Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 08-05-2020, 16:56   #1 (permalink)
Member: 971926
Thanks Meter: 13
Mi play dead after write by vendor [Answered]
I'm with 4 mi play and all after writing by vendor they didn't start anymore and only appears MTK USB
before writing they were stuck in the logo.:
Welcome to Medusa Pro Software version 2.1.1.
Started.
Reader #0: Alcor Micro USB Smart Card Reader 0
Reader #1: USB CCID Smart Card Reader 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 2.4V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Hynix eMMC hC8aP
Page size : 512 B
Block size : 512 B
Block count : 122142720
Size : 58.24 GB (59640.00 MB)
CID Info
CID : 90014A68433861503E034876805C2689
Manufacturer ID : 0X90
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4A
Product name : hC8aP
Product revision : 0.3
Product serial number : (hex) 4876805C
Manufacturing date : 02/2019
CSD Info
CSD : D02700328F5903FFFFFFFFEF8E400043
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 16384 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 8Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x02) 00000010
Boot bus width : x8 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 30531584 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hC8aP_05_06_2020_14_47_13.bin.
Connect successful.
SW: 2.1.0; FW: 1.24.
P00: GPT (00000000, 00000040) 32 KB
P01: boot_para (00000040, 00000800) 1024 KB
P02: recovery (00000840, 00010000) 32 MB
P03: para (00010840, 00000400) 512 KB
P04: expdb (00010C40, 0000A000) 20 MB
P05: frp (0001AC40, 00000800) 1024 KB
P06: nvcfg (0001B440, 00010000) 32 MB
P07: nvdata (0002B440, 00020000) 64 MB
P08: metadata (0004B440, 00010000) 32 MB
P09: protect1 (0005B440, 00004000) 8 MB
P10: protect2 (0005F440, 00004BC0) 9.469 MB
P11: seccfg (00064000, 00004000) 8 MB
P12: persist (00068000, 00018000) 48 MB
P13: sec1 (00080000, 00001000) 2048 KB
P14: proinfo (00081000, 00001800) 3072 KB
P15: efuse (00082800, 00000400) 512 KB
P16: md1img (00082C00, 00032000) 100 MB
P17: spmfw (000B4C00, 00000800) 1024 KB
P18: scp1 (000B5400, 00000800) 1024 KB
P19: scp2 (000B5C00, 00000800) 1024 KB
P20: sspm_1 (000B6400, 00000800) 1024 KB
P21: sspm_2 (000B6C00, 00000800) 1024 KB
P22: gz1 (000B7400, 00008000) 16 MB
P23: gz2 (000BF400, 00008000) 16 MB
P24: nvram (000C7400, 00020000) 64 MB
P25: lk (000E7400, 00000800) 1024 KB
P26: lk2 (000E7C00, 00000800) 1024 KB
P27: boot (000E8400, 00010000) 32 MB
P28: logo (000F8400, 00004000) 8 MB
P29: odmdtbo (000FC400, 00008000) 16 MB
P30: tee1 (00104400, 00002800) 5 MB
P31: tee2 (00106C00, 00005400) 10.5 MB
P32: vendor (0010C000, 00180000) 768 MB
P33: cust (0028C000, 001A0000) 832 MB
P34: system (0042C000, 00600000) 3072 MB
P35: devinfo (00A2C000, 00004000) 8 MB
P36: vbmeta (00A30000, 00004000) 8 MB
P37: cache (00A34000, 000D8000) 432 MB
P38: userdata (00B0C000, 069527DF) 52.66 GB
P39: otp (0745E7DF, 00015800) 43 MB
P40: flashinfo (07473FDF, 00008000) 16 MB
Backuping nvdata partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC8aP_nvdata_0x2b440_0x20000_05_06_2020_14_47_13.b in file...
Reading. Please wait... Done.
Elapsed time 00:00:26
SW: 2.1.1; FW: 1.24.
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : 8f800000 bytes
Device sector size : 512 bytes
Partition offset : 4374528
Number of sectors : 6291456
Device Manufacturer : xiaomi
Build ID : O11019
Display Build ID : ZAL1722-lotus-build-20191220185821
Release ID : 8.1.0
Device Model : MI PLAY
Device Name : lotus
Architecture ABI : arm64-v8a
Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi
Build Description : lotus-user 8.1.0 O11019 V11.0.2.0.OFIMIXM release-keys
after writing it no longer shows the build.
even writing separate partitions, or full dump, or vendor, or srf backup it doesn't turn on:
Model Settings:
Interface : eMMC
Voltage : 2.2V
Bus Mode : 4 bits
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 8Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hC8aP_03_08_2020_17_49_51.bin.
Connect successful.
Not found
Selected scatter file: C:/Users/fehve/Downloads/ENG FIRMWARE XIAOMI Miplay/ZAL1722-Lotus-V33-O-0123_DCC/all_images/images/MT6765_Android_scatter.txt.
Scatter file type 2.
Opened input file: C:/Users/fehve/Downloads/ENG FIRMWARE XIAOMI Miplay/ZAL1722-Lotus-V33-O-0123_DCC/all_images/images/preloader_lotus.bin
No eMMC descriptions found.
Writing. Please wait...
Switched to boot area partition 1.
Writing partition preloader...
Write data verification is enabled.
Done.
Writing partition recovery... Done.
Switched to user area.
Writing partition efuse... Done.
Writing partition md1img... Done.
Writing partition spmfw... Done.
Writing partition scp1... Done.
Writing partition scp2... Done.
Writing partition sspm_1... Done.
Writing partition sspm_2... Done.
Writing partition lk... Done.
Writing partition lk2... Done.
Writing partition boot... Done.
Writing partition logo... Done.
Writing partition odmdtbo... Done.
Writing partition tee1... Done.
Writing partition tee2... Done.
Writing partition vendor... Done.
Writing partition cust... Done.
Writing partition system... Done.
Writing partition vbmeta... Done.
Writing partition cache... Done.
Writing partition userdata... Done.
Writing checksums...Done.
Writing finished.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.2V
Bus Mode : 4 bits
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 8Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hC8aP_03_08_2020_18_10_48.bin.
Connect successful.
Not found
---------------------------------------------------------------Disconnected.
Old 08-06-2020, 04:04   #2 (permalink)
suriyas1's Avatar
Member: 1351351
Thanks Meter: 277
Hello sir pls Check ur PM
Old 08-06-2020, 07:33   #3 (permalink)
Octopus support's Avatar
Member: 2891705
Thanks Meter: 2,136
Hello.
Please download and install latest software version 2.1.2 and repeat the operation once again.
Old 08-06-2020, 13:57   #4 (permalink)
Member: 971926
Thanks Meter: 13
where is version 2.1.2?
Originally Posted by Octopus support View Post
Hello.
Old 08-06-2020, 14:12   #5 (permalink)
Member: 2891705
Thanks Meter: 2,136
You can find it on Support Area (Medusa_pro/RELEASE SOFTWARE/) or go to download manager in Release software folder.
Old 08-06-2020, 16:36   #6 (permalink)
Member: 971926
Thanks Meter: 13
After version 2.1.2 write ok. turn on but same defect as before wipe data failed.
After writing vendor straight starts in recovery.
Old 08-08-2020, 02:24   #7 (permalink)
suriyas1's Avatar
Member: 1351351
Thanks Meter: 277
Give full log writen by vendor..
The Following User Says Thank You to suriyas1 For This Useful Post:
Page generated in 0.23434 seconds with 8 queries
