Member: 217679
Thanks Meter: 95 | xt1792 Motorola G5S xt1792 boot dead repair: Quote:
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : 15 MHz
Connecting...
Device : Samsung eMMC QX13MB
Page size : 512 B
Block size : 512 B
Block count : 61071360
Size : 29.12 GB (29820.00 MB)
CID Info
CID : 150100515831334D4207A2EB0086749D
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : QX13MB
Product revision : 0.7
Product serial number : (hex) A2EB0086
Manufacturing date : 07/2017
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x38) 00111000
Boot partition enable : User area
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 15261696 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX13MB_15_10_2018_11_53_51.bin.
Connect successful.
SW: 1.6.8; FW: 1.24.
P00: GPT (00000000, 00020000) 128 KB
P01: sbl1 (00020000, 00080000) 512 KB
P02: rpm (000A0000, 00040000) 256 KB
P03: tz (00120000, 001C0000) 1792 KB
P04: devcfg (00320000, 00020000) 128 KB
P05: aboot (00360000, 00180000) 1536 KB
P06: cmnlib (004E0000, 00040000) 256 KB
P07: cmnlib64 (00520000, 00040000) 256 KB
P08: keymaster (00560000, 00040000) 256 KB
P09: prov (005A0000, 00030000) 192 KB
P10: sbl1bak (005E0000, 00080000) 512 KB
P11: rpmbak (00660000, 00040000) 256 KB
P12: tzbak (006E0000, 001C0000) 1792 KB
P13: devcfgbak (008E0000, 00020000) 128 KB
P14: abootbak (00920000, 00180000) 1536 KB
P15: cmnlibbak (00AA0000, 00040000) 256 KB
P16: cmnlib64bak (00AE0000, 00040000) 256 KB
P17: keymasterbak (00B20000, 00040000) 256 KB
P18: provbak (00B60000, 00030000) 192 KB
P19: modem (00BA0000, 06400000) 100 MB
P20: fsc (06FA0000, 00000400) 1024 b
P21: ssd (06FA0400, 00002000) 8 KB
P22: dsp (06FA2400, 01000000) 16 MB
P23: DDR (07FC0000, 00008000) 32 KB
P24: sec (07FC8000, 00004000) 16 KB
P25: utags (07FE0000, 00080000) 512 KB
P26: utagsBackup (08060000, 00080000) 512 KB
P27: modemst1 (080E0000, 00200000) 2048 KB
P28: modemst2 (082E0000, 00200000) 2048 KB
P29: fsg (084E0000, 00800000) 8 MB
P30: persist (08CE0000, 02000000) 32 MB
P31: frp (0ACE0000, 00080000) 512 KB
P32: cid (0AD60000, 00020000) 128 KB
P33: logo (0AD80000, 01000000) 16 MB
P34: carrier (0BD80000, 01000000) 16 MB
P35: metadata (0CD80000, 00080000) 512 KB
P36: kpan (0CE00000, 00800000) 8 MB
P37: boot (0D600000, 01000000) 16 MB
P38: recovery (0E600000, 01019000) 16.1 MB
P39: misc (0F620000, 00100000) 1024 KB
P40: limits (0F720000, 00008000) 32 KB
P41: mota (0F740000, 00080000) 512 KB
P42: dip (0F7C0000, 00100000) 1024 KB
P43: syscfg (0F8C0000, 00080000) 512 KB
P44: logs (0F940000, 00200000) 2048 KB
P45: apdp (0FB40000, 00040000) 256 KB
P46: msadp (0FB80000, 00040000) 256 KB
P47: dpo (0FBC0000, 00002000) 8 KB
P48: padA (0FBE0000, 00420000) 4.125 MB
P49: sp (10000000, 00800000) 8 MB
P50: hw (10800000, 00800000) 8 MB
P51: oem (11000000, 29000000) 656 MB
P52: cache (3A000000, 10000000) 256 MB
P53: system (4A000000, D8000000) 3456 MB
P54: userdata (122000000, 625BFBE00) 24.59 GB
Backuping Gpt partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX13MB_Gpt_0x0_0x100_15_10_2018_11_53_51.bin file...
Reading. Please wait... Done.
Elapsed time 00:00:00
Backuping Cid partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX13MB_Cid_0x56b00_0x100_15_10_2018_11_53_51.bin file...
