You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. Only registered members may post questions, contact other members or search our database of over 8 million posts.
Wiko Freddy – Read/Write/Full Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. dahmani)
10.or GV1.0.82 (Android 8.1.0) – Read/Write/Full Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. PIJUSH DAS)
Asus Zenfone Selfie Z00UD (Android6.0.1) – Read/Write/Full Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. PIJUSH DAS)
Samsung SM-A705MN (U5) – Read/Write/Full Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. yosbel182us)
- Added support for the following models via eMMC:
Asus X00TD (Zenfone Max Pro M1_64GB) - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. PIJUSH DAS)
Samsung SM-A217F - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. PIJUSH DAS)
Samsung SM-A600G (DXU8CTG1) - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. PIJUSH DAS)
Samsung SM-T230 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files By (thanks to Mr. PIJUSH DAS)
Xiaomi Redmi Note 8T - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. Tecnoservicel)
Meizu M6s (M712H) - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. Wolodya)
Nokia Lumia 710 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. Wolodya)
Samsung GT-I9060 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. Wolodya)
Samsung SM-T585 - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. Wolodya)
Xiaomi Redmi 5A - Read/Write/Erase, Easy Repair, Partition Manager, Constructor for Repair Files (thanks to Mr. Wolodya)
The equipment to work with NAND:
"SOLDERING ADAPTER NAND TSOP-48, LGA-52, LGA-60" available after October 17, please stay tuned.
"Socket NAND SOCKET TSOP-48" and "NAND SOCKET LGA52, LGA-60" will be available soon...
- Improved writing in PPN NAND.
- Added support for ONFI NAND (8b/16b bus width):
READ (with and without spare data)
WRITE (with and without spare data)
ERASE
- Supported devices:
ATO
AFND5608S1, AFND5608U1, AFND5616S1, AFND5616U1, AFND1208S1, AFND1208U1, AFND1216S1, AFND1216U1, AFND1G08U3
- Added support for the following models via USB:
The Following User Says Thank You to Gsm-Boss. For This Useful Post:
hi i want to ask will medusa pro box work with this new module
and is it possible update medusa pro to medusa pro 2
is it need to buy new hardware
this module is compatible with every Medusa box generations considering their hardware capabilities. to upgrade from Medusa to MPro II there is a special upgrade kit available
