05-09-2020, 13:39 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,047 | LUMIA 520 repair error Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Nokia Model : Lumia_520(RM914) SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/NOKIA_LUMIA_520(RM914)_EMMC.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : 4 MHz Connecting... Device : Toshiba eMMC 008G92 Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 11010030303847393200611EB68211D7 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 008G92 Product revision : 0.0 Product serial number : (hex) 611EB682 Manufacturing date : 01/2014 --------------------------------------------------------------- CSD Info CSD : D00E00320F5903FFFFFFFFEF92400045 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 1 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/008G92_09_05_2020_13_22_51.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00001000) 2048 KB P01: DPP (00001000, 00004000) 8 MB P02: MODEM_FSG (00005000, 00001800) 3072 KB P03: SSD (00007000, 00000020) 16 KB P04: SBL1 (00008000, 00000BB8) 1500 KB P05: SBL2 (00009000, 00000BB8) 1500 KB P06: SBL3 (0000A000, 00001000) 2048 KB P07: UEFI (0000B000, 00001388) 2500 KB P08: RPM (0000D000, 000003E8) 500 KB P09: TZ (0000E000, 000003E8) 500 KB P10: WINSECAPP (0000F000, 00000400) 512 KB P11: BACKUP_SBL1 (00010000, 00000BB8) 1500 KB P12: BACKUP_SBL2 (00011000, 00000BB8) 1500 KB P13: BACKUP_SBL3 (00012000, 00001000) 2048 KB P14: BACKUP_UEFI (00013000, 00001388) 2500 KB P15: BACKUP_RPM (00015000, 000003E8) 500 KB P16: BACKUP_TZ (00016000, 000003E8) 500 KB P17: BACKUP_WINSECAPP (00017000, 00000400) 512 KB P18: UEFI_BS_NV (00018000, 00000200) 256 KB P19: UEFI_NV (00019000, 00000200) 256 KB P20: PLAT (0001A000, 00004000) 8 MB P21: EFIESP (00020000, 00020000) 64 MB P22: MODEM_FS1 (00040000, 00001800) 3072 KB P23: MODEM_FS2 (00042000, 00001800) 3072 KB P24: UEFI_RT_NV (00044000, 00000200) 256 KB P25: UEFI_RT_NV_RPMB (00045000, 00000100) 128 KB P26: MMOS (00046000, 0002C680) 88.81 MB P27: MainOS (00074000, 0039DCAB) 1852 MB P28: Data (00414000, 00A7BFDF) 5.242 GB Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/NOKIA_LUMIA_520(RM914)_EMMC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing DPP partition... Done. Writing MODEM_FSG partition... Done. Writing SSD partition... Done. Writing SBL1 partition... Done. Writing SBL2 partition... Done. Writing SBL3 partition... Done. Writing UEFI partition... Done. Writing RPM partition... Done. Writing TZ partition... Done. Writing WINSECAPP partition... Done. Writing BACKUP_SBL1 partition... Done. Writing BACKUP_SBL2 partition... Done. Writing BACKUP_SBL3 partition... Done. Writing BACKUP_UEFI partition... Done. Writing BACKUP_RPM partition... Done. Writing BACKUP_TZ partition... Done. Writing BACKUP_WINSECAPP partition... Done. Writing UEFI_BS_NV partition... Done. Writing UEFI_NV partition... Done. Writing PLAT partition... Done. Writing EFIESP partition... Done. Writing MODEM_FS1 partition... Done. Writing MODEM_FS2 partition... Done. Writing UEFI_RT_NV partition... Done. Writing UEFI_RT_NV_RPMB partition... Done. Writing MMOS partition... Done. Writing MainOS partition... ERROR[012]: Write error. At sector 0 Attempting to write... Disconnected. |
