06-01-2020, 15:08 | #1 (permalink) |
Insane Poster Join Date: Aug 2010 Location: Spain , Madrid .
Member: 1360157 Status: Offline Sonork: 623-221-328 Thanks Meter: 3 | Incorrectly creates partitions.[Answered] Code: Model Settings: Interface : eMMC Voltage : 3.2V Bus Mode : 4 bits Bus speed : Auto Connecting... Device : Samsung eMMC BJTD4R Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100424A5444345200C111F035657B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : BJTD4R Product revision : 0.0 Product serial number : (hex) C111F035 Manufacturing date : 06/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/BJTD4R_01_06_2020_18_03_44.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.0; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: bota0 (00002000, 00002000) 4 MB P02: na (00004000, 00002000) 4 MB P03: efs (00006000, 0000A000) 20 MB P04: cpefs (00010000, 00004000) 8 MB P05: cm (00014000, 00004000) 8 MB P06: ?????? (00018000, 000F2000) 484 MB P07: nad????? (0001E000, 00000800) 1024 KB P08: recovery (00033800, 00013000) 38 MB P09: b??? (00046800, 00004000) 8 MB P10: steady (00061400, 00002000) 4 MB P11: reserved2 (00063400, 00000C00) 1536 KB P12: system (00064000, 007C0000) 3968 MB P13: cache (00824000, 0007D000) 250 MB P14: userdata (008C9000, 03173000) 24.72 GB P15: d_fw (8C8FFF00000000, FF74100100000001) 1.558e+10 GB P16: ?????? (F0000000010000A, F10000000000F0F2) 30.12 MB P17: ??????0 (F0000000010000C, F10000000000F0F2) 30.12 MB P18: ????? (F0000000010800E, F1000000000FF0E5) 510.1 MB P19: ???0 (F00000000208002, F0FFFFFFFFFFF0F2) 1.718e+10 GB P20: ???@ (F00000000208003, F1000000000FF0F1) 510.1 MB P21: ????? (F0000000040800A, F1000000002070E7) 1038 MB P22: ?????????@ (F00000000600001, F1000000000030F1) 6.118 MB P23: ???? (A078F30F00000000, 60070EF100000001) 9.474e+08 GB P24: ? (B078FC0F00000000, 5F870CF100000001) 9.463e+08 GB P25: ?debug (B0F8FE0F00000000, 4F8703F100000001) 9.416e+08 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/BJTD4R_efs_0x6000_0xa000_01_06_2020_18_03_44.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.1.0; FW: 1.24. |
06-01-2020, 15:24 | #2 (permalink) |
Member: 1360157 Status: Offline Sonork: 623-221-328 Thanks Meter: 3 | This pit file. https://drive.google.com/file/d/1fPq...ew?usp=sharing |
