04-05-2018, 12:28 | #1 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2200422 Status: Offline Thanks Meter: 22 | Samsung GT-S5750E MI: Medusa JTAG init failed [Solved] Selected device model: Samsung GT-S5750E Connecting. Please wait... Checking data... Medusa JTAG Firmware version 1.23. MI: Medusa JTAG init failed. Please connect the target device and power it on... Checking data... Medusa JTAG Firmware version 1.23. MI: Medusa JTAG init failed. Checking data... Medusa JTAG Firmware version 1.23. MI: Medusa JTAG init failed. Last edited by Medusa Box; 04-28-2018 at 16:02. |
04-05-2018, 12:42 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Please check soldering of all necessary wires, press "Connect" button in Software, connect device to Box and power it on. Use fully charged battery and/or USB cable. |
04-05-2018, 20:16 | #6 (permalink) | |
Member: 2200422 Status: Offline Thanks Meter: 22 | Quote:
SAMSUNG_GT-S5750E_JTAG.srf in support area i test by select GT-S5310T but Last edited by Medusa Box; 04-06-2018 at 04:56. | |
04-06-2018, 04:56 | #7 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Please check soldering of all wires, most likely, some of wires were soldered incorrectly. Do each wire as short as possible (max 3-5 CM length) and try to connect again. |
04-18-2018, 14:27 | #9 (permalink) | ||
and all is ok by avometer but some Quote:
04-19-2018, 14:20 | #10 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | We have tried to connect our GT-S5750E and there no any problems with connecting: Most likely You have soldered some wires incorrectly. Check soldering each wire and try to connect the device again. To connect the device do the following: 1. Select (set) Medusa Pro Software settings as in the screenshot above. 2. Insert (connect) fully charged battery into the phone. 3. Plug (connect) device to Medusa Pro Box. 4. Connect USB cable to the phone. 5. Press "Connect" button in Software. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
04-28-2018, 15:48 | #11 (permalink) | |
boot repair done but i have small problem after repair boot phone stock in logo i flash it by S5750EXXKF2_OXAKB1.oct but some problem stock in logo | |
04-28-2018, 16:02 | #12 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Most likely, your device has HW issue (problem with flash chip). If possible, try to replace it and do repairing again. Also You can try to do erase Full flash and then do "Factory Repair" again and r-flash the phone with the latest firmware version. Last edited by Medusa Box; 05-02-2018 at 08:39. |
