Member: 361836
Thanks Meter: 27 | [Help] LG D295 is now failed hello sir, I need help for this device LG D295. when my first attempt to repair the boot loader of the device, it was successful and I was able to put into fastboot mode but during writing firmware via Octopus LG tool. I failed on writing firmware data that result into deadboot again. here is the log of bootloader repair via medusa at first attempt. Quote:
Welcome to Medusa Pro Software version 1.3.7.
Started.
Reader #0: Generic EMV Smartcard Reader 0
Reader #1: USB CCID Smart Card Reader 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : LG
Model : D295
SRF : D:/My Programs/Medusa Pro Software/firmwareFolder/LG_D295.SRF
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
ERROR[001]: Can not connect. No target device present.
Model Settings:
Interface : eMMC
Brand : LG
Model : D295
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Device : Hynix eMMC H4G1d
Page size : 512 B
Block size : 512 B
Block count : 7634944
CID Info
CID : 90014A4834473164040504A2F5341285
Manufacturer ID : 0X90
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4A
Product name : H4G1d
Product revision : 0.5
Product serial number : (hex) 4A2F534
Manufacturing date : 01/2015
CSD Info
CSD : D02701320F5903FFFFFFFFEF8A4040D3
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.6 (for MMC v4.5, v4.51)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : 00000000
Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 1908736 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file D:/My Programs/Medusa Pro Software/EXT_CSD Backups/H4G1d_31_05_2017_14_06_14.bin.
Connect successful.
SW: 1.3.7; FW: 1.17.
P00: GPT (00000000, 00002000)
P01: modem (00002000, 00020000)
P02: sbl1 (00022000, 00000800)
P03: rpm (00022800, 00000400)
P04: tz (00022C00, 00000400)
P05: sdi (00023000, 00000400)
P06: aboot (00023400, 00001000)
P07: rpmb (00024400, 00000400)
P08: tzb (00024800, 00000400)
P09: abootb (00024C00, 00001000)
P10: pad (00025C00, 00001000)
P11: modemst1 (00026C00, 00001800)
P12: modemst2 (00028400, 00001800)
P13: misc (00029C00, 00008000)
P14: persist (00032000, 00010000)
P15: laf (00042000, 0000B000)
P16: boot (0004E000, 0000B000)
P17: recovery (00059000, 0000B000)
P18: fsg (00064000, 00001800)
P19: fsc (00066000, 00000400)
P20: ssd (00066400, 00000400)
P21: DDR (00068000, 00000400)
P22: encrypt (0006A000, 00000400)
P23: rct (0006A400, 00000400)
P24: drm (0006C000, 00004000)
P25: sns (00070000, 00004000)
P26: factory (00074000, 0000A000)
P27: fota (0007E000, 00010000)
P28: sbl1b (0008E000, 00000800)
P29: mpt (0008E800, 00010000)
P30: cust (000A0000, 00019000)
P31: eksst (000BA000, 00000400)
P32: system (000BC000, 002EDC00)
P33: cache (003A9C00, 0007D000)
P34: userdata (00426C00, 00310000)
P35: grow (00738000, 0000FFDF)
Repairing from file "D:/My Programs/Medusa Pro Software/firmwareFolder/LG_D295.SRF".
Write data verification is enabled.
Writing GPT partition... Done.
Writing modem partition... Done.
Writing sbl1 partition... Done.
Writing rpm partition... Done.
Writing tz partition... Done.
Writing sdi partition... Done.
Writing aboot partition... Done.
Writing rpmb partition... Done.
Writing tzb partition... Done.
Writing abootb partition... Done.
Writing pad partition... Done.
Writing modemst1 partition... Done.
Writing modemst2 partition... Done.
Writing CustomMisc partition... Done.
Smart Repair is successfully complete.
Disconnected.
| and here is the 2nd attempt for repairing bootloader but failed due to some error now. the connection is carefully attached to the board. Quote:
Started.
Model Settings:
Interface : eMMC
Brand : LG
Model : D295
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file D:/My Programs/Medusa Pro Software/EXT_CSD Backups/H4G1d_31_05_2017_22_00_12.bin.
Connect successful.
Write verification error 1. Possible reasons: damaged or write protected eMMC.
Disconnected. | |
