Nokia TA-1288 stuck on 9008 mode after wipe userdata partition [Answered] Hi Team, its my 2nd job for Medusa pro, i got Nokia TA-1288 with password and FRP i tried to connect and read its dump and wiped userdata partition it was 46 GB and i cancelled it in middle phone went in QD loader 9008 Mode i downloaded Its firmware and tried to write Userdata thats only 4 MB but still phone is in QD loader 9008 mode CLK resistor came up while soldering ... and i solded back what could be issue here is log anyhelp will be Really appreciated log connect Welcome to Medusa Pro Software version 2.2.2. Started. Reader #0: Generic EMV Smartcard Reader 0 Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting to server. Please wait... Connection to server successful Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Unknown eMMC Page size : 512 B Block size : 512 B Block count : 0 Size : 0 b --------------------------------------------------------------- CID Info CID : 00000000000000000000000000000000 Manufacturer ID : 0X00 Device/BGA : Device (removable) OEM/Application ID : 0X00 Product name : Product revision : 0.0 Product serial number : (hex) 0 Manufacturing date : 00/1997 --------------------------------------------------------------- CSD Info CSD : 00000000000000000000000000000000 CSD structure : CSD version No. 1.0 SPEC version : Allocated by MMCA Data read access time1: 0 ms TRAN speed : 0 MHz READ block length : 1 Bytes WP group enable : NO PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 0 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b EXT_CSD data error!!! Connect unsuccessful!!! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Unknown eMMC Page size : 512 B Block size : 512 B Block count : 0 Size : 0 b --------------------------------------------------------------- CID Info CID : 00000000000000000000000000000000 Manufacturer ID : 0X00 Device/BGA : Device (removable) OEM/Application ID : 0X00 Product name : Product revision : 0.0 Product serial number : (hex) 0 Manufacturing date : 00/1997 --------------------------------------------------------------- CSD Info CSD : 00000000000000000000000000000000 CSD structure : CSD version No. 1.0 SPEC version : Allocated by MMCA Data read access time1: 0 ms TRAN speed : 0 MHz READ block length : 1 Bytes WP group enable : NO PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 0 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b EXT_CSD data error!!! Connect unsuccessful!!! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Foresee eMMC SLD64j Page size : 512 B Block size : 512 B Block count : 120832000 Size : 57.62 GB (59000.00 MB) --------------------------------------------------------------- CID Info CID : 880103534C4436346A408525511687FB Manufacturer ID : 0X88 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X03 Product name : SLD64j Product revision : 4.0 Product serial number : (hex) 85255116 Manufacturing date : 08/2020 --------------------------------------------------------------- CSD Info CSD : D0FFFF329F5903FFFFFFFFEF9640002D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20135936 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/SLD64j_17_10_2021_16_12_58.