Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 09-16-2017, 14:45   #1 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
G532G After Boot repair Hang on logo !! Please Help
G532G After Boot repair Hang on logo !! I flash with latest more than 5 file Flash success , but same problem.
After flash phone automatically goes to Recovery Mode.... and show below error
E:failed to mount/efs (Invalid argument)
Repair Log
Welcome to Medusa Pro Software version 1.4.4.
Started.
Reader #0: Generic EMV Smartcard Reader 0
Downloaded and installed file C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532G_EMMC.srf.
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-G532G
SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532G_EMMC.srf
Voltage : 1.8V
Bus Mode : 1
Bus speed : Auto
Connecting...
Device : Hynix eMMC H8G4u
Page size : 512 B
Block size : 512 B
Block count : 15269888
CID Info
CID : 90014A483847347592011E2538106485
Manufacturer ID : 0X90
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4A
Product name : H8G4u
Product revision : 0.1
Product serial number : (hex) 1E253810
Manufacturing date : 06/2017
CSD Info
CSD : D02701320F5903FFFFFFFFE78A40002B
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : 01001000
Boot partition enable : Boot partition 1 (Bus width = 1Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 3817472 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...Ok
Disk/Image size : d2000000 bytes
Device sector size : 512 bytes
Partition offset : 393216
Number of sectors : 6307840
Device Manufacturer : samsung
Device Platform : mt6737t
Build ID : MMB29T
Display Build ID : MMB29T.G532GDXU1APJ7
Release ID : 6.0.1
Device Model : SM-G532G
Device Name : grandppltedx
Architecture ABI : armeabi-v7a
Architecture ABI2 : armeabi
Architecture ABI List : armeabi-v7a,armeabi
Build Description : grandppltedx-user 6.0.1 MMB29T G532GDXU1APJ7 release-keys
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4u_16_09_2017_14_24_07.bin.
Connect successful.
SW: 1.4.4; FW: 1.22.
P00: GPT (00000000, 00002000)
P01: BOTA0 (00002000, 00002000)
P02: nvram (00004000, 00004000)
P03: lk (00008000, 00001000)
P04: BOTA1 (00009000, 00001000)
P05: secro (0000A000, 00003800)
P06: seccfg (0000D800, 00000400)
P07: efuse (0000DC00, 00000400)
P08: tee1 (0000E000, 00003000)
P09: BOTA2 (00011000, 00003000)
P10: EFS (00014000, 00004000)
P11: nvdata (00018000, 00010000)
P12: PARAM (00028000, 00004000)
P13: recovery (0002C000, 00008000)
P14: boot (00034000, 00008000)
P15: md1img (0003C000, 00010000)
P16: md1dsp (0004C000, 00002000)
P17: keystore (0004E000, 00004000)
P18: omekeystore (00052000, 00001C00)
P19: proinfo (00053C00, 00001400)
P20: para (00055000, 00000400)
P21: PERSISTENT (00055400, 00000400)
P22: STEADY (00055800, 00000800)
P23: protect1 (00056000, 00004000)
P24: protect2 (0005A000, 00004000)
P25: RESERVE2 (0005E000, 00002000)
P26: system (00060000, 00604000)
P27: cache (00664000, 000C8000)
P28: hidden (0072C000, 0001E000)
P29: userdata (0074A000, 00744000)
Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532G_EMMC.srf".
Write data verification is enabled.
Switched to boot area partition 1.
Writing BOOT1 partition... Done.
Switched to user area.
Writing GPT partition... Done.
Writing bota0 partition... Done.
Writing lk partition... Done.
Writing bota1 partition... Done.
Writing secro partition... Done.
Writing seccfg partition... Done.
Writing efuse partition... Done.
Writing tee1 partition... Done.
Writing bota2 partition... Done.
Writing efs partition... Done.
Writing param partition... Done.
Writing recovery partition... Done.
Writing boot partition... Done.
Writing md1img partition... Done.
Writing md1dsp partition... Done.
Writing keystore partition... Done.
Writing omekeystore partition... Done.
Writing proinfo partition... Done.
Writing para partition... Done.
Writing persistent partition... Done.
Writing steady partition... Done.
Smart Repair is successfully complete.
Disconnected.
Old 09-17-2017, 08:12   #2 (permalink)
SRASHED's Avatar
Member: 1024699
Sonork: 100.1622959
Thanks Meter: 600
Manage working efs & write it via odin.
The Following User Says Thank You to SRASHED For This Useful Post:
Old 09-18-2017, 07:26   #3 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Have You written these firmwares via Medusa Pro Software ("Factory Repair") or using Samsung tool?
The Following User Says Thank You to Medusa Box For This Useful Post:
Old 09-20-2017, 07:20   #4 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
No, i flash with Odin
The Following User Says Thank You to maxpro12 For This Useful Post:
Page generated in 0.13338 seconds with 8 queries
