02-19-2017, 10:04 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | LGH811 Successfully Repair Code: Welcome to Medusa Pro Software version 1.3.2. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : H811 SRF : D:/Flash phone/Medusa Pro/firmwareFolder/LG_H81120r_EMMC_.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Toshiba eMMC 032G74 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 110100303332473734001F53A2B8425F Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032G74 Product revision : 0.0 Product serial number : (hex) 1F53A2B8 Manufacturing date : 04/2015 --------------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Boot partition enable : Device not boot enabled (default) Partition config : 00000000 Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/032G74_19_02_2017_15_10_35.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.2; FW: 1.15. Erasing. Please wait... Done. SW: 1.3.2; FW: 1.15. Reapairing from file "D:/Flash phone/Medusa Pro/firmwareFolder/LG_H81120r_EMMC_.srf". Write data verification is enabled. Writing GPT partition... Done. Writing pmic partition... Done. Writing sbl1 partition... Done. Writing tz partition... Done. Writing sdi partition... Done. Writing hyp partition... Done. Writing rpm partition... Done. Writing aboot partition... Done. Writing misc partition... Done. Writing persist partition... Done. Writing sec partition... Done. Writing laf partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing raw_resources partition... Done. Writing factory partition... Done. Writing fota partition... Done. Smart Repair is successfully complete. SW: 1.3.2; FW: 1.15. Disconnected. reflash by Octopus Code: Welcome to Octoplus/Octopus Box LG Software version 2.5.8 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM152 Selected model: H811 Reading info... Could not detect mode! Performed by 2.5.8 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM152 Selected model: H811 Reading info... Model ID: LG-H811 IMEI: 352392-07-283084-2 Android version: 5.1 Battery level: 50% SW Version: H81110n Mode: Emergency Initializing flash...OK SW version: LGH811AT-01-V10n-310-260-AUG-17-2015-ARB02+0 Android version: 6.0 LAF Version: 1.1 Product ID: PT01S150604004273 IMEI: 352392-07-283084-2 Target operator: TMO Hardware: rev_10 Opening "H811V20r_00_0111.kdz"...OK Firmware version: H81120r Firmware model: LG-H811 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Verifying checkSums...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing 1/67 PrimaryGPT_0.bin...OK Writing 2/67 modem_32768.bin...OK Writing 3/67 pmic_229376.bin...OK Writing 4/67 sbl1_230400.bin...OK Writing 5/67 tz_232448.bin...OK Writing 6/67 sdi_234496.bin...OK Writing 7/67 hyp_235520.bin...OK Writing 8/67 rpm_236544.bin...OK Writing 9/67 aboot_237568.bin...OK Writing 10/67 sbl1bak_241664.bin...OK Writing 11/67 pmicbak_243712.bin...OK Writing 12/67 tzbak_244736.bin...OK Writing 13/67 hypbak_246784.bin...OK Writing 14/67 rpmbak_247808.bin...OK Writing 15/67 abootbak_248832.bin...OK Writing 16/67 sdibak_252928.bin...OK Writing 17/67 persist_294912.bin...OK Writing 18/67 sec_376832.bin...OK Writing 20/67 laf_393216.bin...OK Writing 21/67 boot_491520.bin...OK Writing 22/67 recovery_573440.bin...OK Writing 23/67 raw_resources_770048.bin...OK Writing 24/67 raw_resourcesbak_778240.bin...OK Writing 25/67 factory_917504.bin...OK Writing 26/67 system_1048576.bin...OK Writing 27/67 system_1312904.bin...OK Writing 28/67 system_1576912.bin...OK Writing 29/67 system_1837192.bin...OK Writing 30/67 system_1841240.bin...OK Writing 31/67 system_2101200.bin...OK Writing 32/67 system_2361480.bin...OK Writing 33/67 system_2365528.bin...OK Writing 34/67 system_2625488.bin...OK Writing 35/67 system_2885768.bin...OK Writing 36/67 system_2889816.bin...OK Writing 37/67 system_3149776.bin...OK Writing 38/67 system_3410056.bin...OK Writing 39/67 system_3414104.bin...OK Writing 40/67 system_3674064.bin...OK Writing 41/67 system_3936208.bin...OK Writing 42/67 system_4198352.bin...OK Writing 43/67 system_4460496.bin...OK Writing 44/67 system_4722640.bin...OK Writing 45/67 system_4984784.bin...OK Writing 46/67 system_5246928.bin...OK Writing 47/67 system_5509072.bin...OK Writing 48/67 system_5771216.bin...OK Writing 49/67 system_6033360.bin...OK Writing 50/67 system_6295504.bin...OK Writing 51/67 system_6557648.bin...OK Writing 52/67 system_6815744.bin...OK Writing 53/67 system_7077888.bin...OK Writing 54/67 system_7340032.bin...OK Writing 55/67 system_7602176.bin...OK Writing 56/67 system_7604360.bin...OK Writing 57/67 system_7608408.bin...OK Writing 58/67 system_8126464.bin...OK Writing 59/67 system_8128648.bin...OK Writing 60/67 system_8132696.bin...OK Writing 61/67 system_8650752.bin...OK Writing 62/67 system_8912896.bin...OK Writing 63/67 system_9175040.bin...OK Writing 64/67 system_9437184.bin...OK Writing 65/67 system_9699328.bin...OK Writing 66/67 system_9703376.bin...OK Writing 67/67 BackupGPT_61070336.bin...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.5.8 Software version. Last edited by Medusa Box; 02-19-2017 at 20:05. |
The Following User Says Thank You to 089999945 For This Useful Post: |