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.2; FW: 2.00. P00: GPT (00000000, 00020000) 64 MB P01: xbl_a (00020000, 00001C00) 3584 KB P02: xbl_b (00021C00, 00001C00) 3584 KB P03: xbl_config_a (00040000, 00000100) 128 KB P04: xbl_config_b (00040100, 00000100) 128 KB P05: tz_a (00060000, 00002000) 4 MB P06: tz_b (00080000, 00002000) 4 MB P07: rpm_a (000A0000, 00000400) 512 KB P08: rpm_b (000C0000, 00000400) 512 KB P09: hyp_a (000E0000, 00000400) 512 KB P10: hyp_b (00100000, 00000400) 512 KB P11: keymaster_a (00120000, 00000400) 512 KB P12: keymaster_b (00120400, 00000400) 512 KB P13: cmnlib_a (00120800, 00000400) 512 KB P14: cmnlib64_a (00120C00, 00000400) 512 KB P15: cmnlib_b (00121000, 00000400) 512 KB P16: cmnlib64_b (00121400, 00000400) 512 KB P17: mdtpsecapp_a (00121800, 00002000) 4 MB P18: mdtpsecapp_b (00123800, 00002000) 4 MB P19: mdtp_a (00125800, 00010000) 32 MB P20: mdtp_b (00135800, 00010000) 32 MB P21: modem_a (00145800, 0005A000) 180 MB P22: modem_b (0019F800, 0005A000) 180 MB P23: dsp_a (001F9800, 00010000) 32 MB P24: dsp_b (00209800, 00010000) 32 MB P25: abl_a (00219800, 00000800) 1024 KB P26: abl_b (0021A000, 00000800) 1024 KB P27: ddr (0021A800, 00000800) 1024 KB P28: bluetooth_a (0021B000, 00000800) 1024 KB P29: bluetooth_b (0021B800, 00000800) 1024 KB P30: ssd (00220000, 00000010) 8 KB P31: imagefv_a (00220010, 00001000) 2048 KB P32: imagefv_b (00221010, 00001000) 2048 KB P33: uefisecapp_a (00222010, 00001000) 2048 KB P34: uefisecapp_b (00223010, 00001000) 2048 KB P35: persist (00224010, 00010000) 32 MB P36: metadata (00234010, 00008000) 16 MB P37: misc (0023C010, 00000800) 1024 KB P38: keystore (0023C810, 00000400) 512 KB P39: devcfg_a (0023CC10, 00000100) 128 KB P40: devcfg_b (0023CD10, 00000100) 128 KB P41: featenabler_a (0023CE10, 00000100) 128 KB P42: featenabler_b (0023CF10, 00000100) 128 KB P43: qupfw_a (0023D010, 00000080) 64 KB P44: qupfw_b (0023D090, 00000080) 64 KB P45: frp (0023D110, 00000400) 512 KB P46: rawdump (0023D510, 00040000) 128 MB P47: dip (00280000, 00000800) 1024 KB P48: apdp (002A0000, 00000200) 256 KB P49: spunvm (002A0200, 00004000) 8 MB P50: splash_a (002A4200, 00010520) 32.64 MB P51: splash_b (002B4720, 00010520) 32.64 MB P52: limits (002E0000, 00000008) 4 KB P53: toolsfv (002E0008, 00000800) 1024 KB P54: logfs (00300000, 00004000) 8 MB P55: cateloader (00304000, 00001000) 2048 KB P56: logdump (00305000, 00020000) 64 MB P57: vbmeta_a (00340000, 00000080) 64 KB P58: vbmeta_b (00340080, 00000080) 64 KB P59: storsec (00340100, 00000100) 128 KB P60: multiimgoem (00340200, 00000040) 32 KB P61: multiimgqti (00340240, 00000040) 32 KB P62: secdata (00340280, 00000032) 25 KB P63: catefv (003402B8, 00000400) 512 KB P64: catecontentfv (003406B8, 00000800) 1024 KB P65: uefivarstore (00340EB8, 00000400) 512 KB P66: modemst1 (00360000, 00001000) 2048 KB P67: modemst2 (00361000, 00001000) 2048 KB P68: fsg (00380000, 00001000) 2048 KB P69: fsc (003A0000, 00000100) 128 KB P70: msadp (003A0100, 00000200) 256 KB P71: proinfo (003A0300, 00000800) 1024 KB P72: fsgall (003A0B00, 00002000) 4 MB P73: private (003A2B00, 00000800) 1024 KB P74: reserve (003A3300, 00000800) 1024 KB P75: reserve2 (003A3B00, 00000800) 1024 KB P76: devinfo (003C0000, 00000008) 4 KB P77: elabel_a (003E0000, 00028000) 80 MB P78: elabel_b (00408000, 00028000) 80 MB P79: simlock (00430000, 00020000) 64 MB P80: imeilock (00450000, 00020000) 64 MB P81: boot_a (00470000, 00030000) 96 MB P82: boot_b (004A0000, 00030000) 96 MB P83: dtbo_a (004D0000, 0000C000) 24 MB P84: dtbo_b (004DC000, 0000C000) 24 MB P85: vbmeta_system_a (00500000, 00000080) 64 KB P86: vbmeta_system_b (00500080, 00000080) 64 KB P87: recovery_a (00500100, 00030000) 96 MB P88: recovery_b (00530100, 00030000) 96 MB P89: super (00580000, 01000000) 8 GB P90: userdata (01580000, 05DBBFDF) 46.87 GB Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/SLD64j_modemst1_0x360000_0x1000_17_10_2021_16_12_5 8.