10-27-2020, 14:50 | #1 (permalink) |
Junior Member Join Date: Sep 2020 Location: turkey Age: 39
Member: 2968254 Status: Offline Sonork: firat ayrılmazkardes Thanks Meter: 0 | Medusa pro 2 samsung g610 jtg problem [Answered] Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : G610F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_G610F_EMMC_BY_STARKRIMES.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[009]: EXT CSD error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : G610F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_G610F_EMMC_BY_STARKRIMES.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[009]: EXT CSD error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : G610F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_G610F_EMMC_BY_STARKRIMES.srf Voltage : 3.2V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Unknown eMMC ����� Page size : 512 B Block size : 512 B Block count : 4294967295 Size : 2048.00 GB (2097152.00 MB) --------------------------------------------------------------- CID Info CID : FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Manufacturer ID : 0XFF Device/BGA : Device (removable) OEM/Application ID : 0XFF Product name : ÿÿÿÿÿ Product revision : 15.15 Product serial number : (hex) FFFFFFFF Manufacturing date : 15/2012 --------------------------------------------------------------- CSD Info CSD : FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CSD structure : SPEC version : Allocated by MMCA Data read access time1: 80 ms TRAN speed : 0 MHz READ block length : 32768 Bytes WP group enable : YES PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : YES --------------------------------------------------------------- EXTCSD Info Erase block size : 130560 Kbytes Boot1 size : 32640 Kbytes Boot2 size : 32640 Kbytes RPMB size : 32640 Kbytes Partition config : (0xFF) 11111111 Boot partition enable : User area Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0xFF) 11111111 Boot bus width : Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : RST_n function : (0x03) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 4261674496 Kbytes Partitions attribute : 0xFF Part setting completed: 0xFF GP partition 1 size : 255.5 MB GP partition 2 size : 255.5 MB GP partition 3 size : 255.5 MB GP partition 4 size : 255.5 MB Enhanced area size : (0xFF80000) 255.5 MB Enhanced area start : (0xFFFFFE00) 4096 MB Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/�����_26_10_2020_21_48_14.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.4; FW: 2.00. ERROR[011]: Read error. At sector 0. Disconnected. |
10-27-2020, 15:03 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Looks like You've an issue with connection, please try to add resistors 150 Ohm on CMD->VCCQ and D0->VCCQ. Besides, try to set lower Bus speed |
