09-30-2022, 16:41 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: Here
Member: 2102546 Status: Online Thanks Meter: 480 | Need help S134DL [Answered] Best Regards | Yoba |
04-18-2023, 16:56 | #3 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Ganimedes
Member: 1067814 Status: Offline Sonork: 100.1618982 Thanks Meter: 82 | After unlock, some days left and it dead i cant fir it with repair boot. Boot config succesfully changed! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC GX6BAB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 15010047583642414200B1DD684E1925 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : GX6BAB Product revision : 0.0 Product serial number : (hex) B1DD684E Manufacturing date : 01/2022 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/GX6BAB_18_04_2023_11_43_23.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.4.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: efs (00002000, 00004000) 8 MB P02: sec_efs (00006000, 00004000) 8 MB P03: steady (0000A000, 00002000) 4 MB P04: nvram (0000C000, 00020000) 64 MB P05: spmfw (0002C000, 00000800) 1024 KB P06: scp1 (0002C800, 00000800) 1024 KB P07: sspm_1 (0002D000, 00000800) 1024 KB P08: tee1 (0002D800, 00001000) 2048 KB P09: tzar (0002E800, 00002000) 4 MB P10: gz1 (00030800, 00008000) 16 MB P11: lk (00038800, 00001000) 2048 KB P12: dtbo (00039800, 00004000) 8 MB P13: vbmeta (0003D800, 00000080) 64 KB P14: btd (0003D880, 00002780) 4.938 MB P15: protect1 (00040000, 00004000) 8 MB P16: protect2 (00044000, 00004000) 8 MB P17: seccfg (00048000, 00004000) 8 MB P18: bota (0004C000, 00016800) 45 MB P19: boot_para (00062800, 00000800) 1024 KB P20: para (00063000, 00000400) 512 KB P21: misc (00063400, 00000400) 512 KB P22: expdb (00063800, 0000A000) 20 MB P23: frp (0006D800, 00000800) 1024 KB P24: nvcfg (0006E000, 00010000) 32 MB P25: nvdata (0007E000, 00020000) 64 MB P26: metadata (0009E000, 00010000) 32 MB P27: keyrefuge (000AE000, 00008000) 16 MB P28: keydata (000B6000, 00008000) 16 MB P29: md_udc (000BE000, 0000B4D0) 22.6 MB P30: persistent (000C94D0, 00000400) 512 KB P31: proinfo (000C98D0, 00001800) 3072 KB P32: md1img (000CB0D0, 00032000) 100 MB P33: logo (000FD0D0, 00004000) 8 MB P34: param (001010D0, 00002000) 4 MB P35: up_param (001030D0, 00002000) 4 MB P36: persist (001050D0, 00018000) 48 MB P37: boot (0011D0D0, 00010000) 32 MB P38: recovery (0012D0D0, 00012800) 37 MB P39: vbmeta_system (0013F8D0, 00000080) 64 KB P40: vbmeta_vendor (0013F950, 00000080) 64 KB P41: efuse (0013F9D0, 00000400) 512 KB P42: rsv1 (0013FDD0, 00000230) 280 KB P43: sec1 (00140000, 00004000) 8 MB P44: super (00144000, 00B24000) 5.57 GB P45: prism (00C68000, 0003F000) 126 MB P46: optics (00CA7000, 00005000) 10 MB P47: cache (00CAC000, 000F8000) 496 MB P48: omr (00DA4000, 00007800) 15 MB P49: spu (00DAB800, 00019000) 50 MB P50: userdata (00DC4800, 02C77800) 22.23 GB Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/GX6BAB_efs_0x2000_0x4000_18_04_2023_11_43_23.bin file... Reading. Please wait... Done. Elapsed time 00:00:04 SW: 2.2.4.7; FW: 1.24. Backuping nvdata partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/GX6BAB_nvdata_0x7e000_0x20000_18_04_2023_11_43_23. bin file... Reading. Please wait... Done. Elapsed time 00:00:37 SW: 2.2.4.7; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 1327104 Number of sectors : 11681792 Build ID : SP1A.210812.016 Display Build ID : SP1A.210812.016.S134DLUDS5BWA1 Release ID : 12 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : a03sutfn-user 12 SP1A.210812.016 S134DLUDS5BWA1 release-keys --------------------------------------------------------------- Boot config succesfully changed! |
