LS777 zvc no power after unlock Hi, LS777 ZVC after unlock solution done ok with Medusa PRO (write carrier/modem) not power on and PC can't recognize Any help will be appreciated Thanks in advance BR Log of connection after the unlock process --------------------------------------------------------------- Welcome to Medusa Pro Software version 2.1.6. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Gemalto e-gate Smart Card 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB (15032.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147346132A41CBA1C3A15D9 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 10.4 Product serial number : (hex) 1CBA1C3A Manufacturing date : 01/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file Connect successful. --------------------------------------------------------------- SW: 2.1.6; FW: 1.24. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002C000) 88 MB P02: aboot (00030000, 00001000) 2048 KB P03: abootbak (00031000, 00001000) 2048 KB P04: tz (00032000, 00001000) 2048 KB P05: tzbak (00033000, 00001000) 2048 KB P06: sbl1 (00034000, 00000800) 1024 KB P07: sbl1bak (00034800, 00000800) 1024 KB P08: rpm (00035000, 00000400) 512 KB P09: rpmbak (00035400, 00000400) 512 KB P10: devcfg (00035800, 00000400) 512 KB P11: devcfgbak (00035C00, 00000400) 512 KB P12: cmnlib (00036000, 00000400) 512 KB P13: cmnlibbak (00036400, 00000400) 512 KB P14: cmnlib64 (00036800, 00000400) 512 KB P15: cmnlib64bak (00036C00, 00000400) 512 KB P16: keymaster (00037000, 00000400) 512 KB P17: keymasterbak (00037400, 00000400) 512 KB P18: spare1 (00037800, 00000400) 512 KB P19: spare2 (00037C00, 00000400) 512 KB P20: persistent (00038000, 00000400) 512 KB P21: devinfo (00038400, 00000800) 1024 KB P22: spare3 (00038C00, 00003400) 6.5 MB P23: modemst1 (0003C000, 00000C00) 1536 KB P24: modemst2 (0003CC00, 00000C00) 1536 KB P25: mcfg (0003D800, 00002000) 4 MB P26: fsc (0003F800, 00000400) 512 KB P27: ssd (0003FC00, 00000400) 512 KB P28: fsg (00040000, 00000C00) 1536 KB P29: spare4 (00040C00, 00003400) 6.5 MB P30: dsp (00044000, 00008000) 16 MB P31: ftm (0004C000, 00004000) 8 MB P32: misc (00050000, 00004000) 8 MB P33: drm (00054000, 00004000) 8 MB P34: sns (00058000, 00004000) 8 MB P35: fota (0005C000, 00005000) 10 MB P36: sec (00061000, 00000400) 512 KB P37: keystore (00061400, 00000400) 512 KB P38: rct (00061800, 00000400) 512 KB P39: encrypt (00061C00, 00000400) 512 KB P40: eksst (00062000, 00000400) 512 KB P41: apdp (00062400, 00000400) 512 KB P42: msadp (00062800, 00000400) 512 KB P43: dpo (00062C00, 00000400) 512 KB P44: DDR (00063000, 00000400) 512 KB P45: spare5 (00063400, 00000C00) 1536 KB P46: boot (00064000, 00010000) 32 MB P47: laf (00074000, 00010000) 32 MB P48: lafbak (00084000, 00010000) 32 MB P49: recovery (00094000, 00010000) 32 MB P50: recoverybak (000A4000, 00010000) 32 MB P51: factory (000B4000, 0001C000) 56 MB P52: raw_resources (000D0000, 00002000) 4 MB P53: raw_resourcesbak (000D2000, 00002000) 4 MB P54: persist (000D4000, 00010000) 32 MB P55: mpt (000E4000, 00004000) 8 MB P56: carrier (000E8000, 00014000) 40 MB P57: system (000FC000, 00740000) 3712 MB P58: cache (0083C000, 00268000) 1232 MB P59: userdata (00AA4000, 0127AFDE) 9.24 GB P60: grow (01D1EFDE, 00000001) 512 b Backuping modemst1 partition... Opening file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.6; FW: 1.24. Backuping modemst2 partition... Opening file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.6; FW: 1.24. Backuping fsg partition... Opening file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.1.6; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : ab800000 bytes Device sector size : 512 bytes Partition offset : 1032192 Number of sectors : 7602176 Device Manufacturer : lge Device Platform : msm8937 Build ID : NRD90U Display Build ID : NRD90U Release ID : 7.0 Device Model : LG-LS777 Device Name : sf340_spr_us Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : sf340_spr_us-user 7.0 NRD90U 1808821114d5b release-keys --------------------------------------------------------------- |
