03-01-2021, 16:38 | #1 (permalink) |
Registered User Join Date: Aug 2003 Location: ALGERIA ,DZ
Member: 37521 Status: Offline Thanks Meter: 50 | OPPO A5 2020 dead after password remove [Answered] After remove password from OPPO A5 2020 no phone is dead (QD LOADER 9008) what's goes Wrong ,,, all is fine connection with box and remove password operation ok but phone now is not powered ON , dead boot or what help solution please. thanks. |
03-01-2021, 16:44 | #3 (permalink) |
Member: 37521 Status: Offline Thanks Meter: 50 | Welcome to Medusa Pro Software version 2.2.0. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC hC8aP Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A68433861503E0351B158DF96C9 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hC8aP Product revision : 0.3 Product serial number : (hex) 51B158DF Manufacturing date : 09/2019 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hC8aP_01_03_2021_15_42_48.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.0; FW: 1.24. P00: GPT (00000000, 00000028) 20 KB P01: oppodycnvbk (00000028, 00005000) 10 MB P02: oppostanvbk (00005028, 00005000) 10 MB P03: modemst1 (0000A028, 00001000) 2048 KB P04: modemst2 (0000B028, 00001000) 2048 KB P05: opporeserve1 (0000C028, 00004000) 8 MB P06: opporeserve2 (00010028, 00020000) 64 MB P07: opporeserve3 (00030028, 00020000) 64 MB P08: oppo_sec (00050028, 00005000) 10 MB P09: xbl (00060000, 00001C00) 3584 KB P10: xblbak (00061C00, 00001C00) 3584 KB P11: xbl_config (00080000, 00000100) 128 KB P12: xbl_configbak (00080100, 00000100) 128 KB P13: tz (000A0000, 00002000) 4 MB P14: tzbak (000C0000, 00002000) 4 MB P15: rpm (000E0000, 00000400) 512 KB P16: rpmbak (00100000, 00000400) 512 KB P17: hyp (00120000, 00004000) 8 MB P18: hypbak (00140000, 00004000) 8 MB P19: boot (00144000, 00030000) 96 MB P20: bootbak (00174000, 00030000) 96 MB P21: cache (001A4000, 00080000) 256 MB P22: keymaster (00240000, 00000400) 512 KB P23: keymasterbak (00240400, 00000400) 512 KB P24: cmnlib (00240800, 00000400) 512 KB P25: cmnlib64 (00240C00, 00000400) 512 KB P26: cmnlibbak (00241000, 00000400) 512 KB P27: cmnlib64bak (00241400, 00000400) 512 KB P28: mdtpsecapp (00241800, 00002000) 4 MB P29: mdtpsecappbak (00243800, 00002000) 4 MB P30: mdtp (00245800, 00010000) 32 MB P31: mdtpbak (00255800, 00010000) 32 MB P32: modem (00265800, 00080000) 256 MB P33: dsp (002E5800, 00020000) 64 MB P34: dspbak (00305800, 00020000) 64 MB P35: abl (00325800, 00000800) 1024 KB P36: ablbak (00326000, 00000800) 1024 KB P37: ddr (00326800, 00000800) 1024 KB P38: bluetooth (00327000, 00000800) 1024 KB P39: bluetoothbak (00327800, 00000800) 1024 KB P40: ssd (00340000, 00000010) 8 KB P41: dtbo (00340010, 0000C000) 24 MB P42: dtbobak (0034C010, 0000C000) 24 MB P43: recovery (00360000, 00020000) 64 MB P44: recoverybak (00380000, 00020000) 64 MB P45: imagefv (003A0000, 00001000) 2048 KB P46: imagefvbak (003A1000, 00001000) 2048 KB P47: uefisecapp (003A2000, 00001000) 2048 KB P48: uefisecappbak (003A3000, 00001000) 2048 KB P49: persist (003A4000, 00010000) 32 MB P50: metadata (003B4000, 00008000) 16 MB P51: misc (003BC000, 00000800) 1024 KB P52: keystore (003BC800, 00000400) 512 KB P53: devcfg (003BCC00, 00000100) 128 KB P54: devcfgbak (003BCD00, 00000100) 128 KB P55: qupfw (003BCE00, 000000A0) 80 KB P56: qupfwbak (003BCEA0, 000000A0) 80 KB P57: frp (003BCF40, 00000400) 512 KB P58: rawdump (003BD340, 00040000) 128 MB P59: devinfo (00400000, 00000008) 4 KB P60: dip (00400008, 00000800) 1024 KB P61: apdp (00420000, 00000200) 256 KB P62: spunvm (00420200, 00004000) 8 MB P63: splash (00424200, 00010520) 32.64 MB P64: limits (00440000, 00000008) 4 KB P65: toolsfv (00440008, 00000800) 1024 KB P66: logfs (00460000, 00004000) 8 MB P67: cateloader (00464000, 00001000) 2048 KB P68: logdump (00465000, 00020000) 64 MB P69: vbmeta (004A0000, 00000080) 64 KB P70: vbmetabak (004A0080, 00000080) 64 KB P71: storsec (004A0100, 00000100) 128 KB P72: multiimgoem (004A0200, 00000040) 32 KB P73: multiimgqti (004A0240, 00000040) 32 KB P74: secdata (004A0280, 00000032) 25 KB P75: catefv (004A02B8, 00000400) 512 KB P76: catecontentfv (004A06B8, 00000800) 1024 KB P77: uefivarstore (004A0EB8, 00000400) 512 KB P78: DRIVER (004C0000, 00010000) 32 MB P79: fsg (004E0000, 00001000) 2048 KB P80: fsc (00500000, 00000100) 128 KB P81: system (00500100, 00C7E000) 6.246 GB P82: vendor (0117E100, 00322000) 1604 MB P83: odm (014A0100, 00080000) 256 MB P84: userdata (01520100, 05F5BEDF) 47.68 GB Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC8aP_modemst1_0xa028_0x1000_01_03_2021_15_42_48.b in file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.0; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC8aP_modemst2_0xb028_0x1000_01_03_2021_15_42_48.b in file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.0; FW: 1.24. Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC8aP_fsg_0x4e0000_0x1000_01_03_2021_15_42_48.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.0; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 5243136 Number of sectors : 13099008 Build ID : PKQ1.190714.001 Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : trinket-user 9 PKQ1.190714.001 eng.root.20200426.214856 release-keys --------------------------------------------------------------- Reset operation finished |
03-02-2021, 11:14 | #5 (permalink) |
Member: 37521 Status: Offline Thanks Meter: 50 | no , I have only modemst1, modemst2, ext_csd may be clk ,cmd resistor is not ok someone tell that i have to shot clk resistor for phone to work if clk line is not good phone goes to qdloader 9008 is that true...i will test it. any other solution. |
03-06-2021, 15:24 | #11 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: HP Mnla,Philippines Age: 38
Member: 247410 Status: Offline Thanks Meter: 161 | Quote:
bro can you share pinout for medusa thanks | |
