07-29-2021, 08:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: POland
Member: 60746 Status: Offline Thanks Meter: 56 | Medusa pro 2 connect problem [Answered] i have problem with connect via medusa pro 2 Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[009]: EXT CSD error(check voltage/bus mode) ------------------------------------------------------------------------------------- there is no problem with medusa pro: Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC CUTA42 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 1501004355544134320023D249BF9625 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : CUTA42 Full name one from : KLMCG2UCTA-B041 Product revision : 0.0 Product serial number : (hex) 23D249BF Manufacturing date : 09/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x78) 01111000 Boot partition enable : User area (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20357120 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/CUTA42_29_07_2021_08_50_22.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.2; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: bota0 (00002000, 00002000) 4 MB P02: bota1 (00004000, 00004000) 8 MB P03: efs (00008000, 0000A000) 20 MB P04: sec_efs (00012000, 0000A000) 20 MB P05: cpefs (0001C000, 00004000) 8 MB P06: bota2 (00020000, 00004000) 8 MB P07: cm (00024000, 00004000) 8 MB P08: m9kefs1 (00028000, 00002000) 4 MB P09: m9kefs2 (0002A000, 00002000) 4 MB P10: m9kefs3 (0002C000, 00002000) 4 MB P11: nad_refer (0002E000, 00000800) 1024 KB P12: param (0002E800, 00004000) 8 MB P13: up_param (00032800, 00004000) 8 MB P14: misc (00036800, 00001000) 2048 KB P15: boot (00037800, 00012000) 36 MB P16: recovery (00049800, 0001A800) 53 MB P17: dtb (00064000, 00004000) 8 MB P18: dtbo (00068000, 00004000) 8 MB P19: radio (0006C000, 00016800) 45 MB P20: persistent (00082800, 00000400) 512 KB P21: steady (00082C00, 00002000) 4 MB P22: vbmeta (00084C00, 00000400) 512 KB P23: bota3 (00085000, 00000400) 512 KB P24: reserved2 (00085400, 00002C00) 5.5 MB P25: system (00088000, 0099C000) 4.805 GB P26: vendor (00A24000, 00148000) 656 MB P27: product (00B6C000, 000F8000) 496 MB P28: cache (00C64000, 000C8000) 400 MB P29: omr (00D2C000, 00019000) 50 MB P30: cp_debug (00D45000, 00002800) 5 MB P31: nad_fw (00D47800, 0000A000) 20 MB P32: userdata (00D51800, 06728000) 51.58 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CUTA42_efs_0x8000_0xa000_29_07_2021_08_50_22.bin file... Reading. Please wait... Done. Elapsed time 00:00:08 SW: 2.2.2; FW: 1.24. Backuping cpefs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CUTA42_cpefs_0x1c000_0x4000_29_07_2021_08_50_22.bi n file... Reading. Please wait... Done. Elapsed time 00:00:03 SW: 2.2.2; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 557056 Number of sectors : 10076160 Build ID : QP1A.190711.020 Display Build ID : QP1A.190711.020.A405FNXXS3BTI3 Release ID : 10 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : a40xx-user 10 QP1A.190711.020 A405FNXXS3BTI3 release-keys --------------------------------------------------------------- i used the same jig adapter sometimes connect medusa pro 2 with succ, but usually not https://files.fm/f/3bfhxp9pc https://files.fm/f/kgrant5z5 |
07-29-2021, 08:37 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Please, share with us the logs on the unsuccessful connection and explain your problem in more detail. We will help you. |
07-29-2021, 09:09 | #3 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | i have samsung a40 connect w/o problem via jig (modified 160 ohm resistors) with medusa pro box but when i try to connect it with medusa pro 2 box usually w\o succ i just move jig from medusa pro to medusa pro 2 box |
07-29-2021, 09:16 | #4 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Quote:
Have you tried lowering the voltage and reconnecting? Or did you exclusively use 3.3 volts for the connection? Also note that the length of the data lines should be no more than 3-5cm. | |
07-29-2021, 09:26 | #5 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | please look the photos in first post connect wires are the same for both boxes with medusa pro connet succ with medusa pro 2 doesnt i think that there is some problem with medusa pro2 pin connector i tried also solder wires directly from medusa pro2 pin connector - the same problem one or two times i had succ connecting with medusa pro 2 box - but i need remove and put again medusa pin 2 connector so many times..... Last edited by zaskar; 07-29-2021 at 09:31. |
