02-16-2021, 15:51 | #1 (permalink) |
Freak Poster Join Date: Jul 2014 Location: EMMC
Member: 2228324 Status: Offline Thanks Meter: 79 | need help team [Answered] i want to update firmware or backup from it i always have error when connect emmc to box ERROR[011]: Read error. At sector 0. Disconnected. i use all voltage and bus speed not work how can i update firmware? Selected BGA 153/169 socket. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.0V Bus Mode : 1 bit Bus speed : 25 MHz Operations with eMMC restricted(Bus Mode : 1b) Connecting... Device : Samsung eMMC BJNB4R Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100424A4E423452106F37515F4437 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : BJNB4R Full name one from : KLMBG2JENB-B041 Product revision : 1.0 Product serial number : (hex) 6F37515F Manufacturing date : 04/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/BJNB4R_16_02_2021_18_18_48.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.0; FW: 2.00. ERROR[011]: Read error. At sector 0. Disconnected. |
02-17-2021, 10:40 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Make sure the emmc reballing and try connecting with the next setting: -Voltage: 2.8V -Bus Mode: 1 bit -Bus speed: 10 MHz |
