06-22-2021, 05:28 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 46
Member: 152445 Status: Offline Thanks Meter: 16 | please help [Answered] Switched to user area. Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition spmfw... from E0800 to 18 Done. Writing partition scp1... from E1000 to 11D Done. Writing partition sspm_1... from E1800 to 345 Done. Writing partition boot... from E5000 to 5162 ERROR[008]: Data TX error. |
06-22-2021, 07:45 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Please, post here full Software log of operation. We will check it. Quote:
06-22-2021, 08:26 | #3 (permalink) |
Member: 152445 Status: Offline Thanks Meter: 16 | Welcome to Medusa Pro Software version 2.2.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC QX63AB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515836334142006AB0072DA7DB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX63AB Product revision : 0.0 Product serial number : (hex) 6AB0072D Manufacturing date : 10/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX63AB_22_06_2021_02_12_38.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.1; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: boot_para (00002000, 00000800) 1024 KB P02: para (00002800, 00000400) 512 KB P03: efuse (00002C00, 00000400) 512 KB P04: nvram (00003000, 00020000) 64 MB P05: efs (00023000, 00004000) 8 MB P06: sec_efs (00027000, 00004000) 8 MB P07: bota (0002B000, 0000A800) 21 MB P08: param (00035800, 00002000) 4 MB P09: up_param (00037800, 00002000) 4 MB P10: expdb (00039800, 0000A000) 20 MB P11: frp (00043800, 00000800) 1024 KB P12: nvcfg (00044000, 00010000) 32 MB P13: nvdata (00054000, 00020000) 64 MB P14: metadata (00074000, 00010000) 32 MB P15: protect1 (00084000, 00004000) 8 MB P16: protect2 (00088000, 00004000) 8 MB P17: seccfg (0008C000, 00004000) 8 MB P18: persist (00090000, 00018000) 48 MB P19: persistent (000A8000, 00000400) 512 KB P20: misc (000A8400, 00003C00) 7.5 MB P21: sec1 (000AC000, 00001000) 2048 KB P22: proinfo (000AD000, 00001800) 3072 KB P23: md1img (000AE800, 00032000) 100 MB P24: spmfw (000E0800, 00000800) 1024 KB P25: scp1 (000E1000, 00000800) 1024 KB P26: sspm_1 (000E1800, 00000800) 1024 KB P27: lk (000E2000, 00001000) 2048 KB P28: steady (000E3000, 00002000) 4 MB P29: boot (000E5000, 00010000) 32 MB P30: recovery (000F5000, 00010000) 32 MB P31: dtbo (00105000, 00004000) 8 MB P32: tee1 (00109000, 00003000) 6 MB P33: vendor (0010C000, 000E0000) 448 MB P34: product (001EC000, 000D8000) 432 MB P35: system (002C4000, 006D8000) 3504 MB P36: vbmeta (0099C000, 00004000) 8 MB P37: cache (009A0000, 000C8000) 400 MB P38: omr (00A68000, 00018000) 48 MB P39: userdata (00A80000, 02FBE000) 23.87 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX63AB_efs_0x23000_0x4000_22_06_2021_02_12_38.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.2.1; FW: 2.00. Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX63AB_nvdata_0x54000_0x20000_22_06_2021_02_12_38. bin file... Reading. Please wait... Done. Elapsed time 00:00:21 SW: 2.2.1; FW: 2.00. RPMB: Counter of the successful data write requests = 93430. Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 2.2.1; FW: 2.00. Disconnected. Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC QX63AB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515836334142006AB0072DA7DB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX63AB Product revision : 0.0 Product serial number : (hex) 6AB0072D Manufacturing date : 10/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX63AB_22_06_2021_02_13_15.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.1; FW: 2.00. RPMB: Counter of the successful data write requests = 93430. Writing EXT_CSD succesfully complete! Disconnected. Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC QX63AB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515836334142006AB0072DA7DB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX63AB Product revision : 0.0 Product serial number : (hex) 6AB0072D Manufacturing date : 10/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX63AB_22_06_2021_02_14_00.