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 2.00. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/SLD64j_modemst2_0x361000_0x1000_17_10_2021_16_12_5 8.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 2.00. Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/SLD64j_fsg_0x380000_0x1000_17_10_2021_16_12_58.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Not found --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 17033. Switched to boot area partition 1. Opening C:/Users/SA-GSM/Desktop/TA-1288/Foresee eMMC SLD64j_17_10_2021_16_13_28.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.2.2; FW: 2.00. Partition table has been found on device. Switched to user area. Save to C:/Users/SA-GSM/Desktop/TA-1288 folder... Reading partition GPT... Done. Reading partition xbl_a... Done. Reading partition xbl_b... Done. Reading partition xbl_config_a... Done. Reading partition xbl_config_b... Done. Reading partition tz_a... Done. Reading partition tz_b... Done. Reading partition rpm_a... Done. Reading partition rpm_b... Done. Reading partition hyp_a... Done. Reading partition hyp_b... Done. Reading partition keymaster_a... Done. Reading partition keymaster_b... Done. Reading partition cmnlib_a... Done. Reading partition cmnlib64_a... Done. Reading partition cmnlib_b... Done. Reading partition cmnlib64_b... Done. Reading partition mdtpsecapp_a... Done. Reading partition mdtpsecapp_b... Done. Reading partition mdtp_a... Done. Reading partition mdtp_b... Done. Reading partition modem_a... Done. Reading partition modem_b... ERROR[008]: Data TX error. Attempting to read... Disconnected. Get Measurements error. Reloading... Model Settings: Interface : USB Model Settings: Interface : USB Loading firmware. Please wait... Done. Selected eMMC interface. Socket detected! Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Foresee eMMC SLD64j Page size : 512 B Block size : 512 B Block count : 120832000 Size : 57.62 GB (59000.00 MB) --------------------------------------------------------------- CID Info CID : 880103534C4436346A408525511687FB Manufacturer ID : 0X88 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X03 Product name : SLD64j Product revision : 4.0 Product serial number : (hex) 85255116 Manufacturing date : 08/2020 --------------------------------------------------------------- CSD Info CSD : D0FFFF329F5903FFFFFFFFEF9640002D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20135936 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/SLD64j_17_10_2021_16_18_16.