings i have to changed... i will connect direct emmc via pinout... | |
02-09-2019, 09:41 | #11 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | You must have the EXT_CSD file if You connected your old eMMC to Medusa Pro, unfortunately, if You didn't make any backups, we will not able to help You, because we don't have support for this device via eMMC and we haven't any backups for your eMMC. |