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.1; FW: 2.00. RPMB: Counter of the successful data write requests = 93430. Please select file. Partition table was not found. Partition table was not found. Boot config succesfully changed! Disconnected. Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC QX63AB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515836334142006AB0072DA7DB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX63AB Product revision : 0.0 Product serial number : (hex) 6AB0072D Manufacturing date : 10/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX63AB_22_06_2021_02_15_25.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.1; FW: 2.00. RPMB: Counter of the successful data write requests = 93430. --------------------------------------------------------------- Selected scatter file: C:/Users/julian/Desktop/10s/A107M U4 MT6765 Scatter Firmware Android 10 [A107MUBU4BTDE]/A107MUBU4BTDE Scatter Firmware Android 10/MT6765_Android_EMMC_scatter.txt. Scatter file type 2. Opened input file: C:/Users/julian/Desktop/10s/A107M U4 MT6765 Scatter Firmware Android 10 [A107MUBU4BTDE]/A107MUBU4BTDE Scatter Firmware Android 10/preloader_s96116ca1.bin Found 5 eMMC supported CID: eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QD63MB eMMC CID : 150100514436334D42 eMMC Vendor ID : 70 (Kingston eMMC) eMMC Model ID : 0001 eMMC Name : FMBCEA eMMC CID : 700100464D42434541 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : GD6BMB eMMC CID : 150100474436424D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QX63MB eMMC CID : 150100515836334D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QX63AB eMMC CID : 150100515836334142 --------------------------------------------------------------- Selected scatter file: C:/Users/julian/Desktop/10s/A107M U4 MT6765 Scatter Firmware Android 10 [A107MUBU4BTDE]/A107MUBU4BTDE Scatter Firmware Android 10/MT6765_Android_EMMC_scatter.txt. Scatter file type 2. Opened input file: C:/Users/julian/Desktop/10s/A107M U4 MT6765 Scatter Firmware Android 10 [A107MUBU4BTDE]/A107MUBU4BTDE Scatter Firmware Android 10/preloader_s96116ca1.bin Found 5 eMMC supported CID: eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QD63MB eMMC CID : 150100514436334D42 eMMC Vendor ID : 70 (Kingston eMMC) eMMC Model ID : 0001 eMMC Name : FMBCEA eMMC CID : 700100464D42434541 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : GD6BMB eMMC CID : 150100474436424D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QX63MB eMMC CID : 150100515836334D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QX63AB eMMC CID : 150100515836334142 Writing. Please wait... Switched to user area. Writing MBR... ERROR[012]: Write error. At sector 0. Disconnected. Get Measurements error. Reloading... Loading firmware. Please wait... Done. Selected eMMC interface. Socket validation failed. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC QX63AB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515836334142006AB0072DA7DB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX63AB Product revision : 0.0 Product serial number : (hex) 6AB0072D Manufacturing date : 10/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX63AB_22_06_2021_02_16_45.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.1; FW: 2.00. RPMB: Counter of the successful data write requests = 93430. --------------------------------------------------------------- Selected scatter file: C:/Users/julian/Desktop/10s/A107M U4 MT6765 Scatter Firmware Android 10 [A107MUBU4BTDE]/A107MUBU4BTDE Scatter Firmware Android 10/MT6765_Android_EMMC_scatter.txt. Scatter file type 2. Opened input file: C:/Users/julian/Desktop/10s/A107M U4 MT6765 Scatter Firmware Android 10 [A107MUBU4BTDE]/A107MUBU4BTDE Scatter Firmware Android 10/preloader_s96116ca1.bin Found 5 eMMC supported CID: eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QD63MB eMMC CID : 150100514436334D42 eMMC Vendor ID : 70 (Kingston eMMC) eMMC Model ID : 0001 eMMC Name : FMBCEA eMMC CID : 700100464D42434541 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : GD6BMB eMMC CID : 150100474436424D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QX63MB eMMC CID : 150100515836334D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QX63AB eMMC CID : 150100515836334142 Writing. Please wait... Switched to user area. Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Cancelling operation. Please wait... Switch error!!! ERROR[012]: Write error. At sector 0 Disconnected. Get Measurements error. Reloading... Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[009]: EXT CSD error(check voltage/bus mode) Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... ERROR[001]: Can not connect. No target device present. Get Measurements error. Reloading... Loading firmware. Please wait... Done. Selected eMMC interface. Socket validation failed. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC QX63AB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515836334142006AB0072DA7DB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX63AB Product revision : 0.0 Product serial number : (hex) 6AB0072D Manufacturing date : 10/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX63AB_22_06_2021_02_18_46.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.1; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: boot_para (00002000, 00000800) 1024 KB P02: para (00002800, 00000400) 512 KB P03: efuse (00002C00, 00000400) 512 KB P04: nvram (00003000, 00020000) 64 MB P05: efs (00023000, 00004000) 8 MB P06: sec_efs (00027000, 00004000) 8 MB P07: bota (0002B000, 0000A800) 21 MB P08: param (00035800, 00002000) 4 MB P09: up_param (00037800, 00002000) 4 MB P10: expdb (00039800, 0000A000) 20 MB P11: frp (00043800, 00000800) 1024 KB P12: nvcfg (00044000, 00010000) 32 MB P13: nvdata (00054000, 00020000) 64 MB P14: metadata (00074000, 00010000) 32 MB P15: protect1 (00084000, 00004000) 8 MB P16: protect2 (00088000, 00004000) 8 MB P17: seccfg (0008C000, 00004000) 8 MB P18: persist (00090000, 00018000) 48 MB P19: persistent (000A8000, 00000400) 512 KB P20: misc (000A8400, 00003C00) 7.5 MB P21: sec1 (000AC000, 00001000) 2048 KB P22: proinfo (000AD000, 00001800) 3072 KB P23: md1img (000AE800, 00032000) 100 MB P24: spmfw (000E0800, 00000800) 1024 KB P25: scp1 (000E1000, 00000800) 1024 KB P26: sspm_1 (000E1800, 00000800) 1024 KB P27: lk (000E2000, 00001000) 2048 KB P28: steady (000E3000, 00002000) 4 MB P29: boot (000E5000, 00010000) 32 MB P30: recovery (000F5000, 00010000) 32 MB P31: dtbo (00105000, 00004000) 8 MB P32: tee1 (00109000, 00003000) 6 MB P33: vendor (0010C000, 000E0000) 448 MB P34: product (001EC000, 000D8000) 432 MB P35: system (002C4000, 006D8000) 3504 MB P36: vbmeta (0099C000, 00004000) 8 MB P37: cache (009A0000, 000C8000) 400 MB P38: omr (00A68000, 00018000) 48 MB P39: userdata (00A80000, 02FBDFDF) 23.87 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX63AB_efs_0x23000_0x4000_22_06_2021_02_18_46.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.2.1; FW: 2.00. Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX63AB_nvdata_0x54000_0x20000_22_06_2021_02_18_46. bin file... Reading. Please wait... Done. Elapsed time 00:00:21 SW: 2.2.1; FW: 2.00. RPMB: Counter of the successful data write requests = 93430. Save to C:/Users/julian/Desktop/10s/Samsung eMMC QX63AB_22_06_2021__02_19_37.mpt file... Reading partition GPT... Done. Reading is finished. SW: 2.2.1; FW: 2.00. --------------------------------------------------------------- Selected scatter file: C:/Users/julian/Desktop/10s/A107M U4 MT6765 Scatter Firmware Android 10 [A107MUBU4BTDE]/A107MUBU4BTDE Scatter Firmware Android 10/MT6765_Android_EMMC_scatter.txt. Scatter file type 2. Opened input file: C:/Users/julian/Desktop/10s/A107M U4 MT6765 Scatter Firmware Android 10 [A107MUBU4BTDE]/A107MUBU4BTDE Scatter Firmware Android 10/preloader_s96116ca1.bin Found 5 eMMC supported CID: eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QD63MB eMMC CID : 150100514436334D42 eMMC Vendor ID : 70 (Kingston eMMC) eMMC Model ID : 0001 eMMC Name : FMBCEA eMMC CID : 700100464D42434541 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : GD6BMB eMMC CID : 150100474436424D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QX63MB eMMC CID : 150100515836334D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QX63AB eMMC CID : 150100515836334142 Writing. Please wait... Switched to boot area partition 1. ERROR[012]: Write error. At sector 0 Disconnected. Loading firmware. Please wait... Done. Selected UFS interface. Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC QX63AB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515836334142006AB0072DA7DB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX63AB Product revision : 0.0 Product serial number : (hex) 6AB0072D Manufacturing date : 10/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX63AB_22_06_2021_02_21_32.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.1; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: boot_para (00002000, 00000800) 1024 KB P02: para (00002800, 00000400) 512 KB P03: efuse (00002C00, 00000400) 512 KB P04: nvram (00003000, 00020000) 64 MB P05: efs (00023000, 00004000) 8 MB P06: sec_efs (00027000, 00004000) 8 MB P07: bota (0002B000, 0000A800) 21 MB P08: param (00035800, 00002000) 4 MB P09: up_param (00037800, 00002000) 4 MB P10: expdb (00039800, 0000A000) 20 MB P11: frp (00043800, 00000800) 1024 KB P12: nvcfg (00044000, 00010000) 32 MB P13: nvdata (00054000, 00020000) 64 MB P14: metadata (00074000, 00010000) 32 MB P15: protect1 (00084000, 00004000) 8 MB P16: protect2 (00088000, 00004000) 8 MB P17: seccfg (0008C000, 00004000) 8 MB P18: persist (00090000, 00018000) 48 MB P19: persistent (000A8000, 00000400) 512 KB P20: misc (000A8400, 00003C00) 7.5 MB P21: sec1 (000AC000, 00001000) 2048 KB P22: proinfo (000AD000, 00001800) 3072 KB P23: md1img (000AE800, 00032000) 100 MB P24: spmfw (000E0800, 00000800) 1024 KB P25: scp1 (000E1000, 00000800) 1024 KB P26: sspm_1 (000E1800, 00000800) 1024 KB P27: lk (000E2000, 00001000) 2048 KB P28: steady (000E3000, 00002000) 4 MB P29: boot (000E5000, 00010000) 32 MB P30: recovery (000F5000, 00010000) 32 MB P31: dtbo (00105000, 00004000) 8 MB P32: tee1 (00109000, 00003000) 6 MB P33: vendor (0010C000, 000E0000) 448 MB P34: product (001EC000, 000D8000) 432 MB P35: system (002C4000, 006D8000) 3504 MB P36: vbmeta (0099C000, 00004000) 8 MB P37: cache (009A0000, 000C8000) 400 MB P38: omr (00A68000, 00018000) 48 MB P39: userdata (00A80000, 02FBDFDF) 23.87 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX63AB_efs_0x23000_0x4000_22_06_2021_02_21_32.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.2.1; FW: 2.00. Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX63AB_nvdata_0x54000_0x20000_22_06_2021_02_21_32. bin file... Reading. Please wait... Done. Elapsed time 00:00:21 SW: 2.2.1; FW: 2.00. RPMB: Counter of the successful data write requests = 93430. --------------------------------------------------------------- Selected scatter file: C:/Users/julian/Desktop/10s/A107M U4 MT6765 Scatter Firmware Android 10 [A107MUBU4BTDE]/A107MUBU4BTDE Scatter Firmware Android 10/MT6765_Android_EMMC_scatter.txt. Scatter file type 2. Opened input file: C:/Users/julian/Desktop/10s/A107M U4 MT6765 Scatter Firmware Android 10 [A107MUBU4BTDE]/A107MUBU4BTDE Scatter Firmware Android 10/preloader_s96116ca1.bin Found 5 eMMC supported CID: eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QD63MB eMMC CID : 150100514436334D42 eMMC Vendor ID : 70 (Kingston eMMC) eMMC Model ID : 0001 eMMC Name : FMBCEA eMMC CID : 700100464D42434541 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : GD6BMB eMMC CID : 150100474436424D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QX63MB eMMC CID : 150100515836334D42 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QX63AB eMMC CID : 150100515836334142 Writing. Please wait... Switched to user area. Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Cancelling operation. Please wait... Cancelling operation. Please wait... Cancelling operation. Please wait... Cancelling operation. Please wait... Cancelling operation. Please wait... Cancelling operation. Please wait... Cancelling operation. Please wait... Switch error!!! ERROR[012]: Write error. At sector 0 Disconnected. Get Measurements error. Reloading... Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC QX63AB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515836334142006AB0072DA7DB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX63AB Product revision : 0.0 Product serial number : (hex) 6AB0072D Manufacturing date : 10/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX63AB_22_06_2021_02_23_10.