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.2; FW: 2.00. P00: GPT (00000000, 00020000) 64 MB P01: xbl_a (00020000, 00001C00) 3584 KB P02: xbl_b (00021C00, 00001C00) 3584 KB P03: xbl_config_a (00040000, 00000100) 128 KB P04: xbl_config_b (00040100, 00000100) 128 KB P05: tz_a (00060000, 00002000) 4 MB P06: tz_b (00080000, 00002000) 4 MB P07: rpm_a (000A0000, 00000400) 512 KB P08: rpm_b (000C0000, 00000400) 512 KB P09: hyp_a (000E0000, 00000400) 512 KB P10: hyp_b (00100000, 00000400) 512 KB P11: keymaster_a (00120000, 00000400) 512 KB P12: keymaster_b (00120400, 00000400) 512 KB P13: cmnlib_a (00120800, 00000400) 512 KB P14: cmnlib64_a (00120C00, 00000400) 512 KB P15: cmnlib_b (00121000, 00000400) 512 KB P16: cmnlib64_b (00121400, 00000400) 512 KB P17: mdtpsecapp_a (00121800, 00002000) 4 MB P18: mdtpsecapp_b (00123800, 00002000) 4 MB P19: mdtp_a (00125800, 00010000) 32 MB P20: mdtp_b (00135800, 00010000) 32 MB P21: modem_a (00145800, 0005A000) 180 MB P22: modem_b (0019F800, 0005A000) 180 MB P23: dsp_a (001F9800, 00010000) 32 MB P24: dsp_b (00209800, 00010000) 32 MB P25: abl_a (00219800, 00000800) 1024 KB P26: abl_b (0021A000, 00000800) 1024 KB P27: ddr (0021A800, 00000800) 1024 KB P28: bluetooth_a (0021B000, 00000800) 1024 KB P29: bluetooth_b (0021B800, 00000800) 1024 KB P30: ssd (00220000, 00000010) 8 KB P31: imagefv_a (00220010, 00001000) 2048 KB P32: imagefv_b (00221010, 00001000) 2048 KB P33: uefisecapp_a (00222010, 00001000) 2048 KB P34: uefisecapp_b (00223010, 00001000) 2048 KB P35: persist (00224010, 00010000) 32 MB P36: metadata (00234010, 00008000) 16 MB P37: misc (0023C010, 00000800) 1024 KB P38: keystore (0023C810, 00000400) 512 KB P39: devcfg_a (0023CC10, 00000100) 128 KB P40: devcfg_b (0023CD10, 00000100) 128 KB P41: featenabler_a (0023CE10, 00000100) 128 KB P42: featenabler_b (0023CF10, 00000100) 128 KB P43: qupfw_a (0023D010, 00000080) 64 KB P44: qupfw_b (0023D090, 00000080) 64 KB P45: frp (0023D110, 00000400) 512 KB P46: rawdump (0023D510, 00040000) 128 MB P47: dip (00280000, 00000800) 1024 KB P48: apdp (002A0000, 00000200) 256 KB P49: spunvm (002A0200, 00004000) 8 MB P50: splash_a (002A4200, 00010520) 32.64 MB P51: splash_b (002B4720, 00010520) 32.64 MB P52: limits (002E0000, 00000008) 4 KB P53: toolsfv (002E0008, 00000800) 1024 KB P54: logfs (00300000, 00004000) 8 MB P55: cateloader (00304000, 00001000) 2048 KB P56: logdump (00305000, 00020000) 64 MB P57: vbmeta_a (00340000, 00000080) 64 KB P58: vbmeta_b (00340080, 00000080) 64 KB P59: storsec (00340100, 00000100) 128 KB P60: multiimgoem (00340200, 00000040) 32 KB P61: multiimgqti (00340240, 00000040) 32 KB P62: secdata (00340280, 00000032) 25 KB P63: catefv (003402B8, 00000400) 512 KB P64: catecontentfv (003406B8, 00000800) 1024 KB P65: uefivarstore (00340EB8, 00000400) 512 KB P66: modemst1 (00360000, 00001000) 2048 KB P67: modemst2 (00361000, 00001000) 2048 KB P68: fsg (00380000, 00001000) 2048 KB P69: fsc (003A0000, 00000100) 128 KB P70: msadp (003A0100, 00000200) 256 KB P71: proinfo (003A0300, 00000800) 1024 KB P72: fsgall (003A0B00, 00002000) 4 MB P73: private (003A2B00, 00000800) 1024 KB P74: reserve (003A3300, 00000800) 1024 KB P75: reserve2 (003A3B00, 00000800) 1024 KB P76: devinfo (003C0000, 00000008) 4 KB P77: elabel_a (003E0000, 00028000) 80 MB P78: elabel_b (00408000, 00028000) 80 MB P79: simlock (00430000, 00020000) 64 MB P80: imeilock (00450000, 00020000) 64 MB P81: boot_a (00470000, 00030000) 96 MB P82: boot_b (004A0000, 00030000) 96 MB P83: dtbo_a (004D0000, 0000C000) 24 MB P84: dtbo_b (004DC000, 0000C000) 24 MB P85: vbmeta_system_a (00500000, 00000080) 64 KB P86: vbmeta_system_b (00500080, 00000080) 64 KB P87: recovery_a (00500100, 00030000) 96 MB P88: recovery_b (00530100, 00030000) 96 MB P89: super (00580000, 01000000) 8 GB P90: userdata (01580000, 05DBBFDF) 46.87 GB Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/SLD64j_modemst1_0x360000_0x1000_17_10_2021_16_18_1 6.