01-21-2021, 12:12 | #1 (permalink) |
Freak Poster Join Date: Jul 2014 Location: EMMC
Member: 2228324 Status: Offline Thanks Meter: 79 | medusa question [Answered] i have problem with program when i want to write emmc firmware medusa just hang and close i dont know why i try diffrent voltage bus speed , not any chance! any idea to fix this problem? i run windows 7 64bit |
01-21-2021, 14:16 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Please post here full Software log with performed operation, we will check it. Quote:
The Following 2 Users Say Thank You to Medusa Box For This Useful Post: |
01-24-2021, 16:52 | #3 (permalink) | |
Member: 2228324 Status: Offline Thanks Meter: 79 | Quote:
here is the log: Welcome to Medusa Pro Software version 2.1.8. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Get Measurements error. Reloading... Loading firmware. Please wait... Done. Selected UFS interface. Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Full speed mode! Connecting... Device : Samsung eMMC 000000 Page size : 512 B Block size : 512 B Block count : 16777216 Size : 8.00 GB (8192.00 MB) --------------------------------------------------------------- CID Info CID : 1501003030303030300020110221004D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 000000 Product revision : 0.0 Product serial number : (hex) 20110221 Manufacturing date : 00/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DB7FE796404069 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 1024 Kbytes Boot2 size : 1024 Kbytes RPMB size : 1024 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_24_01_2021_19_19_39.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 2.00. Writing eMMC firmware from file: C:/Program Files (x86)/Medusa Pro Software/EMMC_firmwares/KMSJS000KA-B308/KMSJS000KA-B308_FW.bin... --------------------------------------- Welcome to Medusa Pro Software version 2.1.8. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 6.25 MHz Connecting to server. Please wait... Connection to server successful Full speed mode! Connecting... ERROR[009]: EXT CSD error(check voltage/bus mode) Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 6.25 MHz Full speed mode! Connecting... Device : Samsung eMMC 000000 Page size : 512 B Block size : 512 B Block count : 16777216 Size : 8.00 GB (8192.00 MB) --------------------------------------------------------------- CID Info CID : 1501003030303030300020110221004D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 000000 Product revision : 0.0 Product serial number : (hex) 20110221 Manufacturing date : 00/2013 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DB7FE796404069 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 1024 Kbytes Boot2 size : 1024 Kbytes RPMB size : 1024 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/000000_24_01_2021_19_17_56.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.8; FW: 2.00. Writing eMMC firmware from file: C:/Program Files (x86)/Medusa Pro Software/EMMC_firmwares/KMSJS000KA-B308/KMSJS000KA-B308_FW.bin... | |
01-25-2021, 10:33 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Unfortunately, your flash drive stops responding when the firmware is written, it cannot be restored. Software departure bug fixed, please stay tuned for future updates. |