07-29-2021, 09:35 | #6 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | with medusa pro box - connet succ every time - look: Welcome to Medusa Pro Software version 2.2.2. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: O2Micro CCID SC Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 3.3V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC CUTA42 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 1501004355544134320023D249BF9625 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : CUTA42 Full name one from : KLMCG2UCTA-B041 Product revision : 0.0 Product serial number : (hex) 23D249BF Manufacturing date : 09/2019 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x78) 01111000 Boot partition enable : User area (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20357120 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/CUTA42_29_07_2021_10_34_51.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.2; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: bota0 (00002000, 00002000) 4 MB P02: bota1 (00004000, 00004000) 8 MB P03: efs (00008000, 0000A000) 20 MB P04: sec_efs (00012000, 0000A000) 20 MB P05: cpefs (0001C000, 00004000) 8 MB P06: bota2 (00020000, 00004000) 8 MB P07: cm (00024000, 00004000) 8 MB P08: m9kefs1 (00028000, 00002000) 4 MB P09: m9kefs2 (0002A000, 00002000) 4 MB P10: m9kefs3 (0002C000, 00002000) 4 MB P11: nad_refer (0002E000, 00000800) 1024 KB P12: param (0002E800, 00004000) 8 MB P13: up_param (00032800, 00004000) 8 MB P14: misc (00036800, 00001000) 2048 KB P15: boot (00037800, 00012000) 36 MB P16: recovery (00049800, 0001A800) 53 MB P17: dtb (00064000, 00004000) 8 MB P18: dtbo (00068000, 00004000) 8 MB P19: radio (0006C000, 00016800) 45 MB P20: persistent (00082800, 00000400) 512 KB P21: steady (00082C00, 00002000) 4 MB P22: vbmeta (00084C00, 00000400) 512 KB P23: bota3 (00085000, 00000400) 512 KB P24: reserved2 (00085400, 00002C00) 5.5 MB P25: system (00088000, 0099C000) 4.805 GB P26: vendor (00A24000, 00148000) 656 MB P27: product (00B6C000, 000F8000) 496 MB P28: cache (00C64000, 000C8000) 400 MB P29: omr (00D2C000, 00019000) 50 MB P30: cp_debug (00D45000, 00002800) 5 MB P31: nad_fw (00D47800, 0000A000) 20 MB P32: userdata (00D51800, 06728000) 51.58 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CUTA42_efs_0x8000_0xa000_29_07_2021_10_34_51.bin file... Reading. Please wait... Done. Elapsed time 00:00:08 SW: 2.2.2; FW: 1.24. Backuping cpefs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/CUTA42_cpefs_0x1c000_0x4000_29_07_2021_10_34_51.bi n file... Reading. Please wait... Done. Elapsed time 00:00:03 SW: 2.2.2; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 557056 Number of sectors : 10076160 Build ID : QP1A.190711.020 Display Build ID : QP1A.190711.020.A405FNXXS3BTI3 Release ID : 10 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : a40xx-user 10 QP1A.190711.020 A405FNXXS3BTI3 release-keys --------------------------------------------------------------- |
07-29-2021, 09:41 | #7 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | here is the log that i connect with succ with medusa pro box then disconnecting then change box to medusa pro 2 then tried to connect with medusa pro 2 ...... |
07-29-2021, 09:43 | #8 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | We are grateful for your feedback. We will share this information with our developers to troubleshoot and resolve this issue. As soon as there is a solution, we will immediately give you an answer in this thread. Also we will try to simulate this problem on our connectors and our boxes. |
08-02-2021, 08:16 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Try connecting as shown in this picture Be sure to install resistors R1, R2. Set the voltage to no more than 1.8V Last edited by Octopus box; 08-02-2021 at 08:48. |
08-02-2021, 08:20 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | In this case, we need a photo of how he connected, there are many options for how he could do it. To connect to BGA254 UFS flash via Pin Connector you need to connect a flash drive as shown Last edited by Octopus box; 08-02-2021 at 08:49. |
08-04-2021, 15:28 | #12 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | this is emmc i use resistors 160 ohm with 1.8 conecting failed the problem is : I CANNOT CONNECT WITH MEDUSA PRO 2, but with medusa pro conecting w\o problem with medusa pro 2 always : ERROR[009]: EXT CSD error(check voltage/bus mode) |
08-04-2021, 16:02 | #15 (permalink) |
Member: 60746 Status: Offline Thanks Meter: 56 | Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[009]: EXT CSD error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[009]: EXT CSD error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[009]: EXT CSD error(check voltage/bus mode) |
