08-03-2020, 12:47 | #1 (permalink) |
No Life Poster Join Date: Jul 2010 Location: Not Reachable Age: 31
Member: 1351351 Status: Offline Thanks Meter: 277 | MI Play(lotus) ENG Firmware write done Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 4 bits Bus speed : Auto Connecting... Device : Hynix eMMC hC8aP Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A68433861503E0348416EDF16D3 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hC8aP Product revision : 0.3 Product serial number : (hex) 48416EDF Manufacturing date : 01/2019 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hC8aP_03_08_2020_16_49_15.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- --------------------------------------------------------------- Selected scatter file: D:/Mobiles/FIRMWARE/XIAOMI/play/ENG FIRMWARE XIAOMI Miplay/ZAL1722-Lotus-V33-O-0123_DCC/all_images/images/MT6765_Android_scatter.txt. Scatter file type 2. Opened input file: D:/Mobiles/FIRMWARE/XIAOMI/play/ENG FIRMWARE XIAOMI Miplay/ZAL1722-Lotus-V33-O-0123_DCC/all_images/images/preloader_lotus.bin Found 4 eMMC supported CID: eMMC Vendor ID : 90 (Hynix eMMC) eMMC Model ID : 4A01 eMMC Name : hB8aP> eMMC CID : 90014A68423861503E eMMC Vendor ID : 90 (Hynix eMMC) eMMC Model ID : 4A01 eMMC Name : HAG4a2 eMMC CID : 90014A484147346132 eMMC Vendor ID : 13 (Micron eMMC) eMMC Model ID : 4E01 eMMC Name : S0J9B7 eMMC CID : 13014E53304A394237 eMMC Vendor ID : 15 (Samsung eMMC) eMMC Model ID : 0001 eMMC Name : QE63MB eMMC CID : 150100514536334D42 Writing. Please wait... Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Switched to boot area partition 1. Writing partition preloader... Write data verification is enabled. Done. Switched to user area. Writing partition recovery... Done. Writing partition efuse... Done. Writing partition md1img... Done. Writing partition spmfw... Done. Writing partition scp1... Done. Writing partition scp2... Done. Writing partition sspm_1... Done. Writing partition sspm_2... Done. Writing partition lk... Done. Writing partition lk2... Done. Writing partition boot... Done. Writing partition logo... Done. Writing partition odmdtbo... Done. Writing partition tee1... Done. Writing partition tee2... Done. Writing partition vendor... Done. Writing partition cust... Done. Writing partition system... Done. Writing partition vbmeta... Done. Writing partition cache... Done. Writing partition userdata... Done. Writing checksums...Done. Writing finished. SW: 2.1.1; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 4 bits Bus speed : Auto Connecting... Device : Hynix eMMC hC8aP Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A68433861503E0348416EDF16D3 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hC8aP Product revision : 0.3 Product serial number : (hex) 48416EDF Manufacturing date : 01/2019 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hC8aP_03_08_2020_17_11_41.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.1; FW: 1.24. P00: GPT (00000000, 00000040) 32 KB P01: boot_para (00000040, 00000800) 1024 KB P02: recovery (00000840, 00010000) 32 MB P03: para (00010840, 00000400) 512 KB P04: expdb (00010C40, 0000A000) 20 MB P05: frp (0001AC40, 00000800) 1024 KB P06: nvcfg (0001B440, 00010000) 32 MB P07: nvdata (0002B440, 00020000) 64 MB P08: metadata (0004B440, 00010000) 32 MB P09: protect1 (0005B440, 00004000) 8 MB P10: protect2 (0005F440, 00004BC0) 9.469 MB P11: seccfg (00064000, 00004000) 8 MB P12: persist (00068000, 00018000) 48 MB P13: sec1 (00080000, 00001000) 2048 KB P14: proinfo (00081000, 00001800) 3072 KB P15: efuse (00082800, 00000400) 512 KB P16: md1img (00082C00, 00032000) 100 MB P17: spmfw (000B4C00, 00000800) 1024 KB P18: scp1 (000B5400, 00000800) 1024 KB P19: scp2 (000B5C00, 00000800) 1024 KB P20: sspm_1 (000B6400, 00000800) 1024 KB P21: sspm_2 (000B6C00, 00000800) 1024 KB P22: gz1 (000B7400, 00008000) 16 MB P23: gz2 (000BF400, 00008000) 16 MB P24: nvram (000C7400, 00020000) 64 MB P25: lk (000E7400, 00000800) 1024 KB P26: lk2 (000E7C00, 00000800) 1024 KB P27: boot (000E8400, 00010000) 32 MB P28: logo (000F8400, 00004000) 8 MB P29: odmdtbo (000FC400, 00008000) 16 MB P30: tee1 (00104400, 00002800) 5 MB P31: tee2 (00106C00, 00005400) 10.5 MB P32: vendor (0010C000, 00180000) 768 MB P33: cust (0028C000, 001A0000) 832 MB P34: system (0042C000, 00600000) 3072 MB P35: devinfo (00A2C000, 00004000) 8 MB P36: vbmeta (00A30000, 00004000) 8 MB P37: cache (00A34000, 000D8000) 432 MB P38: userdata (00B0C000, 069527DF) 52.66 GB P39: otp (0745E7DF, 00015800) 43 MB P40: flashinfo (07473FDF, 00008000) 16 MB Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC8aP_nvdata_0x2b440_0x20000_03_08_2020_17_11_41.b in file... Reading. Please wait... Done. Elapsed time 00:00:09 SW: 2.1.1; FW: 1.24. ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 4374528 Number of sectors : 6291456 Device Manufacturer : xiaomi Build ID : O11019 Display Build ID : ZAL1722-Lotus-V33-O-0123 Release ID : 8.1.0 Device Model : lotus Device Name : lotus Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : lotus-userdebug 8.1.0 O11019 1548249244 test-keys --------------------------------------------------------------- |
The Following User Says Thank You to suriyas1 For This Useful Post: |
08-03-2020, 12:58 | #2 (permalink) |
Member: 1351351 Status: Offline Thanks Meter: 277 | Full Credite to Medusa pro.............. Medusapro V2.1.1 TEST2 vesion nice work all MTK phnes...... Mi play eng firmware done Screenshots: Last edited by suriyas1; 08-03-2020 at 12:59. Reason: miss words |