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.1; FW: 2.00. P00: GPT (00000000, 00002000) 4 MB P01: boot_para (00002000, 00000800) 1024 KB P02: para (00002800, 00000400) 512 KB P03: efuse (00002C00, 00000400) 512 KB P04: nvram (00003000, 00020000) 64 MB P05: efs (00023000, 00004000) 8 MB P06: sec_efs (00027000, 00004000) 8 MB P07: bota (0002B000, 0000A800) 21 MB P08: param (00035800, 00002000) 4 MB P09: up_param (00037800, 00002000) 4 MB P10: expdb (00039800, 0000A000) 20 MB P11: frp (00043800, 00000800) 1024 KB P12: nvcfg (00044000, 00010000) 32 MB P13: nvdata (00054000, 00020000) 64 MB P14: metadata (00074000, 00010000) 32 MB P15: protect1 (00084000, 00004000) 8 MB P16: protect2 (00088000, 00004000) 8 MB P17: seccfg (0008C000, 00004000) 8 MB P18: persist (00090000, 00018000) 48 MB P19: persistent (000A8000, 00000400) 512 KB P20: misc (000A8400, 00003C00) 7.5 MB P21: sec1 (000AC000, 00001000) 2048 KB P22: proinfo (000AD000, 00001800) 3072 KB P23: md1img (000AE800, 00032000) 100 MB P24: spmfw (000E0800, 00000800) 1024 KB P25: scp1 (000E1000, 00000800) 1024 KB P26: sspm_1 (000E1800, 00000800) 1024 KB P27: lk (000E2000, 00001000) 2048 KB P28: steady (000E3000, 00002000) 4 MB P29: boot (000E5000, 00010000) 32 MB P30: recovery (000F5000, 00010000) 32 MB P31: dtbo (00105000, 00004000) 8 MB P32: tee1 (00109000, 00003000) 6 MB P33: vendor (0010C000, 000E0000) 448 MB P34: product (001EC000, 000D8000) 432 MB P35: system (002C4000, 006D8000) 3504 MB P36: vbmeta (0099C000, 00004000) 8 MB P37: cache (009A0000, 000C8000) 400 MB P38: omr (00A68000, 00018000) 48 MB P39: userdata (00A80000, 02FBDFDF) 23.87 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX63AB_efs_0x23000_0x4000_22_06_2021_02_23_10.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.2.1; FW: 2.00. Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX63AB_nvdata_0x54000_0x20000_22_06_2021_02_23_10. bin file... Reading. Please wait... Done. Elapsed time 00:00:21 SW: 2.2.1; FW: 2.00. RPMB: Counter of the successful data write requests = 93430. Selected pit file: C:/Users/julian/Desktop/10s/A10S_LTN_OPEN.pit Open file "C:/Users/julian/Desktop/10s/BL_A107MUBU5BUC5_CL20275752_QB38565574_REV00_user_ low_ship_MULTI_CERT.tar.md5". Switched to user area. Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition bootloader... from 0 to 18F Done. Switched to user area. Writing partition efuse... from 2C00 to 2 Done. Writing partition param... from 35800 to 446 Done. Writing partition up_param... from 37800 to 446 Done. Writing partition lk... from E2000 to 649 Done. Writing is finished. SW: 2.2.1; FW: 2.00. Open file "C:/Users/julian/Desktop/10s/AP_A107MUBU5BUC5_CL20275752_QB38565574_REV00_user_ low_ship_MULTI_CERT_meta_RKEY_OS10.tar.md5". Open file "C:/Users/julian/Desktop/10s/CP_A107MUBU5BUC6_CP18327332_CL20275752_QB38592343_ REV00_user_low_ship_MULTI_CERT.tar.md5". Open file "C:/Users/julian/Desktop/10s/CSC_OMC_OWO_A107MOWO5BUC5_CL21150498_QB38577461_RE V00_user_low_ship_MULTI_CERT.tar.md5". Switched to user area. Writing MBR... ERROR[012]: Write error. At sector 0. Disconnected. |
06-22-2021, 16:02 | #6 (permalink) |
Member: 152445 Status: Offline Thanks Meter: 16 | I have tried with other devices such as the a31s, a 10s, a10, a21s and others, I only removed the frp, I try to do the flashing process and the devices are totally dead, only with other tools I manage to recover them I bought the tool 5 days ago, thinking that it was more powerful than its competition and I am disappointed, because it lacks many options to recover the devices. I appreciate if prota helps at least to repair that device, thank you team for the support and I remain attentive |
06-22-2021, 16:20 | #7 (permalink) |
Member: 152445 Status: Offline Thanks Meter: 16 | It only works well with old devices, and I flashed redmi note 9s (curtana), redmi note 9 pro and mi 9 xiaomi with the same result turned off, after being in operation and only to change the firmware version for a global one. In my opinion, it is time to update the tool to the new devices since those that are supported according to the support are devices that have already left the market. |
