08-09-2019, 09:10 | #3 (permalink) |
Freak Poster Join Date: Jul 2008 Location: morocco Age: 44
Member: 821750 Status: Offline Sonork: 19790515 Thanks Meter: 29 | Welcome to Medusa Pro Software version 1.7.7. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : M250N SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_M250N_EMMC_QE13MB.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB (15032.00 MB) --------------------------------------------------------------- CID Info CID : 90014A484147346132A43683BB1B3579 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 10.4 Product serial number : (hex) 3683BB1B Manufacturing date : 03/2018 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab800000 bytes Device sector size : 512 bytes Partition offset : 1179648 Number of sectors : 8126464 Device Manufacturer :lge Device Platform :mt6750 Build ID :O11019 Display Build ID :O11019 Release ID :8.1.0 Device Model :LG-M250 Device Name :mlv5_global_com Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :mlv5_global_com-user 8.1.0 O11019 183041135d8b1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/HAG4a2_09_08_2019_01_54_06.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: spare1 (00001C00, 00002400) 4.5 MB P03: misc2 (00004000, 00004000) 8 MB P04: ftm (00008000, 00004000) 8 MB P05: nvram (0000C000, 00002800) 5 MB P06: spare2 (0000E800, 00001800) 3072 KB P07: protect1 (00010000, 00004000) 8 MB P08: protect2 (00014000, 00004000) 8 MB P09: lk (00018000, 00000800) 1024 KB P10: lk2 (00018800, 00000800) 1024 KB P11: laf (00019000, 0000E000) 28 MB P12: para (00027000, 00000400) 512 KB P13: boot (00027400, 00008C00) 17.5 MB P14: recovery (00030000, 00009800) 19 MB P15: recoverybak (00039800, 00009800) 19 MB P16: logo (00043000, 00004000) 8 MB P17: lo_bak_go (00047000, 00004000) 8 MB P18: expdb (0004B000, 00005000) 10 MB P19: seccfg (00050000, 00004000) 8 MB P20: oemkeystore (00054000, 00004000) 8 MB P21: secro (00058000, 00003000) 6 MB P22: spare3 (0005B000, 00001000) 2048 KB P23: keystore (0005C000, 00004000) 8 MB P24: tee1 (00060000, 00002800) 5 MB P25: tee2 (00062800, 00002800) 5 MB P26: eksst (00065000, 00000400) 512 KB P27: encrypt (00065400, 00000400) 512 KB P28: spare4 (00065800, 00002800) 5 MB P29: persist_lg (00068000, 00004000) 8 MB P30: mpt (0006C000, 0000B000) 22 MB P31: lgfota (00077000, 00005000) 10 MB P32: rct (0007C000, 00000800) 1024 KB P33: factory (0007C800, 0001C000) 56 MB P34: efuse (00098800, 00000400) 512 KB P35: spare5 (00098C00, 00003400) 6.5 MB P36: persist (0009C000, 00018000) 48 MB P37: nvcfg (000B4000, 00004000) 8 MB P38: nvdata (000B8000, 00010000) 32 MB P39: metadata (000C8000, 00010000) 32 MB P40: md1img (000D8000, 0000C000) 24 MB P41: md1dsp (000E4000, 00002000) 4 MB P42: md1arm7 (000E6000, 00001800) 3072 KB P43: md3img (000E7800, 00002800) 5 MB P44: cust (000EA000, 00032000) 100 MB P45: frp (0011C000, 00004000) 8 MB P46: system (00120000, 007C0000) 3968 MB P47: cache (008E0000, 00100000) 512 MB P48: OP (009E0000, 00038000) 112 MB P49: userdata (00A18000, 012FEC00) 9.498 GB P50: flashinfo (01D16C00, 00008000) 16 MB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/LG_M250N_EMMC_QE13MB.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switch error!!! Writing BOOT2 partition... ERROR[012]: Write error. At sector 0 Attempting to write... Done. Switched to user area. Writing GPT partition... Done. Writing proinfo partition... Done. Writing spare1 partition... Done. Writing misc2 partition... Done. Writing ftm partition... Done. Writing nvram partition... Done. Writing spare2 partition... Done. Writing protect1 partition... Done. Writing protect2 partition... Done. Writing lk partition... Done. Writing lk2 partition... Done. Writing laf partition... Done. Writing para partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing recoverybak partition... Done. Writing logo partition... Done. Writing lo_bak_go partition... Done. Writing expdb partition... Done. Writing seccfg partition... Done. Writing oemkeystore partition... Done. Writing secro partition... Done. Writing spare3 partition... Done. Writing keystore partition... Done. Writing tee1 partition... Done. Writing tee2 partition... Done. Writing eksst partition... Done. Writing encrypt partition... Done. Writing spare4 partition... Done. Writing persist_lg partition... Done. Writing mpt partition... Done. Writing lgfota partition... Done. Writing rct partition... Done. Writing factory partition... Done. Writing efuse partition... Done. Writing spare5 partition... Done. Writing persist partition... Done. Writing nvcfg partition... Done. Writing nvdata partition... Done. Writing metadata partition... Done. Writing md1img partition... Done. Writing md1dsp partition... Done. Writing md1arm7 partition... Done. Writing md3img partition... Done. Writing cust partition... Done. Writing frp partition... Done. Writing flashinfo partition... Done. Smart Repair is successfully complete. SW: 1.7.7; FW: 1.24. |
08-14-2019, 16:07 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | Partition config : (0x00) 00000000 This config is not correct for mtk cpu based mobile Repaire it with correct config by using medusa pro soft and all will be ok |
The Following 2 Users Say Thank You to rebainoor For This Useful Post: |