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 2.00. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/SLD64j_modemst2_0x361000_0x1000_17_10_2021_16_18_1 6.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 2.00. Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/SLD64j_fsg_0x380000_0x1000_17_10_2021_16_18_16.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Not found --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 17033. Partition table has been found on device. Partition table has been found on device. Partition table has been found on device. Erasing. Please wait... Erasing partition userdata... Cancelled SW: 2.2.2; FW: 2.00. Erase operation failed! Disconnected. Selected PIN - CONNECTOR. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Pin connector is detected!(eMMC: 1b, UFS: PWM 1-4) Connecting... Device : Foresee eMMC SLD64j Page size : 512 B Block size : 512 B Block count : 120832000 Size : 57.62 GB (59000.00 MB) --------------------------------------------------------------- CID Info CID : 880103534C4436346A408525511687FB Manufacturer ID : 0X88 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X03 Product name : SLD64j Product revision : 4.0 Product serial number : (hex) 85255116 Manufacturing date : 08/2020 --------------------------------------------------------------- CSD Info CSD : D0FFFF329F5903FFFFFFFFEF9640002D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 20135936 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/SLD64j_17_10_2021_16_21_50.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.2; FW: 2.00. P00: GPT (00000000, 00020000) 64 MB P01: xbl_a (00020000, 00001C00) 3584 KB P02: xbl_b (00021C00, 00001C00) 3584 KB P03: xbl_config_a (00040000, 00000100) 128 KB P04: xbl_config_b (00040100, 00000100) 128 KB P05: tz_a (00060000, 00002000) 4 MB P06: tz_b (00080000, 00002000) 4 MB P07: rpm_a (000A0000, 00000400) 512 KB P08: rpm_b (000C0000, 00000400) 512 KB P09: hyp_a (000E0000, 00000400) 512 KB P10: hyp_b (00100000, 00000400) 512 KB P11: keymaster_a (00120000, 00000400) 512 KB P12: keymaster_b (00120400, 00000400) 512 KB P13: cmnlib_a (00120800, 00000400) 512 KB P14: cmnlib64_a (00120C00, 00000400) 512 KB P15: cmnlib_b (00121000, 00000400) 512 KB P16: cmnlib64_b (00121400, 00000400) 512 KB P17: mdtpsecapp_a (00121800, 00002000) 4 MB P18: mdtpsecapp_b (00123800, 00002000) 4 MB P19: mdtp_a (00125800, 00010000) 32 MB P20: mdtp_b (00135800, 00010000) 32 MB P21: modem_a (00145800, 0005A000) 180 MB P22: modem_b (0019F800, 0005A000) 180 MB P23: dsp_a (001F9800, 00010000) 32 MB P24: dsp_b (00209800, 00010000) 32 MB P25: abl_a (00219800, 00000800) 1024 KB P26: abl_b (0021A000, 00000800) 1024 KB P27: ddr (0021A800, 00000800) 1024 KB P28: bluetooth_a (0021B000, 00000800) 1024 KB P29: bluetooth_b (0021B800, 00000800) 1024 KB P30: ssd (00220000, 00000010) 8 KB P31: imagefv_a (00220010, 00001000) 2048 KB P32: imagefv_b (00221010, 00001000) 2048 KB P33: uefisecapp_a (00222010, 00001000) 2048 KB P34: uefisecapp_b (00223010, 00001000) 2048 KB P35: persist (00224010, 00010000) 32 MB P36: metadata (00234010, 00008000) 16 MB P37: misc (0023C010, 00000800) 1024 KB P38: keystore (0023C810, 00000400) 512 KB P39: devcfg_a (0023CC10, 00000100) 128 KB P40: devcfg_b (0023CD10, 00000100) 128 KB P41: featenabler_a (0023CE10, 00000100) 128 KB P42: featenabler_b (0023CF10, 00000100) 128 KB P43: qupfw_a (0023D010, 00000080) 64 KB P44: qupfw_b (0023D090, 00000080) 64 KB P45: frp (0023D110, 00000400) 512 KB P46: rawdump (0023D510, 00040000) 128 MB P47: dip (00280000, 00000800) 1024 KB P48: apdp (002A0000, 00000200) 256 KB P49: spunvm (002A0200, 00004000) 8 MB P50: splash_a (002A4200, 00010520) 32.64 MB P51: splash_b (002B4720, 00010520) 32.64 MB P52: limits (002E0000, 00000008) 4 KB P53: toolsfv (002E0008, 00000800) 1024 KB P54: logfs (00300000, 00004000) 8 MB P55: cateloader (00304000, 00001000) 2048 KB P56: logdump (00305000, 00020000) 64 MB P57: vbmeta_a (00340000, 00000080) 64 KB P58: vbmeta_b (00340080, 00000080) 64 KB P59: storsec (00340100, 00000100) 128 KB P60: multiimgoem (00340200, 00000040) 32 KB P61: multiimgqti (00340240, 00000040) 32 KB P62: secdata (00340280, 00000032) 25 KB P63: catefv (003402B8, 00000400) 512 KB P64: catecontentfv (003406B8, 00000800) 1024 KB P65: uefivarstore (00340EB8, 00000400) 512 KB P66: modemst1 (00360000, 00001000) 2048 KB P67: modemst2 (00361000, 00001000) 2048 KB P68: fsg (00380000, 00001000) 2048 KB P69: fsc (003A0000, 00000100) 128 KB P70: msadp (003A0100, 00000200) 256 KB P71: proinfo (003A0300, 00000800) 1024 KB P72: fsgall (003A0B00, 00002000) 4 MB P73: private (003A2B00, 00000800) 1024 KB P74: reserve (003A3300, 00000800) 1024 KB P75: reserve2 (003A3B00, 00000800) 1024 KB P76: devinfo (003C0000, 00000008) 4 KB P77: elabel_a (003E0000, 00028000) 80 MB P78: elabel_b (00408000, 00028000) 80 MB P79: simlock (00430000, 00020000) 64 MB P80: imeilock (00450000, 00020000) 64 MB P81: boot_a (00470000, 00030000) 96 MB P82: boot_b (004A0000, 00030000) 96 MB P83: dtbo_a (004D0000, 0000C000) 24 MB P84: dtbo_b (004DC000, 0000C000) 24 MB P85: vbmeta_system_a (00500000, 00000080) 64 KB P86: vbmeta_system_b (00500080, 00000080) 64 KB P87: recovery_a (00500100, 00030000) 96 MB P88: recovery_b (00530100, 00030000) 96 MB P89: super (00580000, 01000000) 8 GB P90: userdata (01580000, 05DBBFDF) 46.87 GB Backuping modemst1 partition... Opening C:/Program Files/Medusa Pro Software/Backups/SLD64j_modemst1_0x360000_0x1000_17_10_2021_16_21_5 0.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 2.00. Backuping modemst2 partition... Opening C:/Program Files/Medusa Pro Software/Backups/SLD64j_modemst2_0x361000_0x1000_17_10_2021_16_21_5 0.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 2.00. Backuping fsg partition... Opening C:/Program Files/Medusa Pro Software/Backups/SLD64j_fsg_0x380000_0x1000_17_10_2021_16_21_50.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Not found --------------------------------------------------------------- RPMB: Counter of the successful data write requests = 17033. Backuping FRP data... Opening C:/Program Files/Medusa Pro Software/Backups/FRP_0x23d110_0x400_17_10_2021_16_22_35.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 2.2.2; FW: 2.00. Removing FRP. Please wait... Done. SW: 2.2.2; FW: 2.00. Disconnected. Get Measurements error. Reloading... |
Hello. Most likely it hardware problem. Your device can't take connection of eMMC. Please, check CMD and CLK signals. |
Finally DONE NOKIA TA-1288 FRP+Userdata wiped done with Medusa pro........ Thank YOU TEAM |
