03-04-2020, 07:53 | #16 (permalink) |
Crazy Poster Join Date: Oct 2015 Location: Earth
Member: 2480515 Status: Offline Thanks Meter: 48 | SONY M4 E2303 Emmc Pinout Here This is the Sony E2303 Pinout Link https://drive.google.com/file/d/1Yjc...ew?usp=sharing This is Medusa Log Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G1e Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48384731650503CAA1551A8203 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G1e Product revision : 0.3 Product serial number : (hex) CAA1551A Manufacturing date : 08/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 10043392 Number of sectors : 5225984 Device Manufacturer : Sony Device Platform : msm8916 Build ID : 26.3.A.1.33 Display Build ID : 26.3.A.1.33 Release ID : 6.0.1 Device Model : E2303 Device Name : Xperia M4 Aqua Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : tulip_ss-user 6.0.1 1.0.J.0.0 174 test-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H8G1e_21_12_2017_00_16_43.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.0; FW: 1.22. P00: GPT (00000000, 00000100) 128 KB P01: TA (00000100, 00001000) 2048 KB P02: sbl1 (00001100, 00000400) 512 KB P03: s1sbl (00001500, 00000200) 256 KB P04: aboot (00001700, 00000800) 1024 KB P05: rpm (00001F00, 00000400) 512 KB P06: tz (00002300, 00000400) 512 KB P07: hyp (00002700, 00000400) 512 KB P08: alt_sbl1 (00002B00, 00000400) 512 KB P09: alt_s1sbl (00002F00, 00000200) 256 KB P10: alt_aboot (00003100, 00000800) 1024 KB P11: alt_rpm (00003900, 00000400) 512 KB P12: alt_tz (00003D00, 00000400) 512 KB P13: alt_hyp (00004100, 00000400) 512 KB P14: fsg (00006000, 00000C00) 1536 KB P15: modemst1 (00008000, 00000C00) 1536 KB P16: modemst2 (0000A000, 00000C00) 1536 KB P17: persist (0000C000, 00010000) 32 MB P18: modem (0001C000, 00020000) 64 MB P19: boot (0003C000, 00014000) 40 MB P20: rdimage (00050000, 00010000) 32 MB P21: FOTAKernel (00060000, 00014000) 40 MB P22: ssd (00074000, 00000010) 8 KB P23: DDR (00074010, 00000040) 32 KB P24: config (00074050, 00000400) 512 KB P25: LTALabel (00074450, 00008000) 16 MB P26: apps_log (0007E000, 00004000) 8 MB P27: oem (00082000, 0007C000) 248 MB P28: cache (000FE000, 00064000) 200 MB P29: userdata (00162000, 00832000) 4.098 GB P30: system (00994000, 004FBE00) 2552 MB Backuping TA partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/H8G1e_TA_0x100_0x1000_21_12_2017_00_16_43.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.5.0; FW: 1.22. Analyzing Trim Area (TA)... Ok TA IMEI: 35451207445725 Lock status: locked Yigal71 |
The Following User Says Thank You to yigal71 For This Useful Post: |
