05-21-2017, 11:22 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | Wourld First Dead Boot Repaire On Samsung SM-G532G By MEDUSA !! Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Hynix eMMC H8G4u Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 90014A48384734759201330475EF347F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4u Product revision : 0.1 Product serial number : (hex) 330475EF Manufacturing date : 03/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4u_21_05_2017_15_38_02.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.6; FW: 1.16. P00: GPT (00000000, 00002000) P01: bota0 (00002000, 00002000) P02: nvram (00004000, 00004000) P03: lk (00008000, 00001000) P04: bota1 (00009000, 00001000) P05: secro (0000A000, 00003800) P06: seccfg (0000D800, 00000400) P07: efuse (0000DC00, 00000400) P08: tee1 (0000E000, 00003000) P09: bota2 (00011000, 00003000) P10: efs (00014000, 00004000) P11: nvdata (00018000, 00010000) P12: param (00028000, 00004000) P13: recovery (0002C000, 00008000) P14: boot (00034000, 00008000) P15: md1img (0003C000, 00010000) P16: md1dsp (0004C000, 00002000) P17: keystore (0004E000, 00004000) P18: omekeystore (00052000, 00001C00) P19: proinfo (00053C00, 00001400) P20: para (00055000, 00000400) P21: persistent (00055400, 00000400) P22: steady (00055800, 00000800) P23: protect1 (00056000, 00004000) P24: protect2 (0005A000, 00004000) P25: reserve2 (0005E000, 00002000) P26: system (00060000, 00604000) P27: cache (00664000, 000C8000) P28: hidden (0072C000, 0001E000) P29: userdata (0074A000, 00744000) Selected pit file: E:/Samsung/G532G/PIT-SM-G532G-15-03-2017_09-07-10.pit Open file "E:/Samsung/G532G/G532G_DXU1AQA4_OLB1AQB1/G532G_DXU1AQA4_OLB1AQB1/BL_G532GDXU1AQA4_CL10452964_QB12351285_REV00_user_ low_ship_MULTI_CERT.tar.md5". Open file "E:/Samsung/G532G/G532G_DXU1AQA4_OLB1AQB1/G532G_DXU1AQA4_OLB1AQB1/AP_G532GDXU1AQA4_CL10452964_QB12351285_REV00_user_ low_ship_MULTI_CERT.tar.md5". Open file "E:/Samsung/G532G/G532G_DXU1AQA4_OLB1AQB1/G532G_DXU1AQA4_OLB1AQB1/CP_G532GDXU1AQA2_CL10452964_QB12334190_REV00_user_ low_ship_MULTI_CERT.tar.md5". Open file "E:/Samsung/G532G/G532G_DXU1AQA4_OLB1AQB1/G532G_DXU1AQA4_OLB1AQB1/CSC_OLB_G532GOLB1AQB1_CL10452964_QB12606901_REV00_ user_low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOTLOADER... Done. Switched to user area. Writing partition lk... Done. Writing partition secro... Done. Writing partition efuse... Done. Writing partition tee1... Done. Writing partition PARAM... Done. Writing partition recovery... Done. Writing partition boot... Done. Writing partition md1img... Done. Writing partition md1dsp... Done. Writing partition system... Done. Writing partition cache... Done. Writing partition hidden... Done. Writing partition userdata... Done. Writing is finished. SW: 1.3.6; FW: 1.16. Last edited by Medusa Box; 05-21-2017 at 12:49. |
The Following 9 Users Say Thank You to reaz.com For This Useful Post: |
05-23-2017, 08:06 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. You can also find or request firmwares here: http://forum.gsmhosting.com/vbb/f664...15/index3.html. |
05-23-2017, 09:07 | #4 (permalink) | |
Member: 310155 Status: Offline Thanks Meter: 1,313 | Quote:
download BL_G532GDXU1AQA4_CL10452964_QB12351285_REV00_user_ low_ship_MULTI_CERT.tar | |
The Following 2 Users Say Thank You to reaz.com For This Useful Post: |
05-23-2017, 13:48 | #5 (permalink) | |
Freak Poster Join Date: Aug 2005 Location: India Age: 43
Member: 169384 Status: Offline Thanks Meter: 110 | Quote:
Welcome to Medusa Pro Software version 1.3.6. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: FT SCR2000 2 Reader #3: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532F SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Hynix eMMC H8G4u Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 90014A483847347592011D8430682421 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4u Product revision : 0.1 Product serial number : (hex) 1D843068 Manufacturing date : 02/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4u_23_05_2017_17_23_56.bin. Connect successful. --------------------------------------------------------------- SW: 1.3.6; FW: 1.16. P00: GPT (00000000, 00002000) P01: BOTA0 (00002000, 00002000) P02: nvram (00004000, 00004000) P03: lk (00008000, 00001000) P04: BOTA1 (00009000, 00001000) P05: secro (0000A000, 00003800) P06: seccfg (0000D800, 00000400) P07: efuse (0000DC00, 00000400) P08: tee1 (0000E000, 00003000) P09: BOTA2 (00011000, 00003000) P10: EFS (00014000, 00004000) P11: nvdata (00018000, 00010000) P12: PARAM (00028000, 00004000) P13: recovery (0002C000, 00008000) P14: boot (00034000, 00008000) P15: md1img (0003C000, 00010000) P16: md1dsp (0004C000, 00002000) P17: keystore (0004E000, 00004000) P18: omekeystore (00052000, 00001C00) P19: proinfo (00053C00, 00001400) P20: para (00055000, 00000400) P21: PERSISTENT (00055400, 00000400) P22: STEADY (00055800, 00000800) P23: protect1 (00056000, 00004000) P24: protect2 (0005A000, 00004000) P25: RESERVE2 (0005E000, 00002000) P26: system (00060000, 00604000) P27: cache (00664000, 000C8000) P28: hidden (0072C000, 0001E000) P29: userdata (0074A000, 00744000) Selected pit file: C:/Users/sofrware1/Downloads/PIT-SM-G532G-15-03-2017_09-07-10/PIT-SM-G532G-15-03-2017_09-07-10.pit Open file "K:/SM-G532/BL_G532GDDU1AQA6_CL10211537_QB12309832_REV00_user_ low_ship_MULTI_CERT.tar". Open file "K:/SM-G532/AP_G532GDDU1AQA6_CL10211537_QB12309832_REV00_user_ low_ship_MULTI_CERT.tar". Open file "K:/SM-G532/CP_G532GDDU1APL1_NOT_DEFINE_CL422608_QB5391800.tar ". Open file "K:/SM-G532/CSC_ODD_G532GODD1BPL5_CL10211537_QB12013242_REV00_ user_low_ship_MULTI_CERT.tar". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOTLOADER... Done. Switched to user area. Writing partition lk... Done. Writing partition secro... Done. Writing partition efuse... Done. Writing partition tee1... Done. Writing partition PARAM... Done. Writing partition recovery... Done. Writing partition boot... Done. Writing partition md1img... Done. Writing partition md1dsp... Done. Writing partition system... Done. Writing partition cache... Done. Writing partition hidden... Done. Writing partition userdata... Done. Writing is finished. SW: 1.3.6; FW: 1.16. | |
The Following 3 Users Say Thank You to gokul2005 For This Useful Post: |
