04-06-2020, 11:33 | #1 (permalink) |
Crazy Poster Join Date: Aug 2013
Member: 2013587 Status: Offline Thanks Meter: 9 | medusa pro werite file Error Emmc [Answered] and update emmc Error Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC VTU00M Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 15010056545530304DFC3D39868641FB Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : VTU00M Full name : KMVTU000LM-B503 Product revision : 15.12 Product serial number : (hex) 3D398686 Manufacturing date : 04/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/VTU00M_06_04_2020_03_07_23.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.5; FW: 1.24. The same area. Opening D:/GT-I8552-daryaigsm/userarea.bin file... Write data verification is enabled. Writing. Please wait... ERROR[007]: Command fail. At sector 57920. |
04-06-2020, 21:49 | #2 (permalink) | |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
The Following User Says Thank You to hitech care For This Useful Post: |
04-06-2020, 22:47 | #3 (permalink) | |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,100 | Quote:
The Following 3 Users Say Thank You to Pijush Das For This Useful Post: |
04-07-2020, 21:40 | #4 (permalink) |
Member: 2013587 Status: Offline Thanks Meter: 9 | tanks pless hellp The problem persists im use emate x donoot werite file & xml ... & updaet emcc only conect emmc box Model Settings: Interface : eMMC Voltage : 3.2V Bus Mode : 8 bits Bus speed : Auto Connecting... Device : Samsung eMMC KJS00M Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 1501004B4A5330304D0307EF64EC5051 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : KJS00M Full name : KMKJS000VM-B309 Product revision : 0.3 Product serial number : (hex) 7EF64EC Manufacturing date : 05/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE78A404057 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 1024 Kbytes Boot2 size : 1024 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/KJS00M_08_04_2020_01_04_32.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.7; FW: 1.24. The same area. Opening D:/GT-I8552-daryaigsm/userarea.bin file... Write data verification is enabled. Writing. Please wait... ERROR[007]: Command fail. At sector 302528. Attempting to write... Disconnected. Last edited by znasser; 04-07-2020 at 21:46. |
04-07-2020, 23:28 | #5 (permalink) | |
The Following User Says Thank You to Pijush Das For This Useful Post: |
04-08-2020, 00:30 | #6 (permalink) |
Member: 1902789 Status: Offline Thanks Meter: 1,100 | Here is GT-I8552_ISP.srf Samsung_GT-I8552_ISP.srf |
04-08-2020, 16:13 | #7 (permalink) |
Member: 2013587 Status: Offline Thanks Meter: 9 | tank you sultion Im tested But the problem persists Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC KJS00M Page size : 512 B Block size : 512 B Block count : 7626752 Size : 3724.00 MB --------------------------------------------------------------- CID Info CID : 1501004B4A5330304D0307EF64EC5051 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : KJS00M Full name : KMKJS000VM-B309 Product revision : 0.3 Product serial number : (hex) 7EF64EC Manufacturing date : 05/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE78A404057 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1904640 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/KJS00M_08_04_2020_19_35_00.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.7; FW: 1.24. The same area. Opening D:/GT-I8552-daryaigsm/userarea.bin file... Write data verification is disabled. Writing. Please wait... ERROR[007]: Command fail. At sector 32. -------------------------------------------------------------------------------------- Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC KJS00M Page size : 512 B Block size : 512 B Block count : 7626752 Size : 3724.00 MB --------------------------------------------------------------- CID Info CID : 1501004B4A5330304D0307EF64EC5051 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : KJS00M Full name : KMKJS000VM-B309 Product revision : 0.3 Product serial number : (hex) 7EF64EC Manufacturing date : 05/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE78A404057 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1904640 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/KJS00M_08_04_2020_19_39_44.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.7; FW: 1.24. Please select file. Erasing. Please wait... Done. SW: 2.0.7; FW: 1.24. Switched to boot area partition 1. Erasing. Please wait... Done. SW: 2.0.7; FW: 1.24. Switched to boot area partition 2. Erasing. Please wait... Done. SW: 2.0.7; FW: 1.24. Switched to user area. Opening D:/GT-I8552-daryaigsm/userarea.bin file... Write data verification is disabled. Writing. Please wait... ERROR[007]: Command fail. At sector 0. -------------------------------------------------------------------------------- pazzz help me |
04-08-2020, 19:08 | #8 (permalink) | |
04-08-2020, 20:21 | #9 (permalink) |
Member: 2013587 Status: Offline Thanks Meter: 9 | not werite srf & dump not werite srf file & dump Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC KJS00M Page size : 512 B Block size : 512 B Block count : 7626752 Size : 3724.00 MB --------------------------------------------------------------- CID Info CID : 1501004B4A5330304D0307EF64EC5051 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : KJS00M Full name : KMKJS000VM-B309 Product revision : 0.3 Product serial number : (hex) 7EF64EC Manufacturing date : 05/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE78A404057 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1904640 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/KJS00M_08_04_2020_23_48_52.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.7; FW: 1.24. Repairing from file "C:/Users/Allah/Downloads/Samsung_GT-I8552_ISP.srf". Write data verification is enabled. Writing FSBL partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. |
04-08-2020, 20:28 | #10 (permalink) |
Member: 2013587 Status: Offline Thanks Meter: 9 | not write file pelzzzzzzzzzzzzz helpp Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC KJS00M Page size : 512 B Block size : 512 B Block count : 7626752 Size : 3724.00 MB --------------------------------------------------------------- CID Info CID : 1501004B4A5330304D0307EF64EC5051 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : KJS00M Full name : KMKJS000VM-B309 Product revision : 0.3 Product serial number : (hex) 7EF64EC Manufacturing date : 05/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE78A404057 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1904640 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/KJS00M_08_04_2020_23_53_01.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.7; FW: 1.24. Repairing from file "C:/Users/Allah/Desktop/Samsung_GT-I8552_ISP.srf". Write data verification is disabled. Writing FSBL partition... ERROR[007]: Command fail. At sector 1 Attempting to write... Disconnected. |
