05-29-2017, 02:21 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Taguig CT Age: 42
Member: 488875 Status: Offline Sonork: 100.1626294 Thanks Meter: 1,129 | We have MedusaPro box, It's possible to use old medusa tool in medusapro box? i have one here,i've tried to used medusapro box to old medusa tool but can't connect. if it's possible to use this old medusa tool/update to medusapro box, How? i've tried to repair xperia X10i but Not supported in medusapro tool. Last edited by Medusa Box; 05-29-2017 at 06:05. |
05-29-2017, 06:17 | #4 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. To Repair this device, do the following: 1. Solder all necessary JTAG wires, make each of them as short as possible (max. 3-5 CM length). 2. Reboot the PC. 3. Run Medusa Software. 4. Select "EasyRepair" Mode. 5. Press "EasyRepair" button. 6. Select repair type (Dead Boot Repair + Security Recalculation) and press "Next"/"Repair" button. 7. Connect device (soldered JTAG wires) to Box. 8. Connect USB cable to phone and to PC (connect cable only to PC motherboard USB port, don't use USB hubs, this is important for stable connection!). Try to repeat connect procedure a few times with different selected JATG speed. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
05-29-2017, 07:29 | #6 (permalink) | ||
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
05-29-2017, 08:28 | #7 (permalink) | |
Member: 488875 Status: Offline Sonork: 100.1626294 Thanks Meter: 1,129 | pinout is good b'coz medusapro software can read but it says not supported. Quote:
05-29-2017, 08:38 | #8 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Try to connect the device using old Medusa Software v.2.6.1.5 with different JTAG speed values and post here the result. |
