04-11-2017, 05:47 | #2 (permalink) |
Major Poster Join Date: Jun 2015 Location: Mexico Age: 41
Member: 2404731 Status: Offline Thanks Meter: 109 | Hello. Here is eMMC pinout picture for You: VCC pin -> 2.8V pin and VCQ pin -> 1.8V pin. Just solder all wires and make Factory Repair. Press "Thanks" button. |
The Following 6 Users Say Thank You to Carlos_S For This Useful Post: |
04-11-2017, 06:36 | #3 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1639426 Status: Offline Sonork: khurram136 Thanks Meter: 94 | thanks for reply bro but this point not working i am already try phone not connect emmc . |
The Following User Says Thank You to khurram136 For This Useful Post: |
04-11-2017, 09:02 | #4 (permalink) |
Member: 1639426 Status: Offline Sonork: khurram136 Thanks Meter: 94 | World fist dead boot repair medusa pro done WORLD FIST SAMSUNG G3812 DEAD BOOT REPAIR MEDUSA PRO DONE G3812 PHONE HANG IN LOGO TRY FLASHING ODIN PHONE DEAD ONLY BACK FLASH LIGHT BLINKING CONNECT MEDUSA PRO BOX EMMC Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Samsung eMMC 4YMD3R Page size : 512 B Block size : 512 B Block count : 7733248 Size : 3776.00 MB --------------------------------------------------------------- CID Info CID : 15010034594D4433520233DB64202189 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 4YMD3R Product revision : 0.2 Product serial number : (hex) 33DB6420 Manufacturing date : 02/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1286144 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/4YMD3R_10_04_2017_23_37_55.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.4; FW: 1.16. P00: GPT (00000000, 00002000) P01: MRD (00002000, 00001000) P02: MRD_BK (00003000, 00001000) P03: MEP2 (00004000, 00001000) P04: EFS (00005000, 0000A000) P05: Reserved (0000F000, 00007000) P06: LOKE_2ND (00016400, 00000C00) P07: LOKE_1ST (00017400, 00000C00) P08: PARAM (00018000, 00008000) P09: RECOVERY (00020000, 00008000) P10: KERNEL (00028000, 00008000) P11: MODEM (00030000, 0000C000) P12: NVM (0003C000, 00008000) P13: HIDDEN (00044000, 00005000) P14: CACHE (00049000, 0006F000) P15: SYSTEM (000B8000, 00217000) P16: USER (002CF000, 00490800) Code: Selected pit file: C:/Users/CH Khurram/Downloads/Compressed/G3812ZNUAML1_CHUAML1_v4.2.2_Repair_Firmware/G3812ZNUAML1_CHUAML1/WilcoxDS.pit Open file "C:/Users/CH Khurram/Downloads/Compressed/G3812ZNUANE1_G3812CHUANE1_CHU_4.2.2/G3812ZNUANE1_G3812CHUANE1_G3812ZNUANE1_HOME.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition TIMH... Done. Switched to user area. Writing partition LOKE_2ND... Done. Writing partition LOKE_1ST... Done. Writing partition PARAM... Done. Writing partition RECOVERY... Done. Writing partition KERNEL... Done. Writing partition MODEM... Done. Writing partition HIDDEN... Done. Writing partition CACHE... Done. Writing partition SYSTEM... Done. Switched to boot area partition 1. Writing partition OBM... Done. Switched to user area. Writing partition DTim.Recovery... Done. Writing partition DTim.Primary... Done. Writing is finished. SW: 1.3.4; FW: 1.16. Code: Switched to boot area partition 1. Opening F:/samsung boot file/Samsung eMMC 4YMD3R_11_04_2017_00_39_15 B BOT 1.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 1.3.4; FW: 1.16. Switched to boot area partition 2. Opening F:/samsung boot file/Samsung eMMC 4YMD3R_11_04_2017_00_39_37 BOOT 2.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 1.3.4; FW: 1.16. TESTED EMMC POINT MUST SELECT V 2.8 https://www.4shared.com/photo/vlsJFl-0ei/G3812.html |
04-11-2017, 10:19 | #5 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Thanks for your good report. Also, please upload somewhere boot1 and boot2 files, we will upload them into the Support Area for all users. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
04-17-2021, 10:54 | #9 (permalink) |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,101 | Hello Everyone, try this .srf for SM-G3812 SAMSUNG_SM-G3812_eMMC_ISP_SRF_BY_@PIJUSH [NOTE: If you no need repair EFS & NVM then must Untick EFS & NVM then Click on Repair Button] |
The Following User Says Thank You to Pijush Das For This Useful Post: |
