Nokia 1.4 user lock and frp reset done NOKIA 1.4 USER LOCK AND FRP RESET DONE Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Samsung eMMC FE62AB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100464536324142097A51F4DEB713 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FE62AB Product revision : 0.9 Product serial number : (hex) 7A51F4DE Manufacturing date : 11/2020 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/FE62AB_24_05_2022_08_33_30.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.4.4; FW: 2.00. P00: GPT (00000000, 00020000) 64 MB P01: modem (00020000, 0002A000) 84 MB P02: DDR (0004A000, 00000040) 32 KB P03: fsgcombine (0004A040, 00002000) 4 MB P04: fsg (0004C040, 00000C00) 1536 KB P05: sec (0004CC40, 00000020) 16 KB P06: aboot (0004CC60, 00000800) 1024 KB P07: abootbak (0004D460, 00000800) 1024 KB P08: dtbo (0004DC60, 00004000) 8 MB P09: dtbobak (00051C60, 00004000) 8 MB P10: vbmeta (00055C60, 00000080) 64 KB P11: vbmetabak (00055CE0, 00000080) 64 KB P12: boot (00055D60, 00010000) 32 MB P13: recovery (00065D60, 00018000) 48 MB P14: devinfo (0007DD60, 00000800) 1024 KB P15: super (0007E560, 004CC000) 2456 MB P16: vbmeta_system (0054A560, 00000080) 64 KB P17: limits (0054A5E0, 00000040) 32 KB P18: cmnlib (0054A620, 00000800) 1024 KB P19: cmnlibbak (0054AE20, 00000800) 1024 KB P20: cmnlib64 (0054B620, 00000800) 1024 KB P21: cmnlib64bak (0054BE20, 00000800) 1024 KB P22: keymaster (0054C620, 00000400) 512 KB P23: keymasterbak (0054CA20, 00000400) 512 KB P24: fsc (00560000, 00000002) 1024 b P25: ssd (00560008, 00000010) 8 KB P26: sbl1 (00560018, 00000400) 512 KB P27: sbl1bak (00560418, 00000400) 512 KB P28: rpm (00560818, 00000400) 512 KB P29: rpmbak (00560C18, 00000400) 512 KB P30: tz (00561018, 00001000) 2048 KB P31: tzbak (00562018, 00001000) 2048 KB P32: devcfg (00563018, 00000200) 256 KB P33: devcfgbak (00563218, 00000200) 256 KB P34: dsp (00563418, 00008000) 16 MB P35: modemst1 (0056B418, 00000C00) 1536 KB P36: modemst2 (0056C018, 00000C00) 1536 KB P37: splash (0056CC18, 00005800) 11 MB P38: cache (00572418, 00037000) 110 MB P39: persist (005A9418, 00010000) 32 MB P40: metadata (005B9418, 00008000) 16 MB P41: misc (005C1418, 00000800) 1024 KB P42: keystore (005C1C18, 00000400) 512 KB P43: config (005C2018, 00000040) 32 KB P44: oem (005C2058, 00004000) 8 MB P45: btui (005C6058, 00002800) 5 MB P46: mota (005C8858, 00000400) 512 KB P47: dip (005C8C58, 00000800) 1024 KB P48: mdtp (005C9458, 00010000) 32 MB P49: syscfg (005D9458, 00000400) 512 KB P50: mcfg (005D9858, 00002000) 4 MB P51: apdp (005DB858, 00000200) 256 KB P52: msadp (005DBA58, 00000200) 256 KB P53: dpo (005DBC58, 00000010) 8 KB P54: elabel (005E0000, 0000A000) 20 MB P55: userdata (00600000, 0171EFDF) 11.56 GB Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FE62AB_fsg_0x4c040_0xc00_24_05_2022_08_33_30.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.4.4; FW: 2.00. Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FE62AB_modemst1_0x56b418_0xc00_24_05_2022_08_33_30 .bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.4.4; FW: 2.00. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FE62AB_modemst2_0x56c018_0xc00_24_05_2022_08_33_30 .bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.4.4; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 517472 Number of sectors : 5029888 Build ID : QKQ1.200809.002 Display Build ID : 00WW_1_130 Release ID : 10 Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description 2 : 00WW_1_130 --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 9923. Reset operation finished Reset operation finished Backuping FRP data... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FRP_0x5c2018_0x40_24_05_2022_08_33_48.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.4.4; FW: 2.00. Removing FRP. Please wait... Done. Perform a Factory data reset from the phone menu. SW: 2.2.4.4; FW: 2.00. Opening C:/Users/SALEEM/OneDrive/Desktop/Samsung eMMC FE62AB_24_05_2022_08_34_59.bin file... Reading. Please wait... Done. Elapsed time 00:05:49 SW: 2.2.4.4; FW: 2.00. USER LOCK AND FRP RESET Partition table has been found on device. Erasing. Please wait... Erasing partition cache... Done. Erasing partition persist... Done. Erasing partition userdata... Done. Erasing is finished. SW: 2.2.4.4; FW: 2.00. https://i.ibb.co/mScFLdb/n-1-4.png this is my safety gif DUMP FILE ****************************/file/0cw1u...34_59.rar/file |
